Question about Epson TM-U220 Matrix Printer
TM-U220 fatal error - Epson TM-U220 Matrix Printer
Rain041304
  • 63 Answers
SOURCE: My Printer EPSON TM-U220 does not print....HELP!!!!!
Change port to Printer port Lpt1 not the esdprt. then uncheck enable bidirectional support/ Restart computer and then try to do a windows test page
Posted on Feb 12, 2008
  • 10 Answers
SOURCE: Epson TM-U220 Matrix Printer not printing in WinXPP
hi basiime
possible issue is port configuration. if the generic text driver works, apd driver should work too.
what may be happen is that when you install the apd driver the other printer drivers that you have were still using the same port that your apd driver were using. example, you have generic txt assigned to lpt1 and then the apd were assigned on the same port, this is were you get the trouble.
what you must do is, first, check any printer driver that you have using the lpt, say for example, you generic text is using lpt1, when you install the apd driver set it to lpt2. apd drivers will create a new port normally called esdprt. try to use that port but if that will not work reassigned the port of your apd driver to lpt2 printer port then uncheck bi-directional support. from there you should be able to print..
hope that resolves your issue.. =)
Posted on Feb 24, 2008
SOURCE: Problem setting up TM-U220
print the self-test, push the feed botton while powering on...
you can see there the serial interface...
baud rate, data bits, parity, stop bit etc...
then go to the printer and faxes,
right click the epson driver and click properties...
go to the ports window...
click on the epson tm u220 reciept.
click configure port...
adjust the baud rate as same as in the self test...
it works...
Posted on Sep 10, 2008
acdr
  • 1913 Answers
SOURCE: i m unable to install the epson tm-u220 printer in windows 2003
http://www.barcodesinc.com/epson/tm-u220-drivers.htm
download driver and install from here
Posted on Jan 24, 2009
c-hom
  • 150 Answers
SOURCE: Epson TM-U220 Receipt Printer M188D Drivers
The driver for Epson printer has been
Warm regards,
Anirban Mazumdar
Posted on Oct 08, 2009
PRINTER TM U220 on a Mac
Epson website should have them available to download
Jul 24, 2012 | Epson TM-U220 Matrix Printer
Epson TM-U220 hard reset
When a USB interface change interface idn flashing error red light
May 23, 2012 | Epson TM-U220 Matrix Label Printer
Tm u220pd detected tm-p2.01 how to be default
Hi!
You can set the TM-U220 as your default printer by following the steps below:
For XP OS
-Go to Control Panel and click on Printers and Faxes -Right click on TM-U220 printer driver icon and on drop-down select Use as Default.
Hope this helps. Cheers!
Jan 05, 2011 | Epson TM U200PD Matrix Printer
Epson TM-U220 not working with window 7
download this driver APD-406aE i did it and it is working perfect with my windows 7 on a TM-U 220B
Jul 07, 2010 | Epson TM-U220 Matrix Printer
Auto cutter does not cut automatically
TM 220a and TM 220b should come with auto cutters
You have to unscrew the metal tab under the printer, you will find two sets of DIP switches. upper one is DWS 1 and the lower one is DWS 2. On DWS 2 you need to have jumper #2 ON. this enables or activates the auto cutter on printers. Good luck...
Jun 08, 2009 | Epson TM-U220 Matrix Printer
Epsom TM-U220 Error Codes
From the manual its probably one of this item.
-printer temp is too high
-cover is not properly closed
-print head is not in the correct position
-paper cutter is not in the correct position
-paper jam
Try turning off the printer, remove the power cable, turn it on again for 5 seconds to reset it. Connect back power cable, press the feed button and turn it back on. The printer should do a self test, turn it off and on again after the self test. It should make the red light go away.
Oct 27, 2008 | Epson TM-U220 Matrix Printer
Can u give a download driver for pos printer
Oct 03, 2008 | Epson TM-U220 Matrix Printer
Epson tm u220
What type of interface card are you using to connect printer to your computer?
Mar 14, 2008 | Epson TM-U220 Matrix Printer
Epson TM-U220 Matrix Printer Logo
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
