Question about Tricity Bendix AW1400W Front Load Washer
Beeps and flashes 4 times
It beeps and flashes 4 times
Fagor LF 65IT beeps 4 times a few minutes after switching on and all lights flashing on display
This is a flood warning. You must have water in the bottom of your machine which has raised the float and activated the flood switch. Open the lower front panel on your machine and for where the leak is coming from.
Apr 03, 2012 | Fagor LFA-65 IT Dishwasher
Five beep in Hp compaq 530
1 short beep and 1 long beep Memory problem 2 short beeps and 1 long beep (repeats 5 times) Unable to initialize video or video card required but not installed 3 short beeps and 1 long beep CPU configuration error or CPU type is not compatible The following beep codes are common to many HP and Compaq desktop computers that can occur while restoring, flashing or updating the BIOS : Beeps Description 1 short beep Legacy floppy drive or CD/DVD drive not detected 2 short beeps Floppy diskette or compact disc not detected 3 short beeps Unable to start flashing (such as when missing a utility or BIOS image) 4 short beeps Flashing failed (checksum error, corrupted image, etc.) 5 short beeps BIOS recovery successful
Apr 21, 2011 | HP Compaq Business d530 Ultra-Slim PC...
Green light flashes, will not print. Checked all
Hi can gave you the truble codes
  • Light Orange - 2 beeps: Remove any paper jammed
  • Light Orange - 3 beeps: Remove any paper jammed
  • Light Orange - 4 beeps: Add Ink
  • Light Orange - 5 beeps: Re-install cartridge or replace it
  • Light Orange - 6 beeps: Re-install cartridge or replace it
  • Light Orange - 7 beeps: Re-install cartridge or replace it
  • Light Orange - 8 beeps: Waste is almost full
  • Flash 1 x Orange - 10 beeps (error code 6100): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 2 x Orange - 10 beeps (error code 6300): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 3 x Orange - 10 beeps (error code 6800): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 4 x Orange - 10 beeps (error code 5100): Make sure nothing is blocking the cartridge movement, if not requires service.
  • Flash 5 x Orange - 10 beeps (error code 5400): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 6 x Orange - 10 beeps (error code 5B00): Waste full (make a reset)
  • Flash 7 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 8 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 9 x Orange - 10 beeps (error code 5600): Replace the BJ Cartridge(Printhead) or reinstall it
  • Feb 01, 2010 | Canon BJC 4400 InkJet Printer
    Boot up beeping problem
    Hit VGA Card if it is not connected properly. If there is any dust, clean it by using an eraser.
    Aug 17, 2009 | HP dx5150 Microtower PC Desktop
    My philips 50p8341 beeps then flashes the red led 4 times
    4 Blinks means that an incorrect voltage had been detected on the +5V circuit coming from PSU to digital control board.
    The PSU must be tested and eventually repaired or replaced.
    Aug 08, 2009 | Philips Televison & Video
    HP COMPAQ D530 RED BLINKING LIGHT WITH BEEPING SOUNDS.
    4 beeps & 4 flashes mean problem with the power supply. For my experience, most of the time the PSU is good, it is just overloaded.
    For more LED and Beep messages, check this link:
    http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00067072/c00067072.pdf
    Dec 26, 2008 | HP Compaq d530 PC Desktop
    Prima LPR600
    my prima LPR intregated dishwasher just not playing ball, has not been washing properly and had a continuous flashing and beeping fault, we cleaned out the filers and the arms which seemed to help the beeping problem but now have a fault where at the end of the cylcle its now showing another fault where it flashes 4 times but beeping has stopped what seems to be the problem and how do we fix ?
    Oct 17, 2007 | Dishwashers
    Zanussi FX1465W aquacycle, beeps 5 times and end light flashes
    I have the same trouble with my washing machine did you find a solution i have been told the PCB or motor drive system
    May 19, 2007 | Zanussi FJS1225W Front Load Washer
    Tricity Bendix AW1400W Front Load Washer Logo
    Top Tricity Bendix Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
    Charles T Nevin
    Charles T Nevin
    Are you a Tricity Bendix Washing Machine Expert? Answer questions, earn points and help others
