Question about Kenmore Refrigerators
Food freezes in refrigerator model 795.77573600
The food freezes in the refrigerator
SOURCE: Food freezing in refrigerator.
I have a side by side GE Refrigerator only about 4 years old, the setting on the Refrigerator is set at 37 degrees but it continues to go to 20 degrees and freezing my vegtables. Help.
PS - i did vacumn the back filter a week ago with no help.
Posted on Jan 27, 2008
  • 29 Answers
SOURCE: Food is freezing
usually there is an adjustment at the back for the difference between the fridge and freezer compartment. Often is just a vane that blocks freezer air, too much air would freeze the food. Normally you set the fridge thermostat for a normal food temp, then adjust the air to keep the food warmer than the freezer.
Posted on Jan 28, 2008
  • 4 Answers
SOURCE: Side by side GE refrigerator freezing food in refrigerator.
The unit is having a damper control issue. In the back of the refrigerator there is an assembly that is in the center at the top. It connects to the freezer side. The damper is broken, cracked or has an obstruction. Check this and see if it is the problem.
Posted on Jan 09, 2009
alex_salve
  • 78 Answers
SOURCE: fridge area is freezing
unplug the refrigerator for atleast 6 hrs , again connect it , should work
Posted on May 17, 2009
SOURCE: food freezing in refrigerator section of frig.
look under your refridgerator and see if there is alot of dust on the coils. Whenever food starts freezing in my fridge I vacuum the coils and the problem goes away.
Posted on Jun 24, 2009
Drawer Freezer. Doesn't completely freeze food
Good Morning Stacey, thank you for your post!
I understand that your Frigidaire refrigerator is not freezing food properly. What temperature is your refrigerator set to? How much do you have packed into the freezer? Is this a new refrigerator? Could you also provide me with your model number? You can locate the serial (which lists your model number) on the inside wall of your fresh food side. Once I have that additional information I would be able to assist you further. -Matt
Jan 03, 2016 | Frigidaire Refrigerators
Freezing fresh food
HI,
The problem is with the damper door.Check that it is not cracked.If it is cracked then you will have to replace it with a new one.
Goodluck..
May 17, 2008 | GE GTS20ICNCC / GTS20ICNWW Top Freezer...
Gbscohbxercc referigerator freezing food
Could be a defective cold control.
Nov 28, 2013 | Refrigerators
PSC23NSTESS FREEZING VEGTABLES
Side by Side ModelsIf foods, such as fruits and vegetables, in the refrigerator are freezing, it can be caused by several things. First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenheit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • If food in the bottom of the refrigerator is freezing, this could be caused by a refrigerator not having enough food to absorb the cold air.
  • If food in the door is freezing, move the door bins up or down so they are one notch away from freezer vents (Side by Side models only).
  • The fresh food control should be at the normal setting of 5.
Freezer on Top Models
First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenehit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • Since the cold air coming into the fresh food section originates in the freezer above, the rear of the top shelf will be the coldest spot in the fresh food area. Avoid placing delicate items that freeze easily on the back half of this shelf.
  • If food is freezing in the produce (fruits and vegetables) or meat pan, it may be that the temperature controls are not set high enough. Since cold air naturally falls, the pans can get too cold if the refrigerator is not running long enough to maintain good air circulation. Adjust both controls up one notch.
Nov 01, 2012 | GE CustomStyle PSC23NSTSS Stainless Steel...
The fridgerator keep freezing the food. it is on the lowest setting but still it freezed the food. whirlpool MODEL: ET18NMXAW03 SERIAL: ED3042768 have had someone tell me to clear the food so that it...
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Jan 25, 2011 | Whirlpool Refrigerators
My SxS model 25 GE fridge is freezing food on the fridge side. I have turned it down to 1 and it still freezes the food.Also my water dispenser does not work. Can the 2 problems be related? How can these...
heatman101
Jan 05, 2011 | GE GSS25LGM Side by Side Refrigerator
Food freezing in refrigerator section of frig.
Sep 01, 2008 | Refrigerators
Food is freezing
Jan 28, 2008 | Arctic Air R22CW Refrigerator
Refrigerators Logo
35 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
