Question about Bose Wave Radio
Bose Wave and stuttering sound
1st gen awr1-1w, all capacitors were replaced and radio was working great. Came home one day and radio has no display and is making a sound I can only describe as a stuttering hum, kind of like the old non-resistor spark plugs and the impact it had on th a.m. radio except in this instance there is no other background audio, just the stuttering sound. I've rechecked all capacitors and none appear to be swollen or loose. Pressing the on-off button has no impact.
  • 6 Answers
SOURCE: Bose Wave radio humming noise
Actually the problem was caused by a bad 470uf cap, that was used to filter the powersupply for all the analog amps. Replaced the cap the unit works like new.
Posted on Apr 06, 2008
proton77
  • 1183 Answers
The tuner inside needs to be checked for problems. Contact the Bose service centre
1-800-367-4008,
Monday - Friday: 8:30 AM - 9:00 PM ET
Saturday: 9:00 AM - 5:00 PM ET
There very few people on forums that can service bose equipment,its best to get the authorised tech do the job.
Thanks
proton
Posted on Oct 03, 2008
  • 20 Answers
SOURCE: Non-working CD in Bose wave radio
Try replacing the battery on the bottom of the system - alot of people miss it because you have it constantly plugged into the mains, but replacing this (somehow) re-sets the system, and 9 times out of 10 solves the issue.
Posted on Dec 31, 2008
BillB-SA
  • 2761 Answers
SOURCE: My 10 year old Bose wave radio quit working.
There's a line fuse inside the radio, mounted on a PC board. CAUTION: disconnect the set from power before opening the case or poking around inside. The fuse could be bad, but these sets are notorious for losing the power transformer. If the fuse is ok then you are looking at a $100 repair fee from Bose. You might want to check out the new HD radios -- better sound, MUCH lower price.
Bill B.
Posted on May 19, 2009
veryverybusy
SOURCE: my 10+ year old Bose wave radio/alarm on fritz
Replace the 3 AA batteries that maintain memory & backup alarm function. That just may do the trick.
Posted on Apr 10, 2010
Capacitors to fix dim display wave radio AWR1-1W
Vacuum fluorescent display is worn out .. there is no repair. Replacement is the only cure.
Don Miller, CET
Bose Wave Radio Repair
don.miller60@outlook.com
Nov 30, 2015 | Bose Wave Radio
Buttons to change time not working
Bose Support - Owner Manuals
worldwide.bose.com/axa/en_au/...manuals/page.html
Bose CorporationFind Bose product informations for headphones, multimedia speakers, stereo ... IV ·Wave® SoundTouch music system IV · Acoustic Wave® music system II ... manualsfor home theatre systems and speakers ... manuals for stereo speakers ...‎Music systems - ‎Home theatre systems and ... - ‎Headphones - ‎Multimedia speakers
[PDF]The Bose® Wave® Radio Owner's Guide
products.bose.com/pdf/customer.../wrv3_guide.pdf
Bose CorporationThese CAUTION marks are located on the bottom of your Wave radio: ... the user to the presence of important operating and maintenance instructions in this.
Nov 01, 2015 | Bose Wave Radio
Bose Wave Radio pops, loud hum that fades
Power supply capacitors have dried out and need to be replaced.
Sep 03, 2017 | Bose Wave Radio
Hello, my wave radio works great, then goes dead, then works great, then goes dead. Radio, cd, aux....Right now it's dead.....any ideas?
It sure sounds like a power supply problem. Probably a capacitor in your main power circuit. Other parts like transistors can be intermittent with heat, but when capacitors go out, they start losing some charge and work to a varying degree. If you think it's a heat problem, you can spray some Circuit Coolant (Freon) to find the culprit. Otherwise, you will have to ohm out components to see what's going on. I would change out the biggest capacitors first. Sometimes they bulge when they go out, sometimes they don't. It could also be a cracked solder joint- look carefully with a magnifying glass. If you see one, you can resolder it. Good luck, nice radio, worth fixing.
Apr 14, 2010 | Bose Wave Radio
My 10+ year old Bose wave radio/alarm on fritz
Apr 10, 2010 | Bose Wave Radio
I have a Bose Wave radio AWRC-1g. The CD player
Yes you have a defective laser assembly. The 139 is a great price as buying the laser lens alone will cost you around 70 .Bose will also upgrade with any new software and will also provide you with a 1 yr warrenty.
Mar 21, 2010 | Bose & Wave& Music System
Bill B.
Mar 26, 2009 | Bose Wave Radio
Bose Wave clock radio has no sound.
Unfortunately, Bose will not release their schematics or parts lists, effectively giving them a monopoly on repair of their units. If you check the service/repair page on their web site, www.bose.com, you'll find that they will repair most Wave units for $100 or give you $200 credit towards a new model. Before spending the big bucks though, you might want to check out the new HD radios. Better sound and a MUCH lower price than the Bose.
Bill B.
Jan 28, 2009 | Bose Wave Radio
Bose wave no sound
Unfortunately Bose will not release their schematics or parts lists, effectively giving them a monopoly on repairs. According to their web site, www.bose.com, they will repair most Wave radios for $100 or give you $200 credit towards the purchase of a new set. Check your options before you spend the big bucks though. A new HD radio, with better sound and a MUCH lower price, might be a better choice than repair of a problem prone Bose.
Bill B.
Jan 26, 2009 | Bose Wave Radio
Cd "not playable" on Bose Wave AWrcc2
Sounds like a weak or bad optical pick-up. You could try gently cleaning it, but you'll probably have to send to Bose for repair.
May 06, 2008 | Bose Wave Radio
Bose Wave Radio Logo
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
