Question about Logitech S120 2 Speakers
Can"t hook-up new speakers
My original speakers had a usb wire. these do not will they replace the original speakers?
Gwm hover radio harness colors
In my experience the easiest and most efficient way to hook up a new radio in a vehicle is to use an adapter that connects the original wiring to the new radio. There are several site on the web that specialize in these connect adapters for many vehicles. You can do a search for your new radio to the vehicle you have.
Mar 27, 2014 | Vehicle Parts & Accessories
I was installing a new radio in my 98 Mercury villager. Everything hooked up properly to the new wire harness but no sound came out of the speakers. The new radio lit up but no sound. What is the problem?...
you have to connect speaker wire directly to the radio. Don't have amplifier inbetween the speaker and radio because it is not neccessary. If you want amplifier inbetween the radio speaker wire and the speaker then you most likely the amplifier has another power supply wire and hope that the amplifier does not have any additional control wire thats controled by your original radio.
Sep 08, 2017 | Cars & Trucks
I have a Panasonic AK SA 350 stereo unit and want to hook up different speakers than supplied with the unit. How can it be done?
Take new speaker wires and connect them to your new speakers. the wires may have to be cut and new terminals fitted depending on what you have. It would be ideal to solder the ends that clip into the stereo Just make sure the new speakers have the same impedance as the original
Jan 06, 2013 | Audio Players & Recorders
How can i replace 1991 maxima radio system?
The original radio is a BOSE system and it has a buit in amp. So if you replaced the deck you need to replace the speakers all so. Don't cut the wires to hook-up the deck buy an addapter KIT. It's not just the stereo that runs though that harness the factory alarm does all so and that will cause you problems. Anyway back to the stereo you need to add an amplifier and problem sovled.
Jul 23, 2012 | 1991 Nissan Maxima
Trying to get radio out of a 2006 Subaru Baja to check speaker wiring and cant get dash cover off
It's probably the speaker, not the wiring. I've got one speaker that goes in and out, mostly out. Turns out the diaphragm is getting stuck to the magnet. After seeing the wiring checking your speaker connection would be a much easier place to start.
We hooked up an external speaker to the contact points and got sound, plugged the original back in, no sound. A simple un-intentional patting to the speaker and it started working again.
Will probably be replacing soon.
As a side note, crutchfield sent me some nice installation instructions when I purchased a new wire harness to put in a new radio. Pretty detailed and with photos. Getting in there takes a bit of work, but trying to trace wires would be painful.
Jun 06, 2010 | 2006 Subaru Outback
Radio and cd player only play out of left dash speaker. It seems to me that equalizer works ok,(only one speaker to check it with) but when I fade over to right side channel, nothing. The antenae is hooked...
I had this same problem. After reading other ideas and some trial and error, I finally got it. Most Caravans have an Infinity system (the speaker grill will say Infinity on it) ,which uses an amplifier to run the door and rear speakers. I had to ground the clip wire that was originally attatched to the strap ground on the factory installed radio. Then I also had to hook the wire on the new radio for power antenae (blue and white on my unit) to a blue wire on my new harness. This wire came from the last wire of 7 wire harness that had the other 6 wires for speakers. The original wire appeared to be green/red on my vehicle. After I connected both, the speakers cameon and sound great again.
Apr 26, 2010 | 1997 Dodge Caravan
Changed Radio - now speakers don't work. I took out the Chrysler radio that had a CD and cassette in it and replaced it with an aftermarket radio. Now the speakers don't work. I got the adapter from a...
Sounds like your Gr Caravan has the premium sound package. You likely haven't hurt anything - but you may need to modify the wiring a bit. The speakers have a tweeter speaker in the center of the main speaker and the wiring goes through that. However, it only worked with the premium package. Go in to the speakers and move the wiring connections from the tweeter to the main speaker. Your other option is to replace the speakers.
Jan 19, 2010 | 1994 Dodge Grand Caravan
Power supply to in-door speakers 1996 grand caravan
Jun 12, 2009 | 1996 Dodge Caravan
Aftermarket 6 x 9's
What type of car is it? You can purchase speaker harnesses at any car audio shop that will allow you to snap into the factory plugs. Also, beware if your system was designed for 8 ohm speakers - using 4ohm speakers instead could cause some problems. Most aftermarket stereos are designed for 4ohm speakers, but some factory stereos designed for 8ohms could be damaged if you give them a smaller ohm load.
Sep 15, 2007 | Car Audio & Video
Logitech S120 2 Speakers Logo
46 people viewed this question
Top Logitech Audio Players & Recorders Experts
gunzmith
Level 1 Expert
Henry  Thomas
Henry Thomas
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
