Question about Spy Gear Spy Video TRAKR
My spy trakr remote says no signal when turned on
When I turn my spy rcv and remote on the remote says no signal
When i turn it on it shows ...NO SIGNAL VGA INPUT ... cant get it to do anything else
if all the other inputs are working then the trx rcv IC's have gone bad in the module. you can buy a replacement module they are easy to replace contact me and i can get you one.
Apr 02, 2015 | Polaroid FLM-3201 Television
I Need a remote code
Have you checked online with manufacturer of the remote? Remote codes are usually available.
May 08, 2014 | Frisby GPX HT219B Home theater system
When im driving the trakr the left wheels suddenly stop working and go back on whats wrong
Maybe there is something jammed in between those two wheels try driving it on a different surface if still stops take it apart from the bottom and check for any dirt or pieces to be in there
Feb 12, 2011 | Wild Planet Spy Gear Radio Control Spy...
Spy 5000m remote start issues
You need to adjust the tachometer sensing wire, it usually wraps around a spark plug wire so I can sense when the car starts. On my spy alarm, the wire was grey. Hope this helps.
May 05, 2010 | Brand Remote Start/keyless/car Alarm Very...
I have a digital TV with an outside antenna and rotor.I rcv analog channels w/o any problem.I can rcv channel 19.1 on my TV and on my old TV with a converter box. I have gone to antennaweb.com to get the...
the frequency catcher of the antenna may be weaker then required.to receive the digital channels u can attach a network booster which will solve the problem.
Dec 04, 2008 | Televison & Video
Spy Gear Spy Video TRAKR Logo
44 people viewed this question
Top Spy Gear Video Cameras Experts
Are you a Spy Gear Video Camera Expert? Answer questions, earn points and help others
