Question about Samsung Televison & Video
My LCD TV has green where ever it is black on the screen or even in people's mouths
My LCD TV has green where ever it is black. When people open mouths there is green also. When we turn the channels between different kid shows we used to adjust the tint and everything else with that. Now that doesn't work anymore
    New Friend:
  • 3 Answers
Try resetting to factory default
Posted on Feb 17, 2014
  • anthony watkins
    anthony watkins Feb 17, 2014
    i swapped out tv's the cables are good its something in the boards i think just not sure which one to replace any help would be good thank you in advance
  • 11 Answers
SOURCE: hitachi 50v500a high definition tv
I had whole redish/pinkish screen on my 50v500 starting a few days ago, then I read through each of the threads on this site for the samilar problems on my model. I found TVtechmaniac's solution (pasted below) solved my problem. Thank you TVtechmaniac!
Enter the I2C Service Menu, be sure the power is OFF.
1. On the front control panel, press and hold the INPUT button.
2. Then press the POWER button for two seconds.
3. You may keep the INPUT button depressed until you see the OSD with the Service Menu displayed.
4. If you don't see the service menu, please repeat Process making sure you wait until the Power blinking LED stops.
5. Execute the Memory Initialize operation after the adjustment values have been written on a sheet of paper. Highlight “MEMORY INTI”, arrow to the right and hold the button to the right (approx 5 sec.) until a check mark appears in the box. This activates the Memory Initialization.
6. After the Memory initialize operation has finished (10~15 sec, the channel will revert to CH 3.) the pink image symptom should be fixed.
7. Write back the adjustment values from your notes to their respective adjustment parameters in the adjustment mode. (In other words, set the Data Values back to the the Data values written down before the Memory Initialization procedure). NOTE: Make sure the SELECT Button is pressed on remote after every change to the values. Failure to do so will result in the data values not being changed.
8. Exit I2C menu. Press exit repeatedly until you go back to the normal picture.
9. Turn the set off-on and Confirm the picture remains in a good condition.
BE SURE TO COPY DOWN DATA SETTINGS BEFORE INITIALIZING I2C SETTINGS
Posted on Aug 31, 2008
phongnv
  • 56 Answers
SOURCE: My 37'' Vizio LCD TV has a green haze and lines on the TV
It is a very simple fix. Replace the LVDS cable will fix it. This cable connect the mainboard to the panel.
Posted on Feb 18, 2009
  • 304 Answers
SOURCE: whole tv has changed to be a very green tint. even
Go to the back of the tv and make sure all of the Component plugs are fully inserted and also on the source Ie: Cable Box or Sat Box,DVD Player.
Posted on Jul 18, 2009
satavlad
  • 405 Answers
SOURCE: all my channels have a green tint on them.
You have not provided any details about your system. What components are in your system? How they are connected? Etc.
Have you tried resetting the TV? Have you tried switching inputs around?
Posted on Nov 22, 2009
  • 92 Answers
SOURCE: Negative type images in pink & lime green
I had the same problem....turned out it was the "lvds" cable that runs from the mainboard to the lcd controller board. Simply remove the tape that holds it to the back of the backlight housing and also remove the foil shielding tape from the connector on the lcd controller board.
Posted on Dec 04, 2009
It sometimes makes a static nose and the picture is dark i have tried messing with the color and back light settings and it doesn't do much
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Jan 7, 2010 - 26 posts - ‎15 authors
Hi, I have a Samsung LN40A550 LCD TV which I have had for just over a year. ... I was watching TV yesterday and all of a sudden the picture went all. ... started makinga very high pitched buzzing sound with no picuture coming on. We did have a bunch of green vertical lines, but now just a black screen.
Samsung LCD Green Screen - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - TV hooked up to basic cable and getting green screen picture. ... I was getting green static in the dark areas and green fuzz down the left hand ... where can you find the white ribbion, i have a lg rt-32lz50. it works sometimes, but i goes green. Samsung LCD TV screen went black (audio on, no picture)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Samsung DLP crackling/static noise
Jun 11, 2015
LCD TV making clicking/cracking sounds
Nov 24, 2006
More results from www.cnet.com
Samsung LCD Loud Noise and Green Vertical lines at Start up ...
www.badcaps.net > ... > Troubleshooting TVs and Video Sources
Feb 03, 2016 | Samsung Ln40e550 40 1080p Lcd Tv ln40e550
When turned on, screen goes black, but power light stays green
It sounds that the main digital board to this TV is faulty. Contact any service technician.
Jun 26, 2013 | Sanyo LCD-42CA9S VIZON MULTISYSTEM 42" LCD...
Dgm ltv-1961wcr tv, when powering up the screen comes on for about a second, then goes black?
It is a Lcd lamp problem or even the lcd panel try to see any reflexion of the image , if u see one is the lamps, if not then is the lcd panel and if it is then is garbage.
Apr 23, 2012 | Digimate Televison & Video
My LG HD tv screen suddenly went green. sound is
I disagree with info provided, if screen of your LG lcd tv becomes green that means inverter board is working and lcd tv does not have convergence ICs.
Please unplug tv from ac wall socket for minute to get it reset, replug back in and turn it On and check its picture.
If still showing green screen then change input source with remote, if tv shows same green screen on all inputs that means its either lcd panel problem or digital signal processor got bad loacted on main board. Local tv repairman is needed to confirm and fix it.
Thanks.
Jul 21, 2010 | LG 42LC2D 42 in. LCD HDTV
Black screen on my rca lcd tv. The green light comes on like the tv is on but no picture at all.
If you can open your LCD tv than open and checked Investor Board connection or replaced
Feb 06, 2010 | RCA L32HD31 32 in. LCD HDTV
HDTV LCD 32 inch is all green. Good definition but all green. Have tried all color adjustments but even turning down the green all the way still leaves a green screen with some red and blue colors in the...
THe most likely cause for this problem is bad connection of the cable connecting the main TV board with the LCD controller. It's called LVDS cable and is hard to miss, usually fat round and black, connecting a board from the chasis with a little board in the top center of the LCD assembly.
I'd open the TV and gently try and reattach the cable to see if that yields any results. You can try it a few times, in fact I'd do it while the TV is open and working so I can better see if adjusting it makes a difference.
There's also a chance that the LCD logic itself got burned and misses on one of the colors. But I don't remember ever seeing that.
Nov 02, 2009 | Vizio VW32L 32 in. LCD HDTV
Hitachi 42edt41green static
Dave you know your stuff man !!! You helped me fix my black line fix on my LCD / Plasma and then now you helped me get rid of my green dots on my screen !! You rock . thanks a Million
Aug 07, 2008 | ViewSonic N3251w 32 in. LCD HDTV
Lcd tv screen stays black, but with sound
just open up the tv 2 the main bord then look for a littler green button press it and then plug it in and it will work i did it 2 mine
Jan 03, 2008 | LG 32LX1D 32 in. LCD Television
Televison & Video Logo
134 people viewed this question
Jerry Greenberg
Jerry Greenberg
