Question about Solis Master 5000 Espresso Machine
The dredgedrawer notification will not turn off on my solis 5000 espresso machine
I have emptied my dredge drawer on the espresso machine and the notification will not turn off. I have tried everything turning off machine unplugging and nothing works
    Problem Solver:
  • 14 Answers
Grinds sometime get lodged behind the drawer. When you replace the dredge drawer it doesn't go all the way in. Clean out behind it really well (maybe air blower fro computer) and try it again.
Posted on Apr 02, 2014
SOURCE: Solis Master 5000 Espresso Machine - Need Repair
If you can remove the grind hopper(two screws) you can re-index the grinder for a finer grind.
Posted on Mar 14, 2008
erguel
SOURCE: Solis Pallazzo espresso machine - need maintence manual
Hi, check under: http://www.solis.ch/franzoesisch/kundendienst/kundendienst_f.htm
and choose your machine, under E (english) column, you'll get the pdf.
Posted on Feb 01, 2009
SOURCE: I NEED A sOLIS 5000 ESPRESSO MACHINE PARTS DIAGRAM
A friend helped me and I have it now..
Posted on Mar 28, 2009
  • 1089 Answers
SOURCE: Bean and water fault(red) light blinking
HI First make sure everything is in and locked (brew unit, drip tray, and dredge drawer). Open the knob on the right and flow water through the wand. Now turn the knob in the bean hopper to 16 and push the brew button. If that didn't work you might have a clog in the grinder, and will need to clean it.
Posted on Jan 26, 2010
SOURCE: Solis SL70 Espresso Machine: Pump Switch Light Turns Off
Mine has always worked that way; it only seems to have enough power to do a single set of 25 second shots before a short re-heat
Posted on Feb 04, 2010
After emptying the dredge drawer and replacing it, the unit still says "Dredgedrawer Missing"
The sensor that detects the presence of dredge drawer is not closing. Locate it and fix it or just jump the wiring to the sensor.
Aug 09, 2015 | Saeco Magic Comfort Plus Espresso Machine
'dregdrawer full' message but not disappearing when emptying it
HI Are you leaving the machine on when you empty the dredge drawer? There has to be power for the computer to see that the dredge drawer has been removed. Leave it out at least 15 seconds, so the computer thinks you emptied it. This should clear the message.
Jul 09, 2011 | Saeco Incanto Classic Espresso Machine
Machine shows message 'dregdrawer full' even thought the dreg drawer is empty. cant get rid of this error message.
Hi
When you go to empty the dredge drawer you must leave the machine on. When you remove the dredge drawer it will say dredge drawer missing. Leave it out at least 15 seconds so the machine knows you are empting it. When you insert it again the machine will count about 24 cycles and tell you to empty it again. Its a counter.
May 12, 2011 | Gaggia Syncrony Compact Digital Espresso...
Hi, my machine says empty dregs and I don't know what it means by that. Any ideas?
Hi
Leave the machine on. You need to remove the drip tray. Then pull out the big box(dredge drawer) on the right. Empty the contents. Leave it out at least 15 seconds. Then set back in its hole but don't push it in all the way. About half way in, push it the rest of the way in with 1 finger, pushing on the right side of the dredge drawer, until it stops. That way you won't have the problem of knocking off the lever on the drawer switch. You should never get the "dredge drawer missing" by doing it this way.
Apr 17, 2011 | Saeco Magic Comfort Plus Espresso Machine
I have the manual unit and this morning after making a few capps it went to grind and then just stopped. I turned the unit off and then back on but the unit did not do its normal 'first' cycling. I have...
Check for something out of place. Brew unit, dredge drawer, driptray. There is wires on the boiler that may have come off, but unlikley. It could be the brew drive motor, or the board.
Nov 08, 2010 | Solis Master 5000 Espresso Machine
How does a Saeco Magic De Luxe Espress machine know the dregs drawer needs the be emptied and turns on the light? Does is just count the pucks that are put into the drawer or is there some type of sensor?
Simple answer is it counts how many coffees have been made. If you turn the machine off and then empty the dredge drawer the machine doesn't know this. and the light will remain on. Leaving the machine on when you empty the drawer lets the machine know that you emptied it (15 seconds out) and it will turn the light off.
Oct 07, 2010 | Saeco Magic De Luxe Espresso Machine
Bean and water fault(red) light blinking when i turn on solis master 5000 coffee machine. how to fix it. Regards vh
Jan 26, 2010 | Solis Master 5000 Espresso Machine
DREDGE DRAWAR FULL SIGNE COMES UP. EVEN AFTER EMPTYING DREDGE DRAWER MACHINE WILL NOT RESET TO PRODUCT READY
Hi When you empty the dredge drawer, the machine must be on and in use. Take the dredge drawer out and leave it out for 15 seconds. If the machine is off when you empty it doesn't know that.
Jun 15, 2009 | Saeco Royal Professional Espresso Machine
Faulty dredge drawer sensor
remove drawer and drain tray, there may be some coffee grounds on the back of the machine where the drain tray sits, preventing the dregs drawer from sitting properly.
Apr 10, 2009 | Gaggia Syncrony Espresso Machine
Solis Master 5000 Espresso Machine Logo
Top Solis Coffee Makers & Espresso Machines Experts
graybeard32301
Colin Stickland
Colin Stickland
AZBen
AZBen
Are you a Solis Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
