Question about Samsung Computers & Internet
Samsung k7907g change monitor input
No vga input on working monitor
Turned on computer (Pavilion a1657c), HD light operates, Monitor has little window saying:
HDMI Input: No Input Signal
VGA Input: No Input Signal
Recommended Settings: 1920x1080 - 60hz
Changed from the monitor that came with it (HP f2105 digital ouyput) to my Samsung analog and same message comes on dark screen.
Hope It's resolve all Your Computer Problem,
Or
Still having Problem Then follow Us For Computer Support
Mar 21, 2014 | HP Media Center m7657c home PC - RC640AAR...
I have a Samsung 940bw monitor. After pressing the auto button, it does not work anymore. Is there a problem about monitor or is it broken? I am waiting for your help. Thanks.
Hello
damnor01 here to the rescue!
Welcome to Fixya.
Since you pushed the Auto button it is possible that the monitor has changed the input type to a type other than that you are currently using.
For instance it may have chosen to accept VGA input however you have the DVI or HDMI connected.
To fix this you will have to push the auto button again, and possibly again to get it to find your current input channel.
You may need to turn your computer off and then back on again.
You may need to connect your monitor using a different connector, example via VGA, DVI or HDMI. It all depends on the connection you have at present.
Blue Connector is VGA.
White connector is DVI.
HDMI is very narrow conector usually black.
Please be sure to rate this session!
Thanking you
damnor01
Mar 18, 2011 | Samsung Syncmaster 940BW LCD Monitor
Samsung Monitor 192N light turns green when powered on then goes out after few seconds
this usually means the monitor is not getting a signal
  • i would check the hdmi/dvi/vga cable connections dirk_s.jpg
    both on the back of the pc and on the back of the monitor.
  • if the connections are tight, and plugged in well, maybe try and connect it to a second computer or laptop.
    • If it works the problem probably lies with your gfx card in your computer (verify this by trying another monitor on it)
  • If it doesn't work on those i would try and replace the aforementioned cable (usually pretty cheap)
  • if the problem still persists the monitor would probably need to be replaced as its defective.
Feb 28, 2011 | Samsung Syncmaster 192N 19" LCD Monitor
I noticed that my monitor has an additional port to connect another monitor to but for some reason its not recognizing the monitor
Is that a port for an additional monitor or is it simply an alternative method of connecting the monitor to the PC. My monitor has a vga input along with a dvi input and a hdmi input. These are all inputs not outputs.. Unless the port is specifically labeled as an additional monitor output, the chances are its an input.. You may have to use proprietry software to make any additional outputs available.. if the monitor is a Samsung, go to the samsung website and search for the monitor model. or read the manual..
Nov 02, 2009 | Sony DELUXEPRO SDM-X82 18.1" LCD Monitor
Bought Samsung 2233BW Monitor, hooked the two plugs, power and DV1 cord started computer and switched on monitor, NOTHING HAPPENED. Silly thing just unhooked Samsung and hooked back up the AOC monitor no...
You might need to go into the monitor's setup menu and select the digital input. (That's DVI, by the way, for Digital Video Input, and not DV1.) Some monitors automatically detect the input but not all of them. Obviously, this doesn't apply if the Samsung has only a DVI input. It might also be necessary to tell the video card to turn on the DVI output. You can do this with your old AOC connected and use the video setting utility supplied with the video card.
May 22, 2009 | Computers & Internet
Acer Picture in Picture Problems - Can't Change it off VGA
yes your keypad is locked to open it you press all keys on monitor simultaneusly for 5 seconds window wll show massage keypad unlocked then release window will dissapear
Oct 29, 2008 | Samsung SyncMaster 940MG 19" LCD Monitor
Samsung 931B SyncmMaster
DO YOU MEAN WONT SWITCH FROM ANALOG TO DIGITAL!!!
THE ONLY WAY THIS WILL CHANGE IS IF YOU HAVE A DIGITAL INPUT SOURCE CONNECTED to this mointor like HDMI AS THIS MOINTOR AUTOMATICALLY SENSES ANALOG SIGNALS AND DIGITAL INPUT SIGNALS if a digital signal is available it will switch over if a digital input singal is not available you will only be able to use the analog option
Jan 11, 2008 | Samsung SyncMaster 930B 19" LCD Flat Panel...
Computers & Internet Logo
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
