Question about Carrera Go!!! Nascar Electric Race Set
I put the car on the track and put in my controller but it won't advance
    New Friend:
One car on track runs great. When I place second car on its track, it stops. I tried to interchange cars. Both cars work on inner track. Both stop on outer track.
Posted on Jan 06, 2016
I NEED A KEY CODE FOR THE BUILT IN RADIO IN A FORD FIGO 1.4 AMBIENTE 2012 MODEL
Try this, found it on another answer board.
Press and hold the Auto button. While holding the Auto button, push and hold the Track Up button. The “_ _ _ _” will disappear after about 5 sec. Enter KCAR using the remote control from a higher end CD Receiver or any Excelon CD Receiver. Enter "KCAR” with the remote controller as described below. “K”: Press TRACK UP key (>>|) after pressing 5 key twice. “C”: Press TRACK UP key (>>|) after pressing 2 key once. “A”: Press TRACK UP key (>>|) after pressing 2 key three times. “R”: Press TRACK UP key (>>|) after pressing 7 key twice. * If you commit a mistake in the code entry, the unit enters the code request mode again. Press the Track Advance button on the remote to enter the override code. The unit will enter the All Off or Standby mode if done properly. Video Unlock: Use a remote from a higher end CD Receiver or any Excelon CD Receiver. Some Video remotes will work, switch on remote must be set to AUD. Press 55222277 on the remote. There will be NO visual verification when entering the override code. Head units with a Up / Down Volume control buttons: Press and hold the Volume Up button. While holding the Volume Up button, push and hold the Disp button. The “_ _ _ _” will disappear after about 5 sec. Enter KCAR using the remote control from a higher end CD Receiver or any Excelon CD Receiver. Enter "KCAR” with the remote controller as described below. “K”: Press TRACK UP key (>>|) after pressing 5 key twice. “C”: Press TRACK UP key (>>|) after pressing 2 key once. “A”: Press TRACK UP key (>>|) after pressing 2 key three times. “R”: Press TRACK UP key (>>|) after pressing 7 key twice. * If you commit a mistake in the code entry, the unit enters the code request mode again. Press the Track Advance button on the remote to enter the override code. The unit will enter the All Off or Standby mode if done properly.
Read more: How can I get the key code for ford figo radio systems? - Radio system key code ford figo :: Ask Me Fast at http://www.askmefast.com/How_can_I_get_the_key_code_for_ford_figo_radio_systems-qna4609185.html#q2909005
Dec 09, 2015 | Ford Cars & Trucks
Left my window down in the rain and now it won't go up
It may have slid off the track from the water. If it doesn't start working once it dries out, a day or two depending on the weather, take the door panel off to make sure it is on the track properly and that the cables/wires have not corroded.
Jun 05, 2013 | 2001 Jeep Cherokee
Passenger door window not on track
There are no tracks on windows
On the verticle sides you have window guides
Inside the door is a window regulator & motor assy
that puts the glass up or down
Have to remove inner door panel to see what needs
replacing
Do not just put it back together it won't work a day
Some have cables some have a sizzor type mech
Nov 19, 2012 | 2000 Dodge Caravan
My 1997 Lincoln town car the front driver side window won't work, when I hit the button i just hear a clicking sound
the window has come of track you have to take door panel off and put it back on the gear
May 06, 2012 | 1997 Lincoln Town Car
POT AND PAN DRAWER WON'T CLOSE PROPERLY
Take out the drawer. Lift it out. Make sure nothing is in the tracks. Take everything out of the drawer. Put it back and watch the tracks. If it closes properly you've over loaded it, otherwise you have bad tracks.
Jan 23, 2012 | Whirlpool 30" Self-Cleaning Freestanding...
Driver's side window is off the track and is lodged inside the door. How do I take off the door panel and put the window back on its track?
The window regulator is broken
Windows do not go off track
Just like your back doesn't go out
You remove a couple screws around the door handle
You may have to pry up the switch panel to get to some
of them
There are plastic fasteners around the outside of the door
panel that get pryed loose
You won't like doing that job, as the professsionals
don't want to do it either
Sep 21, 2011 | 2003 Buick Century
My drivers side window won't stay on the track when I lower it. It.s NOT powered. Is there something inside that I can't see keeping me from getting this done?
are you talking about the window going crooked when lowering it if so then there is a clip that mounts to the side of the window that keeps it in the track so it won`t do this.they sometimes break and you can buy the part and install it just be careful when installing so the window won`t break.if its the track at the lower edge of the window this is a pressure/glue type fit and the track will need to be cleaned,pushed together a bit and use a window glue and install the window into the track and let it sit for a couple of hours before trying it.
Jun 30, 2011 | 1989 Oldsmobile Delta 88
CD player freezes on certain tracks. My only way to stop it is to push the advance arrow to go to the next track It seems to happen on every CD I play.
try to clean your optical lens, by a cotton badge and put some oil on moving parts. if ended you need to replace optical assembly. or try to re align potentiometer that control the focus of the lens.
Apr 10, 2010 | Philips Magnavox MCS225 17...
USB Playback order is wrong
Ive just had the same problem with my Kenwood KDC-W6041U
What has worked for me was to rename the tracks at the beginning of the file name i.e.
01-track
02-track
Not
track-01
track-02
Jul 09, 2009 | Kenwood KDC-MP438U Car CD/ MP3 Player
Kenwood ddx512
The unlock code usually only goes on if you previously put one on there. I would suggest calling Kenwood but there is a guy that claims he can fix this i have never tried this but you can. http://mike-unlockcodes.blogspot.com/
Apr 24, 2009 | Kenwood DDX-512 Car DVD Player
Carrera Go!!! Nascar Electric Race Set Logo
96 people viewed this question
Top Carrera Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Carrera Toy Expert? Answer questions, earn points and help others
