Question about HP Compaq Presario F500 F700 and G6000 Motherboard - 442875-001
Battery/charger battery charges ok,but laptop wont work with just the charger
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 64 Answers
Charger go true a lot of power voltage regulators and in the end is not powerful inought to power loptop without battery, same capasity neaded to help maintain stable curent.
Posted on Feb 18, 2014
I bought a new battery for laptop and it still wont charge
Dell uses proprietary equipment. IF the laptop wont work when plugged in and it is the original Dell charger, you need to check the charger, if the charger wont work then the battery wont charge. Note that it might be the connection on the board inside the laptop especially if the cord got pulled on while plugged into the laptop.
Oct 05, 2015 | Dell Computers & Internet
Laptop runs on battery and charges ok,but wont run just on the charger-hp f700
Feb 17, 2014 | HP Compaq Presario F500 F700 and G6000...
Dell latitude D420 wont charge when plugged in
If the laptop works without the battery, just the charger, the charger is OK.
Jan 13, 2014 | Dell Latitude D420 (DELLD420) PC Notebook
Its plug in but battery wont charge
If your battery will not charge, you need to run a test on some components on the laptop. The battery, the charger and the laptop itself. Once you detect the faulty conponent then you replace it with a new one.
To test the battery:
1.Power off the laptop,
2.Take out the battery,
3.Insert it in another laptop,
4.Check of it will charge,
If the battery holds a charge there, then it means the problem is not from the battery, but if it does not hold a charge, then it means the battery is defective and need to be replaced with a new one.
To test the charger:
1.Unplug the charger from the present laptop,
2.Connect it to another laptop to see if it will charge.
If it charges the laptop, then it means the charger is alright, and if it does not charge the laptop, then it means the charger is bad and need to be replaced.
To test the laptop:
1.Turn off the laptop,
2.Disconnect your present charger,
3.Remove your present battery pack,
4.Insert a well tested battery into the laptop,
5.Connect a well tested charger to the laptop.
If it powers on, then it and charges, then it means the laptop is working fine, but if it does not charge, then it means the connection port of the laptop is bad.Hope this information was helpful.
Nov 28, 2012 | HP Compaq nc2400 Notebook
Aspire 5935 G plugged in not charging 0% aviable
If you are sure the charger is OK, then the possible cause could be the battery or the power jack.Take the battery out, and plug in the charger, if your laptop works, then the power jack is OK, you need to replace the battery; If not, then it proves the power jack is broken, it need to be resoldered or placed. Or you could directly test your battery with a digital multimeter.
Mar 31, 2012 | Computers & Internet
I already replaced my charger once. This is the second time it just wont charge my laptop and it hasn't even been a year since I replaced the last one. What is wrong?
guess the problem is with your laptop battery....chargers normaly dont crack soon.....
charging the battery....is not OK
to sort out the issue
do this...
1 remove the battery from the battery bay....(hope u know how to do that)
2 now connect the adaptor and check if the notebook works....(without the battery in the bay)
3 now remove the adpator and install the battery...check if it now works with just the battery....
4 now connect the adpator to notrbook with the battery in it's bay...start the notebook.....and let it work for some 3 - 5 hrs
5 remove the adaptor...check if the battery immediatly takes over...if not then battery is the issue
Feb 17, 2011 | Compaq Presario CQ60215DX Laptop Charger...
Hi i have some problem to my laptop battery it wont charging, but laptop charger is working fine, my laptop brand is compaq presario C700. i tried to charge my laptop in 2 hours after that i tried to turn...
Did ur laptop works or turn on when u plug the adaptor charger?
If ur laptop turns on when the charger is pluged in, u got problem with ur DYiNG BATTERY!
Better buy a brand new battery!
Nov 08, 2010 | Compaq Presario 700 470024-192 Notebook
New battery wont charge back up
there is a problem with your charger. dell chargers have a habit of blowing. there is a small chip in them that tells the computer that it is ok to charge the batery, that little "safety feature" blows out and will no longer charge your battery. you will have to buy a new charger, either at a store like best buy (make sure it specificly says it is compatible with dell) or go to the dell website to order an "official" one. both options are unfortunately a little expensive, but your only option. i had the same problem with my xps1330.
Jul 19, 2009 | Dell Latitude D500 Notebook
My T42 suddenly wont recharge the battery or wrk off mainsadapter
If the Laptop wont work off the power adepter, it also will not charge. The adepter could be bad (even if showing a power light) or the connector on the laptop could be broken. The best test is to take the battery out, attach the power adepter and try to start the computer if it starts, your battery is at fault. If nothing, suspect eh charger first. Be sure the pin on the Laptop power connector isn't bent or broken.
Jan 04, 2009 | IBM ThinkPad T42 Notebook
Works off mains and battery but wont charge battery.
replaced the circuit board where it meets the battery
Aug 20, 2008 | Dewalt DC011 AM/FM Radio
HP Compaq Presario F500 F700 and G6000 Motherboard - 442875-001  Logo
69 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
