Question about Panasonic LUMIX DMCZS7 DMCTZ10 Digital Camera
Can't format memory card on camera
2 GB SD Card won't format using camera
SOURCE: Panasonic Lumix DMC FZ20
Had to take my SD card in for a system recovery.
Thanks
Posted on May 21, 2008
SOURCE: SD card - memeory card parameter error
The manual for the camera states that the memory card must be formatted in the camera and that cards formatted in a computer may not work properly. Use the format command in the camera.
Posted on Jul 05, 2009
Obertelli
  • 3006 Answers
SOURCE: What is the largest size
The DMC-FZ7 is designed to work with SD cards up to a maximum 2GB capacity (4GB in theory, but very few devices work reliably with the 4GB SD as they simply didn't exist at the time so could not be compatibility tested with most SD devices). You have tried an 8GB SDHC card which the camera is incompatible with.
The SDHC card is the same size and shape as SD but is significantly different "under the hood". SDHC compliant devices can use earlier SD cards, but devices which are not designed to use SDHC cards cannot be updated: the incompatibility lies at the basic hardware level so there is no firmware update to overcome this.
So your guess is correct, but I hope that my reply helps you to understand why. Your fix is therefore to stick with SD cards of a maximum 2GB capacity. As SDHC cards start at a minimum 4GB capacity, you have no risk of buying the wrong model.
Please take a moment to rate my answer.
Posted on Sep 24, 2010
LongPockets
  • 1177 Answers
SOURCE: When I turn my camera
A card that size is actually an SDHC card. SD and SDHC cards fit the same slots, but they are slightly different. Many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible.
I expect your camera just won't work with this kind of card. It is often difficult to find out the maximum capacity memory card a camera will use, as today's cards are much larger that those available when the manual for the camera was written.
Posted on Dec 07, 2010
LongPockets
  • 1177 Answers
SOURCE: Is there a maximum SD
I think you mean 16 and 24 GB (Gigabyte), not MB, but those would not be SD cards. A card that size is actually an SDHC card. SD and SDHC cards fit the same slots, but they are slightly different. Many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible.
If you really mean 16MB, then that would be rather small, not too big. 16MB is definitely compatible with the camera and is mentioned in the manual.
The maximum memory card size mentioned in the manual is 1GB, and that is quite big enough. If you really need more space, then just carry a spare, like people used to take extra film with them on holiday.
Posted on Dec 09, 2010
Testimonial: "Cheers long pockets I really appreciate your prompt reply and clarification. Sorry about the MB- GB thing,I will go for a 1GB and back card - thanks"
I have a Polaroid i1032 10.0 megapixel camera. the user guide says that i can use up to a 1 gb SD memory card. I've used a 2 gb SD card and it works fine. My question is can I use SDHC cards 2 gb, 4 gb, 8...
At the time your camera was made, 1GB was the max size standard SD card. Then along came 2GB standard SD, but this card also used the same format as previous cards, so yes it also worked in your camera. Now SDHC is a very different format with different file handling (although externally it looks exactly the same). I'm sorry to say, it is very unlikely that SDHC will work with your camera. Here on Fixya you'll see many folks asking why the brand new card they just bought doesn't work with their older camera. 9 time out of 10, this is the reason why.
Mar 22, 2011 | Polaroid i1032 Digital Camera
What size memory card does the kodak easyshare cx6200 take?
The internal memory for this camera is 8 MB.
The manual indicates using memory cards of size 8 to 128 MB, so this is an early SD memory camera, following the original SD standard. Do not try SDHC or SDXC cards. The camera will support a 1 GB card. It *might* support a 2 or 4 GB card, but since this is a 2 Mpixel camera, a 512 MB or 1 GB card will allow you to save thousands of jpeg format pictures.
Mar 01, 2011 | Kodak EasyShare CX6200 Digital Camera
When pictures are taken they are being stored on the camera. They do not go to the SD card.
You need to get rid of the pictures in the internal memory. If you want to save any of them, go into the menu and find "copy". You will find the option to copy them to a memory card. Then, with no card in the camera, go into the menu and find "format"....follow the on-screen instructions to erase the internal memory. Then your card should work properly.
Dec 28, 2010 | Panasonic Lumix DMC-ZS3 Digital Camera
Should you use an 8gb sd memory card in a panasonic lumix dmc-fx3 camera ?
The manual lists the following SD cards compatible:
4 GB SDHC Memory Card
2 GB SD Memory Card
1 GB SD Memory Card
512 MB SD Memory Card
256 MB SD Memory Card
128 MB SD Memory Card
64 MB SD Memory Card
An 8GB card may or may not work. If you try it, make sure it is an SDHC card. (Note: HC=High Capacity)
Thanks for using Fixya.
Apr 27, 2010 | Panasonic Lumix DMC-FX3 Digital Camera
MY Koday EasyShare C530 not supporting 2GB memory
This is from the Kodak website, bad news:
Question : Can I use a 2 GB Secure Digital (SD) memory card in my KODAK EASYSHARE C-Series Digital Camera? Answer : No, your digital cameras is not compatible with 2 GB SD memory cards; your camera accepts a maximum 1 GB SD card.
Hope this helps.
Feb 06, 2010 | Kodak EasyShare C315 Digital Camera
We insert a memory chip into our Kodak EasyShare C190 camera. The read-out informs us that the memory card requires formatting. We click on "OK." The camera goes into a "formatting" mode, then informs us...
Your camera is only supporting SD/MMC Cards (up to 2 GB) and KODAK SDHC Cards (up to 8 GB).
The card that you currently have might be faulty. Please try another card.
You might also need to switch the camera over to saving pictures directly onto the SD card.1: Menu, Cam settings, Chose AUTO or SD card option Press OK
Note: If the SD card isn't in the camera or is unreadable the camera will automatically go back to saving you taken pictures on the internal memory.
Jan 04, 2010 | Kodak Easyshare C190 12MP Digital Camera...
Same as yours
The Z740 supports only MultiMediaCards & SD Memory Cards. 4GB and larger SD cards are usually SDHC (Secure Digital High Capacity) types - and bear the SDHC mark on the label. These cards are not compatible with this camera. Use only MMC and SD cards. SD cards are 2 GB and under - although *some* 4 GB cards are marked as SD too; these cards may or may not work. If you purchase a 4 GB SD (not SDHC) card, make sure that it can be returned if it doesn't work reliably in your camera.
Oct 05, 2009 | Kodak EasyShare Z740 Digital Camera
A 2gb memory card says memory full tried it in
No, that camera works with the 2gb cards just fine. You will want to try to format the card in your computer first, then try it in your camera (format it in the camera before using). If it doesn't format in the computer, it is a bad card.
Jul 19, 2009 | Kodak EasyShare C330 Digital Camera
I bought a 2GB SD card for my Kodak EasyShare C330 Camera
Buy a 1GB card (or 2). The spec for the SD card format is going to 2GB but the Kodak C330 not compatible with 2 GB SD memory cards.
Click
Jun 01, 2009 | Kodak EasyShare C330 Digital Camera
I have a new 2 gb dane-elec memory card and when i turn on my camera it says the memorty card is full and when i try formatting it it says filesys error e00100
Click
But try an firmware upgrade. Maybe the supporting now the 2 GB memory cards.
Why download firmware version 1.07?
This firmware version improves memory card compatibility and provides general performance updates.
KODAK EASYSHARE C330 Zoom Digital Camera Firmware
May 22, 2009 | Kodak EasyShare C330 Digital Camera
Panasonic LUMIX DMCZS7  DMCTZ10 Digital Camera Logo
18 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
