Question about Zareba Sp3 Solar Power Fencer
Discharge problem Red light not blinking. No power output
Blinking red power light on a Panasonic Viera 47 in. plasma
No sure how many blinks you have but here are the blink error codes and the common boards failures for each
Blinking Times Contents Check point
1 Panel SOSPanel
3 P+ 3.3V SOS A-Board
4 Power SOS P-Board
5 P+ 5V SOS A-Board
6 Driver SOS1SN-Board
7 Driver SOS2SN-Board
8 Driver SOS3SS-Board
9 Discharge Control A-Board
10 Sub 5V SOSA-Board
SN-Board
SS-Board
P-Board
12 Sound SOS A-Board
Speaker
13 Emergency SOS A-Board
Feb 01, 2014 | Panasonic VIERA TH-42PX60U 42 in. Plasma...
Mhc-rg222 red light blinks power button wont turn on unit
Check the back of the unit for speaker wire shorts, if everything looks fine suspect the output ic's in the stereo.
May 26, 2012 | Sony MHC-RG222 CD Shelf System
Samsung TX-P3075WH blinking red light
Hello
Check its LOT [Line Output Transformer]. Replace it along with Line Output Transistor.
Apr 07, 2012 | Samsung TX-P3075WH 30" TV
Airconditioner works only in fan mode...when picking heat i get an EE blinking signal and power light turns to red....
EE means high discharge pressure.If new unit or recently re charged gas unit, it's over charged. Other wise, it has non condensable gas. Remove all gas and replace filter direr flush out system re charge gas. Helpful.
Before doing above, clean condenser coil and check. Some times due to condenser block also discharge pressure will raise.
Jan 04, 2011 | Heating & Cooling
My TV will power on but no sound or picture. The red light blinks multiple times
If the red light blinks then the tv doesn't power n - it blinks to signal the fact that the power source is in protected mode because there's a big short on one f it's outputs.
The tv must be opened and the shorted part identified by someone who knows what it must do , and how to do it safely. If you're not such a person then call a repairman.
Oct 02, 2010 | Panasonic Televison & Video
SONY KP-61V90 tv will not power on, red light in front,
Its 2 times blink error code that shows +B volt supply (+135 volts) is shorted, most probably horizontal output transistor is shorted, replace it.
If you are good in soldering parts in circuit board then take out horizontal transistor, check it, found shorted then replace it with same number.
Horizontal output Transistor Q502 number is 2SD2578 and available in Part Store for $10
Let me know for further query, if any.
Thanks.
Nov 18, 2009 | Sony Televison & Video
Red light blinking, tv doesn't start
Your TV is in Protection Mode right now. A part inside the TV has failed and the TV will not turn ON to prevent other parts from being damaged. The red light blinking is an error code for diagnosing the problem part on the one of the power supply boards. The problem boards that need to be looked at is the Backlight Inverter Board or the Main Power Supply Board.
There is a slim chance you can leave the TV unplugged for an hour so the TV can discharge and reset itself. But other than that, I would use the warranty if possible. The TV repair shop maybe expensive, so get some price quotes to see if it worth the trouble.
Sep 09, 2009 | Philips 50PF9631D 50 in. HD-Ready Plasma...
My 605 turns off and red light blinks when volume goes past 58
Shorted speakers can cause the unit going on protection mode (the red light blinking) when a certain volume is reached.
Test with a set of replacement speakers.
If it is not the speakers, it is probably transistors in the amp final or something nearby. Test also input output board.
Apr 27, 2009 | Onkyo TX-SR605 Receiver
Blinking Green power light
Unplug the power cable and press and hold the power button for several seconds to discharge the system. Then allow several minutes before reconnecting the power cable. If the problem still persists, it may be a failed power supply.
Nov 20, 2008 | Computers & Internet
Red blinking power light
Check horiz output xistor,check all electrolytic capacitors in
power supply,esp. those numbered in the 900's.For instance,
C923 ? may be swollen on top(pooched)  1000mf/35v......
Let me know.......T.
Oct 29, 2007 | JVC AV-20920 20" TV
Zareba Sp3 Solar Power Fencer Logo
430 people viewed this question
Top Zareba Renewable Energy Experts
Marco De La Fuente...
Brian Lee
Kelly C
Kelly C
Level 1 Expert
Are you a Zareba Renewable Energy Expert? Answer questions, earn points and help others
