Question about Tricity Bendix AW1400W Front Load Washer
My ticity Bendix AW 1400 a beeps/flashes in a series of 4
Beeps/flashes4 times
  • 54 Answers
SOURCE: Tricity Bendix AW1001w
is the door locking if not replace it.
Posted on Feb 12, 2008
barkencoa
  • 3463 Answers
SOURCE: tricity bedix spin query
First of all make sure you have selected the correct spin speed if there is more than one setting.
Check and make sure prog 4 is mot a delicate wash prog, as it will spin at a lower speed if this is the case.
If it has a filter, locate it and remove to clean.
Plz rate my solution.
Thanks.
Posted on Jan 12, 2009
SOURCE: Tricity bendix aw 1001 w is not draining,pump and
If you have checked all of these then the only other explanation is that the pump motor is faulty and needs replacing or there is a fault with the wiring or Programmer.
Posted on May 03, 2010
HansPP
  • 2510 Answers
SOURCE: Trying to organise changing brushes in Tricity
Washing machine motors are usually induction motors and do not have brushes? Anyway, the back comes off and that normally gives access to the screws that hold the top on, but the motor is normally located at the bottom of the machine.
Posted on Feb 14, 2011
caroldon
  • 17130 Answers
SOURCE: tricity bendix 1400w will not start have heard 6 beeps
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Posted on Jun 28, 2012
What is A service code
I don't know what a service code is on your truck, but on my Ford Ranger, it's a series of beeps that I get when I first start the engine. It something isn't working right, the seatbelt minder beeper starts off with a series of beeps that indicate what's wrong. It might be something like 4 beeps, or three long beeps and two short ones. After that , it goes into the 24 beeps...pause...24 beeps that indicate that I don't have my seatbelt fastened.
On your truck, it might be different. It might be a series of flashing LED lights or something. Check your User's Manual.
Also, you can always to to Advance Auto Parts and they'll hook it up to a handheld diagnostic indicator for free.
Dec 02, 2014 | Cars & Trucks
Cmos beep codes
do you know which bios your computer is running ?
AMI BIOS beep codes 1 beep - DRAM refresh failure
2 beeps - Parity Circuit Failure
3 beeps - Base 64K RAM failure
4 beeps - System Timer Failure
5 beeps - Processor Failure
6 beeps - Keyboard Controller / Gate A20 Failure
7 beeps - Virtual Mode Exception Error
8 beeps - Display Memory Read/Write Failure
9 beeps - ROM BIOS Checksum Failure
10 beeps - CMOS Shutdown Register Read/Write Error
Phoenix BIOS BEEP codes. 1-1-3 CMOS write/read failure.
1-1-4 BIOS ROM checksum error.
1-2-1 System timer failure. (Programmable Interval Timer PIT)
1-2-2 DMA (direct Memory Access) failure.
1-2-3 DMA page register failure.
1-3-1 RAM refresh failure.
1-3-3 64K RAM chip or data line failure.
1-3-4 64K RAM odd/even logic failure.
1-4-1 64K RAM address line failure.
1-4-2 64K RAM parity error.
2-?-? Any beep series starting with 2 beeps indicates a 64K RAM chip or data line error.
3-1-1 Master DMA register test.
3-1-2 Mslave DMA register failure.
3-1-3 Master interrupt mask register failure.
3-1-4 Slave interrupt mask register failure.
3-2-4 Keyboard controller failure.
3-3-4 Screen (video) memory failure.
3-4-1 Screen initialization failure.
3-4-2 Screen retrace failure.
4-2-1 Timer tick interrupt test failure.
4-2-2 Shutdown test failure.
4-2-4 Unexpected interrupt in protected mode.
4-3-1 RAM test failure above address 0FFFFh (64K +)
4-3-3 Interval timer channel 2 test failure.
4-3-4 Time of day clock failure.
4-4-1 Serial port test failure.
4-4-2 Parallel port test failure.
4-4-3 Math Co-processor failure.
BEEP codes may vary dependent upon the revision of BIOS. This list is for reference only
hope this helps
Oct 10, 2012 | Intel Mother Board S5520HCR (988889365963)...
Why won't my laptop start up?
according to the manual a series of 4 beeps indicates a "RAM read/write error". Do you know how many sticks of memory you have in your laptop?
Feb 18, 2012 | Dell Inspiron M5030 PC Notebook
Forgot the combination to the lock. Is there a way to retrieve the combination or return it to its factory default combination 1, 2, 3, 4, 5
The instructions below are copied from the programming instructions (page 11):
ERASE ALL PROGRAMMING
(The "out of box" factory default will be restored)
1. At the back of the lock, remove the screw at the bottom of
the lock housing and remove the cover.
2. Take out the battery pack and remove battery power by disconnecting
the battery pack.
3. Plug in the (provided) male shunt connector into the yellow
wire female connector.
4. With shunt connector connected, re-connect the battery
pack. The lock will immediately sound 3 short beeps (if
these 3 beeps are not heard, then restart at step 2).
5. The lock will then sound more slow beeps, 1 beep for every
second it takes to clear the memory.
6. After a few more seconds, the LED will slowly alternate between
flashing red and green--disconnect the yellow wire
shunt connector.
7. The LED will continue to slowly flash green and red for 25
seconds. To enroll Function Cards, proceed immediately
as follows:
• With the lock LED slowly alternating between flashing
red and green, present the Function Card #1
to the lock. The lock will sound 5 slow beeps.
• The lock LED will flash green rapidly. The lock is
ready to enroll the Function Cards.
• Re-present Function Card #1 to the lock. The
lock LED will flash green then red, with two beeps
(indicating the card was enrolled successfully).
• Present Function Card #2 to the lock. Again, the
lock LED will flash green then red, with two beeps.
• Continue to present, in order, Function Cards 3-
9. Each time a new Function Card is presented, the
After the 9th Function card is presented, the lock LED will flash
green twice, sound two beeps, and will then remain silent,
ready for use. Note: If the lock continues to beep after presenting
the 9th Function Card, check to verify that the yellow
wire shunt is disconnected.
Note: If you only wish to use the first 3 Function Cards, simply
allow the lock to "time out" after 30 seconds.
Here is the link to the complete instructions, in PDF form. You will need Adobe Acrobat or equivalent to view them:
http://napcosecurity.com/download/PL3000_WI1280A.04_PROG.pdf
Good luck-and please provide feedback if this helps!
Nov 04, 2011 | Trilogy ALARM LOCK PL3000 Series T3 Prox...
Five beep in Hp compaq 530
1 short beep and 1 long beep Memory problem 2 short beeps and 1 long beep (repeats 5 times) Unable to initialize video or video card required but not installed 3 short beeps and 1 long beep CPU configuration error or CPU type is not compatible The following beep codes are common to many HP and Compaq desktop computers that can occur while restoring, flashing or updating the BIOS : Beeps Description 1 short beep Legacy floppy drive or CD/DVD drive not detected 2 short beeps Floppy diskette or compact disc not detected 3 short beeps Unable to start flashing (such as when missing a utility or BIOS image) 4 short beeps Flashing failed (checksum error, corrupted image, etc.) 5 short beeps BIOS recovery successful
Apr 21, 2011 | HP Compaq Business d530 Ultra-Slim PC...
Trying to organise changing brushes in Tricity Bendix AW 1400. I'm in Scotland, daughter and machine in England! Does top or back come off machine to allow access and is motor fairly accessible for...
Feb 14, 2011 | Tricity Bendix AW1400W Front Load Washer
Green light flashes, will not print. Checked all
Hi can gave you the truble codes
  • Light Orange - 2 beeps: Remove any paper jammed
  • Light Orange - 3 beeps: Remove any paper jammed
  • Light Orange - 4 beeps: Add Ink
  • Light Orange - 5 beeps: Re-install cartridge or replace it
  • Light Orange - 6 beeps: Re-install cartridge or replace it
  • Light Orange - 7 beeps: Re-install cartridge or replace it
  • Light Orange - 8 beeps: Waste is almost full
  • Flash 1 x Orange - 10 beeps (error code 6100): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 2 x Orange - 10 beeps (error code 6300): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 3 x Orange - 10 beeps (error code 6800): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 4 x Orange - 10 beeps (error code 5100): Make sure nothing is blocking the cartridge movement, if not requires service.
  • Flash 5 x Orange - 10 beeps (error code 5400): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 6 x Orange - 10 beeps (error code 5B00): Waste full (make a reset)
  • Flash 7 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 8 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 9 x Orange - 10 beeps (error code 5600): Replace the BJ Cartridge(Printhead) or reinstall it
  • Feb 01, 2010 | Canon BJC 4400 InkJet Printer
    Computer wont start and i get a series of four
    4 beeps mean your th'ers something wrong with your computer's memory. Make sure that the chips are seated firmly in their sockets If that dont help pull out the chips and reseat the chips
    Hope this helps.
    Sep 28, 2009 | HP Compaq dc5700 Small Form Factor -...
    Opti-UPS 1400ES UPS unit - Beeping 14 Times, stops, Beeps Again.
    you can try this asia systems technologies look for our sale person william +65 65478990 william@asiasystemstech.com i suspected that now that u UPS is have hardware issue.. to determine if the unit is really the problem it hav to be do a further diagnos..
    Mar 04, 2009 | Opti -UPS PowerES 1400 UPS System
    4 beeps 2373 laptop
    Standard Original IBM POST Error Codes
    Code Description
    1 short beep System is OK
    2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem
    1 long, 1 short beep System board problem
    1 long, 2 short beeps Display adapter problem (MDA, CGA)
    1 long, 3 short beeps Display adapter problem (EGA)
    3 long beeps 3270 keyboard card
    IBM POST Diagnostic Code Descriptions
    Code Description
    100 - 199 System Board
    200 - 299 Memory
    300 - 399 Keyboard
    400 - 499 Monochrome Display
    500 - 599 Colour/Graphics Display
    600 - 699 Floppy-disk drive and/or Adapter
    700 - 799 Math Coprocessor
    900 - 999 Parallel Printer Port
    1000 - 1099 Alternate Printer Adapter
    1100 - 1299 Asynchronous Communication Device, Adapter, or Port
    1300 - 1399 Game Port
    1400 - 1499 Colour/Graphics Printer
    1500 - 1599 Synchronous Communication Device, Adapter, or Port
    1700 - 1799 Hard Drive and/or Adapter
    1800 - 1899 Expansion Unit (XT)
    2000 - 2199 Bisynchronous Communication Adapter
    2400 - 2599 EGA system-board Video (MCA)
    3000 - 3199 LAN Adapter
    4800 - 4999 Internal Modem
    7000 - 7099 Phoenix BIOS Chips
    7300 - 7399 3.5" Disk Drive
    8900 - 8999 MIDI Adapter
    11200 - 11299 SCSI Adapter
    21000 - 21099 SCSI Fixed Disk and Controller
    21500 - 21599 SCSI CD-ROM System
    AMI BIOS Beep Codes
    Code Description
    1 Short Beep System OK
    2 Short Beeps Parity error in the first 64 KB of memory
    3 Short Beeps Memory failure in the first 64 KB
    4 Short Beeps Memory failure in the first 64 KB Operational of memory
    or Timer 1 on the motherboard is not functioning
    5 Short Beeps The CPU on the motherboard generated an error
    6 Short Beeps The keyboard controller may be bad. The BIOS cannot switch to protected mode
    7 Short Beeps The CPU generated an exception interrupt
    8 Short Beeps The system video adapter is either missing, or its memory is faulty
    9 Short Beeps The ROM checksum value does not match the value encoded in the BIOS
    10 Short Beeps The shutdown register for CMOS RAM failed
    11 Short Beeps The external cache is faulty
    1 Long, 3 Short Beeps Memory Problems
    1 Long, 8 Short Beeps Video Card Problems
    Phoenix BIOS Beep Codes
    Note - Phoenix BIOS emits three sets of beeps, separated by a brief pause.
    Code Description
    1-1-3 CMOS read/write failure
    1-1-4 ROM BIOS checksum error
    1-2-1 Programmable interval timer failure
    1-2-2 DMA initialisation failure
    1-2-3 DMA page register read/write failure
    1-3-1 RAM refresh verification failure
    1-3-3 First 64k RAM chip or data line failure
    1-3-4 First 64k RAM odd/even logic failure
    1-4-1 Address line failure first 64k RAM
    1-4-2 Parity failure first 64k RAM
    2-_-_ Faulty Memory
    3-1-_ Faulty Motherboard
    3-2-4 Keyboard controller Test failure
    3-3-4 Screen initialisation failure
    3-4-1 Screen retrace test failure
    3-4-2 Search for video ROM in progress
    4-2-1 Timer tick interrupt in progress or failure
    4-2-2 Shutdown test in progress or failure
    4-2-3 Gate A20 failure
    4-3-1 RAM test in progress or failure>ffffh
    4-3-2 Faulty Motherboard
    4-3-3 Interval timer channel 2 test or failure
    4-3-4 Time of Day clock test failure
    4-4-1 Serial port test or failure
    4-4-2 Parallel port test or failure
    4-4-3 Math coprocessor test or failure
    Low 1-1-2 System Board select failure
    Low 1-1-3 Extended CMOS RAM failure
    Feb 19, 2009 | IBM ThinkPad T40 2373 Notebook
    Tricity Bendix AW1400W Front Load Washer Logo
    29 people viewed this question
    Top Tricity Bendix Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
    Charles T Nevin
    Charles T Nevin
    Are you a Tricity Bendix Washing Machine Expert? Answer questions, earn points and help others
