Question about Dishwashers
Kudm01tj noise - do you know the Db level of this model?
Only problem is noise level
Do you have the output specs for a Hydrovane 975 SQ model?
PDF]Hydrovane 5-7-8 Series Compressor - Compressed Air ...
www.ca-intl.com/files/products/hydrovane-5-7-8-series.pdf
Hydrovane's design and production excellence, combined with a strong .... ModelMotor Capacity Rotor Noise Oil Motor. HP SCFM@ Speed Level - dB(A) CapacityVoltage. 100 PSIC .... 128 PUAS 67.00 28.25 39.5 975 1.00 20.25 x 22.25 n/a.
Nov 26, 2015 | Air Tools & Compressors
How do you set the switches on AT3525 Mike?
The AT3525 handles very high sound pressure
levels with ease, accepting as high as
146 dB SPL before producing 1% T.H.D. A
switchable 10 dB (nominal) pad is built-in,
increasing its capabilities to 156 dB SPL.
An integral 80 Hz hi-pass filter provides easy
switching from a flat frequency response to a
low-end roll-off. The hi-pass position reduces
the microphone's sensitivity to popping in
close vocal use. It also reduces the pickup of
low-frequency ambient noise (such as traffic,
air-handling systems, etc.), room reverberation
and mechanically-coupled vibrations.
Jun 20, 2014 | Audio Technica Audio Players & Recorders
Samson g track windows 7
It works fine in Windows 7 except that there's a bug in Windows 7 that adds lots of noise to the mic. It's easy to work around, though: Go into Recording devices, Properties button, Levels tab, right click on the level number so that it shows in decibels, and then adjust the level to 0 dB. It's supposed to be at 0 dB but Windows 7 defaults it to 30 dB for no reason. This isn't a problem on Windows XP.
Nov 29, 2012 | Samson G-TRACK USB RECORDING MICROPHONE...
Static Noise
Is it a hissing noise or a distorted crackling noise? If it's a hissing noise then it's due to a bug in Windows that adds 30 dB of gain. It's easy to work around, though: Go into Recording devices, Properties button, Levels tab, right click on the level number so that it shows in decibels, and then adjust the level to 0 dB. It's supposed to be at 0 dB but Windows 7 defaults it to 30 dB for no reason. This isn't a problem on Windows XP or OS X.
Jan 04, 2012 | Samson G-TRACK USB RECORDING MICROPHONE...
I am looking for information regarding a Weatherking 102 ton 13 S.E.E.R condenser. Specifics regarding noise levels. Can you help?
I think you may have listed your tonnage incorrectly. But, basing it on a 3 to 4 ton unit the dB rating is 76.
Hoe this tells you what you wanted to know.
Mar 11, 2011 | Weather King Heating & Cooling
My mic seems to pick up internal noise even when muted
Hi, You can check you the connectios or the mic. remember that the mic is too sensitive, you can adjust it with the nobb on the mic by putting it on o -dB and reduce the highs on your mixer or EQ to reduce hiss sound.
But fisr check the connection properly to see if when muted, is muted properly.
Take care.
Jun 08, 2010 | Samson G-TRACK USB RECORDING MICROPHONE...
Center channel is too quiet for dialogue from PS3 movies
turn the other speaker decibal levels down then increse main volume until you are satisfied.
Feb 06, 2010 | Denon AVR-1907 Receiver
Top rack slides out of its own accord when I open the dishwasher.
Your dishwasher most likely needs to be re-leveled.
Remove the toe-kick plate at he bottom front of the DW. Use a wrench to lengthen the front leveling legs to raise the front of the dishwasher.
Feb 01, 2010 | KitchenAid 24 in. KUDM01TJ - Multiple...
I don't know how many watts is this amp
ECLIPSE makes a 32440
If this is the amplifier you are looking for specs on...
4 x 85W @ 4 ohms (13.8V - 0.1% THD)
4 x 120W @ 2 ohms (13.8V - 0.1% THD)
2 x 240W @ 4 ohms bridge (13.8V)
Thanks for using FixYa -a FixYa rating is appreciated for taking the time to answer your Question.
Mar 28, 2009 | MTX Thunder 1501D Car Audio Amplifier
KitchenAid model KUDM01TJ
Check for loose wires on all switches and their is a fuse on the electronic panel that should be checked.
Mar 31, 2008 | KitchenAid 24 in. KUDM01TJ - Multiple...
Dishwashers Logo
77 people viewed this question
Top Dishwashers Experts
Owen Barnes
