Maytag quiet series 100
The machine won't spin properly, leaving items sopping wet. I ran unit with door open and it seemed that it was trying to agitate as well as spin. Is it the timer
  • 1 more comment
  • Brad Brown Feb 17, 2014
    Hi Eric Hamersma, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box? Whole model number??
  • Eric Hamersma
    Eric Hamersma Feb 18, 2014
    It's a maytag quiet series. Model number mav4755aww . Thanks!
  • Eric Hamersma
    Quiet series 100
  • Washing Mach... Master
  • 15,557 Answers
Drain it all the way and lay it down so that you can see the drive pulleys and belt, inspect for wear and debris. Clean and if needed replace
Posted on Feb 18, 2014
Testimonial: "I replaced the belt ane the thrust bearing. It's running quietly now and seems be working great!"
  • Brad Brown Feb 20, 2014
    Good for you!
aborcass
  • 2651 Answers
SOURCE: spin cycle
the machine has sensors within it that detect off balance loads, very possible that the 1 or 2 items are not enough to correctly balance themselves, so the machine will never achieve full speed spin.
Posted on Nov 23, 2008
  • 212 Answers
SOURCE: Washer sometimes leaves clothes sopping wet - then the next day O
you can remove the bottom access panel to get to the drain pump. there might be something in the coin trap.
Posted on Jun 24, 2009
jsrock516
  • 5911 Answers
SOURCE: Could you please tell me how to remove the agitator for cleaning
The agitator on a Maytag Performa comes off by removing the center post cap and dispenser by pulling on it. Locate the agitator bolt and loosen (you may need to hold the agitator in place while loosening). With the bolt removed, the agitator will lift off.
If you still have questions, please let me know. I hope this helps you.
Posted on Sep 16, 2009
  • 3 Answers
SOURCE: Kenmore 41748102701 Front Load Washer - no spin
replace the door switch mech it is a common problem with front load kenmore washers. cost under 100 for the part
Posted on May 04, 2010
SOURCE: Maytag epic z-ripped piece of door seal
I have the same problem with mine except the rubber piece that is ripped is still attached. The rip is about 3/4". How do we replace the rubber seal? is there a specific part number I need to look for? Sounds like this might be a common problem... I wonder how many others have this same issue. I havent even washed anthing as heavy as a rug. I only wash cotton. The door itself has a spot on it that seems like it may have helped cause the tear.
Posted on Jul 07, 2010
My machine doesn't rinse and drain properly, sometimes the clothes are sopping wet
Maybe you just need to change the motor brushes. YouTube has some great videos. Spares here on Fixya. Did you check out your filter?
Click if helped.
Mar 12, 2013 | Bosch Nexxt 100 Series WFMC1001UC Front...
The latch is sticking on my dishwasher. How can I
replace the door latch and the handle check to see if the console loops that hold the latch are broken if so replace the console
Jun 02, 2010 | Maytag 24 in. MDB9750AW Dishwasher
Maytag bravo quiet series 300: Stopped at spin:
We have a Maytag Bravo Quiet Series 300 washing machine, the door latch is broken. I have the replacement part ( the locking mechanism) but I need can not figure out how to get the top of the washer to flip up to give me access to top front of the machine to remove the old part and replace it with the new.
How do I flip back the top (not the door) of this machine?
John
Jan 15, 2010 | Maytag Washing Machines
Have a quiet pak4 kenmore elite. the spin cycle seems to not wring out the clothes well. In some cases, the items are dripping wet. I tried running an empty cycle, (rinse and spin setting), and it seem to...
Try this: remove the front lower acces panel(below the door going acroos the lower portion of the washer)
by removeing the attaching screws and pull off, then inside you will see a cylinder shaped unit with a cap with a twist handle on it,this is the filter pump, unscrew the cap to remove the trap and clean out completely, there will be some water in it when you open it so have a towel ready to sop up the water,reassemble everything and try a load of clothes, this will fix your problem. Good luck !
Jan 12, 2010 | Kenmore Elite 45986 Front Load Washer
Jun 24, 2009 | Kenmore 44072 Front Load Washer
Maytag Neptune MAH6700AWW spins but not fast enough
Too much laundry in your machine. Try a smaller load and see if you have the same problem
Jan 19, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag washer/front end loader
HI...mine has just started dong the very same thing. I unplugged it to reset the computer and tried
just the 'spin' setting....still...the water is still in the machine....not sure what to do. I thought a blockage too.
abby
Sep 08, 2008 | Maytag MAH6500 Neptune Front Loading...
Water does not drain completely, mostly but not completely and just stays there Maytag Quiet Series 100
If the machine has a auto sensor or auto clean cycle it is supposed to keep water in the bottom. The sensor has to stay wet for it to work properly. My Maytag drains, then fills slightly to do this.
Jul 03, 2008 | Maytag Dishwashers
Washing Machines Logo
101 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
