It does'nt continue booting, it shut off automatically, what is the cause?
  • Computers & ... Master
  • 15,756 Answers
Have you tried booting in safe mode? If so what happens?
Posted on Feb 17, 2014
Need a boot driver
If your computer came with recovery media, you'll want to insert and boot from the operating system install disk (if it doesn't boot from your media automatically, you may have to change the boot order in BIOS [hit f10 at boot time]. Depending on the version of windows you are running, the boot options will be slightly different but you want to end up in repair mode. in XP that will mean hitting "R" to repair, vista/7 you will hit "repair my computer". Once you can get into a recovery console, you'll want to type: sfc /scannow
That will find and replace corrupt system files and boot drivers.
Nov 07, 2013 | HP Compaq Presario SR2010NX PC Desktop
How to turn on a dhcp on a rca model dcm425 cable modem?
Enabling DHCP at the Client To enable the Windows NT DHCP client, you must log on as administrator at the Windows NT client.
Normally, you enable DHCP as part of the installation procedure for Microsoft TCP/IP, however, you can use this procedure if you have manually configured TCP/IP:
  1. Run Control Panel and choose Network.
    The Network Settings dialog box appears.
  2. Under Installed Network Software, select TCP/IP Protocol and then choose configure.
    The TCP/IP configuration dialog box appears.
  3. Select Enable Automatic DHCP Configuration.
    A Microsoft (MS) TCP/IP message appears, indicating that the DHCP Protocol attempts to configure the server automatically during system initialization.
  4. Choose Yes.
    A MS TCP/IP Configuration dialog box appears, displaying current TCP/IP configuration parameters. The IP Address and Subnet Mask boxes are not available (grayed out) and the manually configured values are no longer displayed.
  5. Choose OK to return to the Network Settings dialog box.
  6. Choose OK again.
  7. Shut down and restart the computer.
To enable DHCP on a Windows for Workgroups client if TCP/IP is not installed yet:
  1. Use Network Setup to install the MS TCP/IP-32 3.11 protocol.
  2. In the MS TCP/IP Configuration dialog box, select the Enable Automatic DHCP Configuration check box, and choose Continue.
  3. Restart the computer to initialize TCP/IP using DHCP.
To enable DHCP on a Windows for Workgroups client if TCP/IP is installed:
  1. To access the Network Drivers dialog box, run Network Setup.
  2. Select Microsoft TCP/IP-32 3.11, and then choose Setup.
  3. In the MS TCP/IP Configuration dialog box, select the Enable Automatic DHCP Configuration check box, and choose continue.
    A message box appears indicating that the configuration of DHCP overrides any values established locally.
  4. Choose Yes.
  5. To initialize TCP/IP using DHCP information, restart the computer.
Dec 19, 2010 | RCA Computers & Internet
Nltdr missing
How To: Fix "NTLDR is missing"
Applies to: Microsoft Windows NT, Windows 2000, Windows XP
Symptoms
When you start your computer, you receive the error message "NTLDR is missing. Press any key to restart."
Cause
The error message "NTLDR is missing" means that the Windows boot loader (NT Loader, NTLDR) cannot be found. This oftenoccurs when the computer tries to boot from a drive other than the one Windows is installed on, due to a change in the driveconfiguration or because you left a bootable disk in a removable drive. But it may also be because the NTLDR file has beencorrupted or deleted.
SolutionCheck the boot drives
First, check the boot drives to make sure that the computer is not trying to boot from a different drive to the one thatcontains Windows.
  • Check that there are no CDs or DVDs in the CD/DVD drives.
  • Check that no removable drives are plugged in to the USB ports.
  • Check the boot order in the BIOS Setup to ensure that the computer boots from the drive containing Windows before any other bootable devices.
If this does not resolve the problem, you will have to repair the NT boot loader.
Fix NTLDR
The easiest way to fix the "NTLDR is missing" error is to use Spotmau PowerSuite.However, if your computer is using Windows XP and you have a Windows XP installation CD you may be able to boot from this anduse the Recovery Console to fix NTLDR manually instead.
Use Spotmau PowerSuiteInsert the Spotmau PowerSuite CD and start the computer. The main menu will appear.spotmau-2.gif
  • Click 2. Windows Recovery.
  • When the Windows Recovery tool starts, click Windows NT/2000/XP/2003.
  • On the Windows NT/2000/XP/2003 Recovery dialog, click Recover NTLDR and NTDETECT.
  • On the Recover NTLDR and NTDETECT dialog, select your operating system (e.g. Windows XP) and then click Recover.
The tool will repair the file and report "NTLDR and NTDETECT have been recovered successfully."
  • Remove the Spotmau PowerTools CD from the drive and click Restart to reboot the computer.
Here link of the program Spotmau PowerSuite 2010 + Serial Download
Here link of the program Spotmau PowerSuite 2010 v5.1.1.4846 Download
Please Rate Me
Nov 17, 2010 | HP Pavilion dv6000z Notebook
Hi i'm ricky. my laptop is always shutting down everytime there's a message apppeared telling that NT AUTHORITY SYSTEM TERMINATED UNEXPECTEDLY, DCOM server process launcher terminated unexpecetedly..what...
Just putthe cd windows xp to the rom drive and re-install the windows, be sure that your priority boot will be the cd rom then continue the installation and the system will repair your program.
Feb 02, 2010 | Computers & Internet
Laptop wont boot on, it starts but turns off again
I'm guessing ou have windows XP?
if so you hae a corrupted regisry and need to boot from your Windows CD and at he first et of questions choose Eneter to intall windows, then F8 to continue and then it should tell yo another Windows insatallation has been found and ask if you wish to perform an automatic repair.
Give it a try and enjoy :)
Jan 22, 2010 | HP Compaq Presario CQ50-210US Notebook
My compaq presario doesnt properly boot....the power botton lights up and it seems booting but can not continue... it automatically tries to reboot every after 25 seconds...
you must know that RAM causing improperly booting and makes your computer automatic rebooting. and can make also your windows corrupted.
Aug 11, 2009 | Compaq Presario Notebook
Shuts down before booting
Try hitting f8 before windows loading starts and select he option
"Disable automatic reboot when system fails" or something like that and you will see whats causing it
Cheers
Jun 23, 2009 | Acer Aspire One Netbook 8.9" Notebook
The computer starts then shuts down.
Try booting up the computer pressing whatever key the Dell needs to boot into BIOS (F10, Delete key, F1...pay attention to the screen) and leave the computer on for about 15min. See if it cuts off then. If it does its more than likely your power supply. If it doesn't then its not hardware related.
Mar 12, 2009 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
