Question about D-Link DIR-625 (790069292637) Wireless Router
Install on linux operating system - D-Link DIR-625 (790069292637) Wireless Router
  • 783 Answers
Sir
A The router connects to the internet, so the settings for that should not be touched, and it does so regardless of any operating system your computer may be running. The adaptor connects the computer to the router and needs a suitable driver to work with Linux. Unfortunately, model numbers are not enough to determine which is the correct driver for your particular hardware, as manufacturers have a habit of changing the chips used inside a device without altering the model number. I was caught out with a D-Link USB adaptor like this. I bought one because it was supported by the Linux prism drivers, only to find that they had just switched to an unsupported chipset.
There is a way out if it turns out that there's no Linux driver for your chip, but it's possible that there is a native solution. Your card is quite likely to be based on the Ralink RT73 chipset. OpenSUSE 10.3 includes a driver for this but does not install it by default. Go to the Software Management section of Yast and install rt2x00-kmp-default. Now plug in your network adaptor and go into the Hardware Information section of Yast. If your device is now listed in the Network Card section, you can go to the Network Card section and set it up. If it isn't listed, unplug the adaptor, open a terminal and run
su tail -f /var/log/messages
Plug in the adaptor and watch the output in the terminal. You should see some details whizz past (press Ctrl+C to stop the output). Run
modprobe rt73usb
and if you get no feedback, you have the right driver. Go into the Network Card section of Yast and set up your network connection. You may need to specify the driver module (rt73usb) for the device here. If all of the above fails, there is an option to use the Windows drivers for the adaptor, using a package called NdisWrapper. This emulates the Windows network driver interface, so that Windows drivers can be used in Linux, so install this with Yast. Dig out the driver CD that came with the device and locate the driver .inf file, then in the terminal window you should still have open, run
ndiswrapper -i /path/to/driver.inf modprobe ndiswrapper
The first command should install the driver where NdisWrapper can find it; the second loads the NdisWrapper module and should give no output if all is well. Now create the interface in Yast using the Add button, set the Device Type to Wireless and the Module Name to NdisWrapper, leaving everything else on the default settings, and follow the usual prompts to set it up.
' '.-----.-----.-----.' ' ' '.----.' '_ ' - '' _ ' -__' '' ' ' '' _'' _' '_______'' __'_____'__'__''________''__' '____' '__' W I R E L E S S F R E E D O M ----------------------------------------------------- ATTITUDE ADJUSTMENT (12.09, r36088) ----------------------------------------------------- * 1/4 oz Vodka Pour all ingredients into mixing * 1/4 oz Gin tin with ice, strain into glass. * 1/4 oz Amaretto * 1/4 oz Triple sec * 1/4 oz Peach schnapps * 1/4 oz Sour mix * 1 splash Cranberry juice
in Case You still Have problem Then follow Us On online link Router Set on Linux operating system on below link URL:
http://www.techsupportrouter.com/support-for-d-link-router.html
Posted on Mar 28, 2014
I downloaded a Linux program from the Internet to my download directory. How can I install it?
It depends on situation.
What is your operating system?
Windows:
No easy way exists to run Linux program in windows. Use VirtualBox or VMware virtual environment, download Linux OS, install virtual Linux machine and then install your downloaded program in Linux.
VirtualBox free download (virtual environment):
Welcome to VirtualBox org
Ubuntu Linux OS free download (virtual machine):
http://www.ubuntu.com/download/desktop
Your final installation set look:
Your downloaded program
Linux operating system - installed as virtual machine
Virtual environment
Windows OS
These components are installed on computer
Linux:
There exists more program packages types :
RPM package installation (Centos, RedHat, OpenSuse...)
rpm -ivh program_name.rpm
Debian package installation (Ubuntu, Debian...)
sudo dpkg -i program_name.deb
or
sudo apt get install program_name
General compressed file / installator
File extesion examples:
package_name.tgz
package_name.tar.gz:
Unpacking
tar -xvzf program_name.tgz
Installation of executable file :
./install.sh
(or another file from the package)
Jan 19, 2016 | Computers & Internet
How can I install Linux over windows XP
just install other drive. when booting log on, just select your operating system linux or" xp. brother do it solve your problem.
Dec 28, 2011 | Dell Computers & Internet
I will ask if i can download windows 7 on linux acer aspire 4738?there will be a problem?
there won't be any problem as far as Windows and Linux, but this is a fairly involved procedure.You'll first need to create a Windows partition on your hard disk in NTFS file system format. Otherwise,Windows might overwrite / erase your linux installation when Windows 7 installs.
make the windows partition the "Primary" or "Boot" partition.
When Windows 7 installs, it may ask if you want to delete the linux partition.Answer "NO" to this.
The next concern is which operating system will boot by default,Windows or Linux.
I had no problem doing this with Windows Vista, and whe Vista booted,it listed a choice of operating systems to boot,and I would select either Windows Vista or Ubuntu Linux.
Apr 03, 2011 | Acer Computers & Internet
When I start the laptop (HP HDX 16) I get this messege: Boot device not found Error codes Hard Disk-(3F0) pleas install an operating system on your hard disk. F2 system diagnostic. but it does not install...
The Windows edition listed in BIOS (Vista) is referring to the operating system that came with the computer. BIOS's System Diagnostics will always say the OS is Vista, because that is the original OS that HP put on the system. BIOS itself, however, cannot detect an operating system on the new Hard Drive because there is no operating system. In order to get an operating system, you have a couple options:
Depending on the terms and length of your warranty, you may be able to get HP to reinstall the operating system back onto the new Hard Drive. The amount you would pay depends on the warranty. Many warranties, however, become void when you change physical components in the computer (especially with laptops). If this is the case, you will have to try the next option.
You can buy a retail copy of Windows either online or from an electronics store. The price will depend on what edition you purchase, but it will probably cost you at least $100 US.
You can install a Linux operating system on your Hard Drive. If you've never heard of Linux, it is an operating system based on much of the same code as Mac operating systems, but has a more "Windows-like" feel to it. Linux operating systems are NOT the same as windows, and some programs that work in Windows will not work in Linux; you would need to find the Linux counterpart for these programs. One of the best things about Linux operating systems are that they are absolutely free to download, install and use. A very popular and stable Linux operating system is Ubuntu, which can be found at: http://www.ubuntu.com/
Mar 20, 2011 | HP HDX16t Premium Series Notebook
WHAT IS LINUX?
Its all things good ;) the definition for it is: open-source version of the UNIX operating system.
So another words its free OS
But personally I like ubuntu way better thin fedora.
best of luck
Mar 04, 2011 | fedora Linux Operating System
Hi there.I've hp compaq 5610b laptop and using vista operating system.Is it possible to use another operating system in my computer?Plz help me!
You can install the previous version of Windows - this is Windows XP or you can install the latest version of Windows - this is Windows 7.
You can install a Linux operating system such as Ubuntu or Red Hat
Google search for Linux operating systems to download Linux freeware program.
Dec 16, 2010 | HP Compaq 6510b PC Notebook
How do i install a software on red hat enterprise linux
Software on Redhat linux is delivered as RPM packages. you can install these via the internet if you have the YUM utility installed.
May 25, 2010 | fedora Linux Operating System
How t format a pc with centos os?
The formatting and installing the PC with the centos is similar to the other Linux operating systems .
Initially insert installation cd and boot the computer and with the help of GUI you can perform the formatting and installation .
Installing centos is similar to rest of Linux operating systems
The detailed steps can be found from tyhe following link
http://www.howtoforge.com/installation-guide-centos5.1-desktop
May 05, 2010 | Red Hat Enterprise Linux ES Basic Edition
How to install rar prog on linux?
You can downoad rar program for linux from following link. Also you can dowbload step by step installation manual.
http://peazip.sourceforge.net/
Mar 03, 2010 | fedora Linux Operating System
Installation roblem
bro make perfect partion of ur hard disk............
Dec 01, 2009 | SuSE Linux Enterprise Management Pack...
D-Link DIR-625 (790069292637) Wireless Router Logo
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
