Question about GE Dryers
Dryer suddenly shrinking clothes
I always use cold water to wash my clothes. Lately though, my GE dryer has been shrinking everything! I really have been doing the same routine for many years but in the last month my family has been complaining (and rightly so) that I'm shrinking their sweatshirts and t-shirts dramatically! I dry it on Low, but I do take it to Optimum dry. I've always done this without a problem until the last month. Any ideas??
  • GE Master
  • 16,037 Answers
The machine has two issues that could cause this:
1. As heating elements age, they got hotter before they burn out.
2. There is a thermostat on the heater element enclosure that controls the heat, this might be going bad.
If you open the panel to see the heating element, there should be a tech sheet in the machine that has temps listed for different settings.
While you are in there, you need to clean it out. It probably has a lot of lint in the machine and this can cause a fire hazard.
The way that you test it is to put a load of damp clothes in the machine and set it and then take the temp at the outlet. You need to use a meat thermometer to check the output temp. Use the chart on the tech sheet to tell if the thermostat is working right. Also it goes without saying that you should unplug the machine for most of this.
Posted on Feb 17, 2014
revamos
  • 16 Answers
SOURCE: GE Profile Electric dryer - not heat, damp clothes but tumbler works
first checkyour breaker it may not look like it is tripped but cut it off and on or maybe the thermo fuse or you element is bad you have to check proper voltage to parts
Posted on Apr 20, 2008
SOURCE: GE Dryer smells like its burning
the burning smell may be caused by a belt some have a look at the belt
Posted on Mar 07, 2009
  • 532 Answers
SOURCE: dryer is not drying clothes.
well im not going to look up the model # to see if its gas or electric,but check the exhaust tube for blockages
Posted on Apr 22, 2009
pumpkinman
  • 1144 Answers
SOURCE: Ge Dryer making loud rumbling noise
drum bearings are going up
Posted on Jun 19, 2009
milten1
  • 1304 Answers
SOURCE: GE Profile dryer - automatic dry never stops
ok go back to that page and
look in the
backsplash, blower section
you are looking for part
230
Posted on Oct 15, 2009
Testimonial: "Fast and Courteous Feedback!!! Thanks again!!"
Why do my front load ge washer leave lint on the clothes?
A lot of build up from front loaders is caused from "scrud" excess detergent or constant cold water use. Place a cup full of Epson Salts in the machine and run through a hot wash cycle every 4 weeks or so and this will help keep bowl clean.
Dec 03, 2014 | GE Washing Machines
Why does my machine shrink clothes on 40 degree wash
Some tissues are more sensitive to shrinking than others.
Some clothing cannot be machine washed or only at very low temperatures (hand warm).
Especially woolen fabric will shrink even at 40 degrees.
Be carefull with spinning at high RPM's.
Always consult the label in the clothing:
Jun 03, 2014 | Miele Novotronic Premier 500 Front Load...
I have a GE dryer that won't dry our clothes. It heats up, but water is all over the inside door and the lint that comes out of the hose in the back is wet! The outside of the dryer (the top in...
It really sounds like your washing machine is not spinning the clothes out enough. Have they been wetter than usual lately? The dryer could just be struggling to keep up with the heavier / wetter load as there is no reason for it to create moisture on it's own.
Oct 06, 2010 | GE Dryers
Washer temp setting changes by itself
I also have a Whirlpool washer/dryer for my condo, although I don't know the model number of mine. I had the same problem -- after it was precisely a year old, suddenly one day the hot and cold started coming out reversed. I was able to fix mine by more or less temporarily fiddling with the water pressure. What I did was one time, when the rinse cycle was running and the washer was filling up with hot water (grrrr...), I completely shut off the valve supplying hot water. So at that point the water stopped filling into the washer, and then I started tinkering with the cold water, twisting the valve off and on a few times. Then BINGO, suddenly the cold water "kicked in" and for the remainder of the rinse cycle, it filled the washer with cold water. I then turned the hot water valve back on, and since then it has been running correctly.
Jun 05, 2010 | Whirlpool Washing Machines
My Zanussi FJ 1254W has suddenly started leaving lots of undissolved powder in the clothes after washing. I've checked that the filter is clean, and used Calgon though a couple of washes, but it hasn't...
Try filling it up with HOT water and vinegar use about 2 cups for a full load. Also take the hot and cold water hoses off the washer and check the screens for little sand like rocks that can block the water flow. I always use liquid and not the powder. Another thing is not to put the clothes in first. After you try the other things first then try to add the water first with the powder and then put the clothes in. Don't over load the clothes. This can cause the powder not to dissolve either. Hope this helps.
Dec 06, 2009 | Zanussi FJ1254W Front Load Washer
Washer is using hot water on the cold/cold was
Unless your hoses are reversed the machine control is bad and needs to be replaced. Please contact me if you need further help or leave feedback if appropriate as that is how I get paid. Thanks for letting me help you!
Nov 30, 2008 | Kenmore Elite 45986 Front Load Washer
Clothes wont dry but gets really hot
make sure your exhaust line is clear and not kinked
Oct 24, 2008 | Washing Machines
The clothes in the washer dryer at the end of the wash are really hot and therefore start to shrink the dryer button is not on and the wash is on a 30 degree heat can you help?
If you have washer set for a warm rinse and the cold water inlet screen is restricted you will get too much hot water. Another thing I have seen is if another near by faucet has a sprayer on it and the sprayer is off, but the hot and cold valves supplying the sprayer are on, the hot water can feed back through that faucet and give you an increased rinse water temp in your washer. Also, make sure hot and cold hoses are attached to the proper side of the inlet valve.
Sep 02, 2008 | Whirlpool Washing Machines
Grease spots on clothes
That could mean your overloading your dryer to the point the wheel bearings are squished really bad. When loading your washing machine you should always be able to see the water level more than the clothes, your clothes should be floating in the water. That way, when you unload your washing machine and go to dry, you will have the right amount of clothes everytime
J
Jun 29, 2008 | Whirlpool LER5636P Electric Dryer
Frigidaire Front Load Washer Shrinking clothes
check to make sure you water line arnt hooked up backwards. if hot is to cold and cold to hot your washing in hot water when your trying to use cold
Nov 20, 2007 | Frigidaire 14 Cycle Tumble Action Washer
Dryers Logo
79 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
