Question about Konica Minolta Office Equipment & Supplies
Error 510 minilta di 1610 - Konica Minolta Office Equipment & Supplies
  • Konica Minolta Master
  • 6,696 Answers
Power off the machine Hold down the stop key and power on if the code comes back replace the fuser unit.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Jan 16, 2016
3 Suggested Answers
jqsababa967
  • 145 Answers
SOURCE: code erreur
CAUSE: Adjustment mode 11 is not set to correct value.
SOLUTION: To set Adjustment mode 11 to proper value, perform the following:
1. Enter Tech Rep mode (Counter, Stop, 0, 0, Stop, 0, 1).
2. Press Stop and then Start. AJ- will display.
3. Enter 11 from the keypad.
4. Press Start. Current value will display.
5. Press Clear.
6. Enter a value of 1 from the keypad.
7. Press Start to save the setting.
8. Press Auto Reset to exit Adjustment Mode.
HOPE THAT HELP
Posted on Dec 06, 2008
  • 6 Answers
SOURCE: caro esperto codice errore c0510 minolta dialta di
Amico C0510 - fusione fallita (temperatura di fusione del basso anormale) temperatura del termistore fusione roll undectable rimane al di sotto di 120 ° ... controllare il fusore
Posted on Jun 01, 2010
How to solve konica minilta c224 machine c2558 error
SHAKE THE BLACK IU VERY WELL Clean Imaging Unit Contacts RUN GRADATION
UPDATE FIRMWARE
REPLACE BLACK IU
Jun 29, 2013 | Konica Minolta Bizhub C224 Color Copier...
Konica minolta di 1610 replace drumkit
se mando fazer limpezas gerais sera que ele retirara o codigo (error)
Nov 12, 2012 | Konica Minolta DiALTA Di1610p Printer
Caro esperto codice errore c0510 minolta dialta di 1610 sapresti come fare per sbloccare
May 24, 2010 | Konica Minolta Office Equipment & Supplies
Error code P9 and P21 appears on screen and when printing or photocopying using color black, blank copies are outputed
hi piz Error code P9 and P21 appears on screen and when printing or photocopying using color black, blank copies are outputed
Apr 29, 2010 | Konica Minolta bizhub C250 All-In-One...
Konica bizhub di1610fp priter constantly gives a paper size error and requires paper reset.
Change the paper size,emter in the user modeor press the Utility key.I have the Minolta Di 1610 (copier/printer) and every function is OK.One toner cartridge is OK for 7500 copies,if you can the setting the user tools.
Aug 31, 2009 | Konica Minolta Office Equipment & Supplies
Minolta Di 1610 f not starting
Scanner home position. Check the scanner itself there is a small piece of plastic that actuates the home sensor, check for dust dirt (can air) sensor is loacated under the glass left side rear
Apr 27, 2009 | Office Equipment & Supplies
Code erreur
5. Press Clear.
HOPE THAT HELP
Oct 20, 2008 | Konica Minolta DiALTA Di183F Copier
Delstar DS801 MP4 player
take it back to were you got it as you have a internal disk problem and disk means hard drive in laymans terms
Feb 02, 2008 | Delstar DS 917 Digital Media Player
Konica 7415 erro code C14A3
You have a blown exposure lamp or fuse. When repaired code will automaticaly reset.
Oct 15, 2007 | Office Equipment & Supplies
32 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
