Question about Panasonic TC-P54S1 54 in. Plasma HDTV
Tc-P54S1 6 blinks - Panasonic TC-P54S1 54 in. Plasma HDTV
I have a Panasonic TC-P65ST50 which recently began shutting down and displaying 7 blinking lights and 8 blinking lights. Most of the time 7 blinking lights are displayed.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
Feb 25, 2016 | Panasonic TC P65ST50 - 65" Class 64.7"...
Panasonic Plasma TC-P42C1 10 light blink code, then the light came on and then no light at all-nothing! Power Suppy board?
By blinking led its shows where is exactly the complaint. You have to count the blinking. How much time its blinks in one sequence. the only it will be possible to say is it power supply or any other boards.
www.electro-medical.blogspot.com
Sep 03, 2015 | Panasonic Televison & Video
I have a panasonic viera TC-50S1 i turned it on yhe picture was messed up .. it shut off and will not turn back on the red light keeps blinking one time
Assuming you meant TC-P50S1, as TC-50S1 is not a valid model, 1 blink code means suspect bad A board (main board). Below is a link to the parts list for that TV model.
http://www.tristatemodule.com/t-Search.aspx?q=TC-P50S1
Nov 03, 2013 | Televison & Video
Tc-p46g15 not power seven blinks pause seven blinks again
7 blinks something went kaput in your y-sus board
one or more transistors
easy fix cost about 14$ to 30$ with transistors but the heck is you have to take out most of them cause they are in parallel to find wich one is shorted......hope this help
Oct 19, 2013 | Panasonic TC-P46G15 Plasma TV
Tc-p50g20 4 blinks
My panasonic TC-P50G20 does not power on, just I have 4 blinks on my powericon1.png indicator light. What error does that mean?
Jul 24, 2013 | Panasonic Tc-p50g20 Viera G20 Series 50"...
My TV just turned off and the power light flashes 8 times. what is the flash code for 8 times on a panasonic TC-50PS14
thought I would post this here for everyone.
1 blink STV 5v sense DG Board
2 blinks 15v SOS D Board
3 blinks 3.3v SOS D Board
4 blinks Power SOS P Board
5 blinks 5v SOS D Board
6 blinks Driver SOS 1 SU / SD / SC Boards
(SC energy recovery circuit)
7 blinks Driver SOS 2 SU / SD / SS Boards
(SC floating voltage area)
8 blinks Driver SOS 3 SS Board
(SS energy recovery circuit)
9 blinks Panel Config. SOS
10 blinks Sub 5v SOS / Main 3v SOS DG Board
DTV 9v SOS / Tuner Power SOS
11 blinks Fan SOS PB Board
12 blinks Sound SOS H Board
13 blinks Communication error DG Board
with IC8001 (Pesks Lite 2)
May 14, 2010 | Panasonic Televison & Video
Panasonic TC-P54S1 54 in. Plasma HDTV Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
