Question about Kenwood Excelon KDC-X596
KdC-X596 quit working - Kenwood Excelon KDC-X596
I have a kenwood kdc bt43u and transferred it, with my amp and rear speakers, to an identical vehicle. It all works fine until i use bluetooth. sound only comes from the front factory fitted speakers
Not quite sure what you are saying here but I am going to take a stab. If I am filling in the gaps but are the rear speakers wireless? If this is the case then they are not paired with the speakers but with your receiver deck. You will need to pair the speakers as well before it will play through them.
Dec 21, 2014 | Kenwood Car Audio & Video
Kenwood kdc-x811 faceplate quit responding.
Call Kenwood they can give you a code to enter by using the remote
Mar 22, 2014 | Kenwood KDC-716S CD Player
Have a kdc-x596, just installed and in the seek mode for AM does not pick up any stations. Locks on to FM fine. What gives?
Sounds like you didn't have the BLUE power antenna wire hooked up. Pull out the radio to confirm. The BLUE wire (from aftermarket radio) will turn on an antenna booster if there is one in the car. What car is this in?
Dec 23, 2012 | Kenwood Excelon KDC-X596
On the back of my kdc 135 their is 2 wire that are blue. one without a white strip that says antenna cont. and another that is jus solid blue but i dnt quite remember wat it says, which do i hook my rem...
The antenna wire is used for the antenna and trigger wire for an after market amplifier (blue w/white tracer) It sends power out to power the accessories. I'm not quite sure what you mean by "rem cable" but I hope I've offered enough information for you to make a determination.
If so, please rate my assistance and leave a testimonial.
Dec 28, 2010 | Kenwood KDC-135 CD Player
Quit working, but still says "Protect" What's up?
when it says protected one of the speaker or speaker wire is grounding out (touching the metal) one way to find out wich speaker is to working bad is to disconnect the speaker behind the radio one by one and whene you disconecct the bad one the rest will work next replace the bad speaker and it should work fine
Jun 28, 2010 | Kenwood KDC-MP205 CD Player
Car cd player ..................no sound
check shorted speakers or they are getting old and need replacing
Apr 22, 2010 | Kenwood KDC-MP5032 - Car Audio CD MP3...
Kenwood KDC-MP428 - the display is out but works otherwise
there are several surface mount resistors on the right side inside of the deck that need to be resoldered.
Jan 07, 2010 | Kenwood KDC-X590 CD Player
I have a Kenwood KDC MP532U. The face plate will not display.
it more than likely has bad solder connections inside the radio on some surface mount resistors usually located on the right front of the radio as it faces you.
Sep 16, 2009 | Car Audio & Video
Protect mode
my stereo kenwood kdc-mp2032 is in protect mode, í lost my manual, and i don´t know how quit this mode. can yuo help me?
Jun 19, 2008 | Kenwood KDC-MP2032 CD Player
Door Opens then closes and Powers Off
Try holding down BUTTON [5], then press the RESET button (you'll need a ballpen between the AUTO and SCRL buttons). This worked on the KDC-MP825 (very similar to the MPV8025) when my wife had the same problem this month.
May 21, 2007 | Kenwood KDC-MPV8025 CD Player
Kenwood Excelon KDC-X596 Logo
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
