Question about Garden
Snow Blower dying out after running?
Bought it in January 2011 worked well until this time. Will run on choke but when I slide the lever to run will die out as if fuel or air is being cut off? I opened, took and cleaned carburetor apart and seems to be still relatively new. Tried adjusting the idle screw but very sensitive will back-fire if opened wide and just runs on choke but again will die out after a while. Is it a good idea just to buy the whole carburetor assembly and replacing it or do I need to open the filter for possible clogging causing to be cut off after awhile? Please advise, I bought one in 2003 and never gave me this problem before, looks like the part is made in China and of poor quality, please advise I am about to write the Better Business Bureau about this, for the price I paid should have gotten another brand instead.
3 Suggested Answers
rycgl
  • 1545 Answers
SOURCE: Starts with choke but will not run when choke is
I've noticed the Echos are cold-blooded and a decent warm-up time is required. You indicate the fuel mixture has to be somewhat rich to keep the engine running. This indicates the needle jets need tweaking to acquire the proper mix (if applicable) or else the fuel pump diaghram is not functioning properly and needs replacement according to the symptoms.
Here is a link to the site that has the G&D (gasket and diaghram) kit and RB (rebuild) kit part numbers for you. You will need to know your machine's model. Link to determine your carb: http://www.zamacarb.com/pdfs/APPL_CR2010.pdf
This is the link to determine the part numbers of the kits. Zama has a great site and informative links:
http://www.zamacarb.com/pdfs/QuickKit_CR2010.pdf
Please vote on this solution.
Posted on Sep 12, 2010
lttljiggs651
  • 7 Answers
SOURCE: husqvarna 223l runs wide open on choke, but dies when choke is off
it may be the idle jet is plugged there is a needle and seet on most of them. have you tried half choke sometimes the will clear on their own
Posted on May 01, 2012
I have a 26 in craftsman snow thrower brand new engine runs erratically hunting
The choke does not have to be all the way open on a snow blower engine. The choke control has notches or steps for that reason. With the engine running adjust the choke one notch at a time until it smooths out. Once the engine warms up you may have to adjust the choke a notch or two to keep it running smoothly.
Mar 11, 2017 | Craftsman Garden
Yardworks snow blower only runs smooth on half choke whats wrong with it
Is there a screw on the carb to adjust the air. If there is turn it out a little bit at a time till it runs right.. If that does not work your carb may be dirty.
Sep 27, 2016 | Garden
I have a 5/24 mtd 2 stage sniw blower.it runs with a little choke on and augers spinning. But when i hit snow it dies out
if you can only get it to run in choke , then you have some problem that is keeping the proper amount of fuel flowing , id say most likely inside the carb pathways , Ive had great luck cleaning out carbs with some automotive fuel carb/injector cleaner added right to the fuel tank and let it run (even in choke ) after it heats up the cleaning will begin
Nov 22, 2015 | Garden
I have an older craftsman snow blower 10 hp. It starts ok with full choke, runs ok half choke, backfires with no choke-run position.
It's too lean; not enough fuel mixed with the air. Look for the main mixture screw--it should be a large screw with a spring under it on the carburetor. Run the engine until it's warm.
With the engine running, turn the screw outward (lefty-loosey) about 1/8 turn slowly and see if it improves. Slowly turn the screw back and forth until it runs best with the choke completely off. Then set it 1/8 turn richer (turn screw outward 1/8 turn) than the best position.
Reason for doing this: Conditions change, even the barometric pressure. Small engines run okay if they are a little rich but not if they are a little lean.
Mar 03, 2015 | Garden
What are the starting instructions for an Ariens snow blower, 10000 series, Model # H5065226H
Your carb may need cleaned but you can try using starting fluid to get it going it may just need help from sitting if starting fluid doesn't work carb is probably gummed up
Nov 22, 2014 | Ariens Garden
Managemylife com sears
A complete replacement carburetor will just buy you another set of parts identical to the ones you already have. Nothing is worn out.
You should be able to clean the carburetor inside with SPRAY carburetor & fuel injector cleaner, after opening it up. Spray the cleaner through the jet and every passage you can find. Be careful about your eyes - some passages lead back toward your face, and carburetor cleaner is NO good for your eyes!
When it's clean, examine it to be absolutely sure everything's assembled correctly, especially the float valve ("needle and seat"). Put it back together and reinstall it on the engine.
Put a little FRESH gasoline (NEVER use old gasoline in an engine!) in the tank.
Now take off the fuel line (from the carburetor) and make sure fuel drains from it freely. Put it back on immediately and loosen the bowl. Fuel should also drain from the bowl freely.
Last, doublecheck your idle mix adjustment screw. If you toyed with it, you have to get it adjusted correctly again - a good starting point is SNUG (never TIGHT), then back it out counterclockwise about 1-1/2 turns. Once you get the engine started and running without the choke, it (the screw) should be adjusted until it's very slightly rich (counterclockwise) from the point where idle speed drops if you turn it clockwise any further. Said another way... get it idling without the choke, then turn that screw in (clockwise) 1/4-turn at a time until you can hear the idle speed drop. At that point, back it out (counterclockwise) about 1/4 turn.
If you CAN'T get it to idle without the choke, then just try backing out (counterclockwise) that screw 1/4-turn at a time. Each 1/4-turn should make it run just a little richer, necessitating less choke.
Feb 17, 2014 | Craftsman Arnold Mtd Snow Thrower Blower...
MTD SNOW BLOWER WON'T RUN WITHOUT CHOKE ON
If it will only run on full choke you have an air leak somewhere
Jan 21, 2013 | Garden
I have a Yard Machine 5.5hp 2-stage snow blower. I bought it used but I think it is a lightly used 2004+-. I use the primer bulb and it will start within 2 pulls, runs beautifully. I slowly open the...
The running time seems to indicate a plugged fuel tank vent. Try opening the cap to see if that will allow continued running. Many engines have the vent within the cap itself, while others vent from the air cleaner through a line. Ignore the fuel drip on the adjustment screw. Hope this helps!
Dec 27, 2010 | Garden
Snow blower won't stay running
ok heres what you do to get your snow blower to keep running.
while you have it choked, and you get it to the running point, turn the cup bowl ajustment in/out a fraction at a time while you move the chock off slowly till you get the right setting to keep it running then ajust the setting once more to clear it up to purrr like a kitten again the vibration moves the screw out to set everything out of wack......
Feb 09, 2010 | Craftsman 16" High Garden Tractor Snow and...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
