Question about Garmin Astro 220 GPS
Power button defective - Garmin Astro 220 GPS
Why is the power button not working?
Could be the switch is defect, or the power supply is defect, or the power cable is not good connected. The mains is dead or some other defect in the TV is keeping it from starting, just to name a few possibilities. Please consult a tech when you are sure the TV does get power.
Mar 23, 2015 | Haier 42" LCD 1080p 60Hz
Why the power button stop working?
Are you sure the battery is charged? if so, still switches and buttons can become defect. If your power button has a history of acting slow or strange lately, it could be it is defect. If to there is a chance only the battery is not charged. Please check if anything lights up when the charger is connected.
Jul 13, 2014 | Tablets & eReaders
Yellow blinking light on power button
A steady or Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Apr 15, 2014 | Dell Studio XPS Desktop Computer
Start button does not light
please follow this steps and fix it. GOD BLESS YOU
1. No power to the dishwasher
Make sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced.
2. Door switch
Replace if defective.
3. Timer or Electronic control
Replace if defective (note: uncommon problem).
4. Selector switch
Read more: http://www.appliancepartspros.com/repair-help/dishwasher-repair-help.html#ixzz2aaj83j00
Jul 30, 2013 | Jenn-Air 24 in. JDB1250 Built-in...
Sony Trinitron KV-27V10, power supply getting power to first relay, power button has continuity, how do I get power to power button ?
first check for power supply operation..maybe a defective horizontal stage might caused this type of defects
Jul 15, 2011 | Sony KV-27V10 27" TV
Acer 6930 ! power on button flashing orange and will not turn on. Why is this ?
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
4. The power button could be bad.
5. The motherboard could be defective & needs to be replaced.
Sep 08, 2010 | Acer Computers & Internet
Gateway 831gm - press power on, power is there but will not stay
If the power button is not defective in/out, it means yuo have a defective power supply.
Thanks
Jul 30, 2010 | Gateway Computers & Internet
Do not start when start button is pressed. Seems power adapter K30266 is defective. Output should be 24V, but I get only 7.2V.
power adapter is definitely defective if it only has 7.2 volts on it output. check if you have plugged it in the correct voltage!
May 21, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Broken plastic power button
Broken plastic power button? This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:service@wisiny.com.thanks,we sincerely hope we can help you!
you can also check this boards whether suit you:
1742SED2H 715G1492 2 FR Dell ADTV1742SED2H Power Supply Backlight Inverter...
Apr 29, 2009 | Dell E177FP LCD Monitor
No Picture, No Sound While Watching
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
LCD TV TroubleshootingThe defective LCD TV may have the following common symptoms:
Symptom: No picture on screen but LCD TV still has sound.
Solutions: The problem is cause by defective inverter. Replacing ivnerter will solve hte problem. Symptom: Screen flash on and off between 1/2 to a few seconds, but power indicate light stays on and TV still has sound.
Solutions: The problem is cause by defective inverter. Symptom: Blue Screen but no picture
Solutions: The problem is cause by defective Main Board(AD Board). In some cases, this problem may cause by the defective Screen Controller board. Thsi board is mounting on teh back of LCD TV Scree. Symptom: Power light stays on but no display and sound
Solutions: The problem is cause by defective Main Board(AD Board) or Power supply board. Symptom: No Power or Power indicate light does not lits
Solutions: The problem could cause either by defective Power supply board or defective Main Board(AD Board). Symptom: Screen is half dim and half bright
Solutions: The problem is cause by defective LCD Panel.It needs to be replace.
Hope it may help you;
Regards;
VOTIT
Jan 29, 2009 | RCA L37WD250 37 in. LCD HDTV
Garmin Astro 220 GPS Logo
23 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
