Question about Sunbeam 2360 Deluxe Mixmaster Mixer
While putting a new handle on my mixer a small spring and small bracket in the back came off. I can't find a diagram that shows the placement of these small pieces. Is there a diagram for this area of the mixer.
    New Friend:
    Problem Solver:
  • 14 Answers
Call the manufacturer of the mixer. If it's a replaceable part they would know and they might even stock it. If it's still under warranty they'd probably replace it.
Posted on Feb 17, 2014
How do i adjust the bowl height on an ksmc5os?
I'm not familiar with your model but on stand mixers with crank handle bowl lift there are 2 places for it to be. With bowl lift down there can be s screw straight in from the front on the pedestal just above the bowl lift sliding bracket, the full range of adjustment is half a turn, anti clockwise to raise, clockwise to lower. The other one is a small screw sticking down from under the gear case where the bracket that carries trhe bowl slides up and down. Clockwise to lower, anti clockwise to raise.
Aug 19, 2014 | KitchenAid KSMC50S Commercial Stand Mixer
How to replace motor brushes? I only can take the small springs after unscrewing the caps on both sides. The carbon brushes are still inside? Tell me how to take them out and just put new brushes with...
I believe the brushes and the spring are one piece, so the brush should come out with the spring. Either the brushes are so worn that you just aren't noticing the little bit that's left, or the block has come loose from the spring. You can tip the machine over so the brush hole is facing down and let gravity do the work. If there's any brush left inside, it should slide out. Otherwise just install the new brushes.
Dec 14, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
The handle will not allow me to raise the bowl to make contact
Looking at the following parts diagram:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10157992.pdf
You can see the linkage on page 6. Turning the crank handle #22 counter clockwise rotates the link #18, which is attached, which pulls on the rod #11. There is a spring clip #10 on the rod which sometimes comes off making the linkage bind. Make sure it is in place by turning the mixer on its side and looking up inside the base.
If it is in place then spray a small amount of lubricant on the linkage to lubricate all of the moving parts.
Also put a small amount of lubricant on the sliding member #7 where it slides against the stand section #15.
Note: Don't try to move the crank lever when the mixer is on its side since it will bind. It requires gravity to pull the sliding part down, and with it on its side the sliding part will not move downward thus binding up the linkage.
Apr 16, 2010 | KitchenAid KP2671 Professional 6 Series...
Brushes stuck, afraid i put them back in wrong. now they wont come back out with the spring when i take the black plug out. no power when i turn on the switch.
you can access the brushes from inside the mixer if you take it apart. Look at the parts diagram here to see if you can figure out how to disassemble it:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208212369.pdf
Once you have it apart you can use a small screw driver to push the brushes out from the inside.
Apr 03, 2010 | KitchenAid K45SS Classic Stand Mixer
My Kitchenaid mixer is tripping the power in my house. I removed the back and found two identical springs loose in the machine. Have you seen this problem before? Cheers Anthony.
Anthony,
Based on your description, it sounds like those identical springs are a part of your motor brushes. Normally, they would be attached to the motor brushes (depending on model), which are located behind the 2 slotted round access caps about mid way, front-back on the cover assy. My hunch is that the spring(s) may have gotten dislodged during a previous dis-reassembly and had came in contact with the armature and a grounded component causing a short and circuit overload ( breaker trip). I suggest that you locate the appropriate diagram for your mixer and ensure that your brushes are assembled correctly - all parts accounted for. You can get diagrams and parts lists from various online vendors, such as: http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=k45ss Use the 'Motor and Control' diagram as a reference.
DZII
Jan 03, 2010 | KitchenAid K45SS Classic Stand Mixer
Need interior diagram of Sunbeam MixMaster Model 2486
Here's the solution. The spring controls the beater eject button. The spring is mounted on the metal shaft and is oriented so that the straight side of the spring rests along the white plastic part adjacent to the shaft, and the curved side of the spring points outward and downward so that it will rest against the case when the unit is reassembled. See photo.
Dec 26, 2009 | Sunbeam Food Mixers
The attachments move up on the shaft
There is a retaining clip part number 9703680 illus no 25 on pg 5 of this part diagram http://www.goodmans.net/images/dmg/ka_diagrams/KP26M1X.pdf that part slip down the shaft on my mixer. I use a pair retain clip pliers to put back in place in the grove on the shaft and was back in business. if the clip is not on the shaft then you need to get a new one.
Jan 15, 2009 | KitchenAid KP2671 Professional 6 Series...
The switch is broken
Mine did the same thing. I found the ball bearing inside the switch had fallen off. Put it back on and it works like new!
Pull the mixer case apart. Push in on the seam in the front and back and it will pop open after you remove the 1 screw. Pull the switch apart. There is a spring inside the top part of the switch and a small (1/8") ball bearing should be on top of the spring. Chances are, it has fallen off. Find it and stick it back on the spring while holding the top part of the switch upside down. Put the mixer back together.
Dec 26, 2007 | Braun M880 MultiMix Hand Mixer
Sunbeam 2360 Deluxe Mixmaster Mixer Logo
62 people viewed this question
Top Sunbeam Food Mixers Experts
Oloyede Monsuru
Oscar Netto
Oscar Netto
Are you a Sunbeam Food Mixer Expert? Answer questions, earn points and help others
