Question about Sony KDL55HX800 55 in. TV
Sony KDA50R550A tv cannot see antenna
I have an antenna attached to my Sony KDA50R550A tv but it cannot see it. It worked yesterday, but not today.
    Top Expert:
  • Sony Master
  • 74,251 Answers
Check and replace its tuner. It is faulty. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Posted on Feb 17, 2014
How can I buy a new antenna for model sony cfm-165tw
Many boombox antennas are attached by a small screw through the pivot point. This is usually a #1 Phillips screw. Some do not have a swiveling antenna; for these you have to remove the back of the case to get at the attachment screw. Keep the screw; it's guaranteed to fit when you attach the new antenna.
The hard part is finding a replacement. If you have the pivoting/swiveling antenna, the Radio Shack 28" Replacement Telescoping Antenna 270-1405 ($5.99 online) will probably work. You might even be able to use it for a non-pivoting antenna that telescopes into the inside of the case.
Jul 22, 2014 | Sony Boombox Am Fm Tv Weather Band...
No TV broadcast picture. Is this a tuner problem?
yes it does seem to be a tuner problem , I also wonder what happens when you use the auto channel finder and tuner usually found in the set up section of the menu ? As well as was your TV working before and receiving input via the antennae but has now stopped working in this regard ? I also noted that attaching an analog to digital converter box worked fine , so your TV is capable of receiving a signal via that method , dose the converter box use your antennae input jack or a video jack to send the converted signal into your TV ? if it is using your antennae jack then it may not be a tuner problem .
Jul 19, 2014 | Sony Grand Wega Kdf-50we655 50-inch Lcd...
I moved and cant figure out how to hook my 4030 channel master antenna up again. I have a converter box and hd toshiba tv
INSTALLATION
Channel Master by PCT indoor antennas are designed to provide optimum reception of
UHF / VHF and FM signals. These antennas have 75 ohm outputs, which allow simple,
hassle-free connections to today's newer TV sets that have 75 ohm F type connector
inputs.
Simply attach one end of the supplied 6' cable with F connectors to the output of the
antenna (Fig.1). Attach the other end of the cable to the input of the TV set or VCR
(Fig. 2). Some adjustment of the antenna might be necessary for optimum viewing.
Model CM-4030 includes a built-in amplifier and separate power supply.
1. Follow the same steps as above for antenna to TV / VCR hookup. Note : Model
CM-4030 also allows for two set / VCR hookups with its unique dual output feature.
2. Insert the power injector into the back of the antenna (Fig. 3). Plug in the power
transformer to the closest electrical outlet (Fig. 4).
Google 4030 Channel Master Instruction Sheet for the PDF File with the diagram.
Fig 2a
Fig 3 Fig 4
prohibido por ley.
TV
Fig 1 VCR
Fig 2
Fig 2a
Fig 3 Fig 4
Jan 10, 2014 | Channel Master 4030 Amplified indoor HDTV...
My parents have given us their Loewe Spheros TV. Yesterday on installation the picture quality was fine, but today is very grainy. We have tried Sharpen and Image+ with no success. Any suggestions?
Hello
you haven't specified here about which connectron method you have adopted with your tV. If it is with outdoor antenna, check the antenna direction. If it is connected with cabel, check the connections at cable ends of firmness. If antenna connections may have sole loose contact, picture will get grainy. OK.
Dec 11, 2011 | Televison & Video
I installed a coby tv in my RV. Auto scan worked great for a year. Today it picks up no channels at all. Everyone else in RV park has 20+ channels. The scan performs everytime, but picks up nothing
If you've tried all positions with antennae, booster switch is on, and are sure you have all settings on TV correct, try running an alternate cable directly from antennae head to back of current plate where your co-ax from antennae is attached. That will tell you if you have a bad cable or connection from antennae to plate inside. Just get a piece long enough to go through door or window to current spot where connected. If that doesn't cure it, then it's a head or booster switch problem. You can even by-pass the booster and go direct to TV to see if any better.
Sep 03, 2011 | Coby TFTV3227 32 in. LCD TV
Problem with auto tune Sony TV
check the setting the of your antenna poor reception will not lock the tuner to it.
Jun 01, 2009 | Televison & Video
Tv reception on handheld Sony Watchman in Feb 2009
The old Watchmans are analog. If plugged into a digital cable/dish system it will scan in UHF and find the working channel than can be conrolled by your digital remote control. As far as taking it out on its own and working off the external antenna...those days will be over. Sony will have to manufacture digital Watchmans.
Jul 07, 2008 | Sony Watchman FDL-22 2.2 in. Television
TV problem
Bad solder connect inside tuner = un- solder tuner from
PC board and solder bad connect or replace tuner with new..
I.F. block next to tuner should be soldered,also.......T.
Dec 08, 2007 | Sony KV-13TR28 13" TV
Sony KDL55HX800 55 in. TV Logo
32 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
