Question about Epson WorkForce WF-7520 Wide Format All-in-One Printer
Epson wf-7520 power light, auto answer light & wi-fi light blink
First the wi-fi would not stay connected so I just used the ethernet connection because the distance was almost to far from one end to the other. Just before we moved the printer would not fubction. The the power light, auto answer light & whi-fi lights blinked locking it up so I could not used the printer. I would unplug it for hours, then days, then weeks we started moving. It sat unplugged from the power source and the ethernet network connection. After several weeks I uninstalled all drivers and epson software. I plugged it in and the this time the lights did not blink. I reset the printer to original factory settings. Oddly when I plugged into the network it spit out several copies we had tried to print weeks before. I went through the fresh install like I had just purchased it. It worked but due to a firewall error unrelated to this between computers on our network, I had to start over once I fixed the firewall error. Everything was fine until I left it try to update the firmware. It required the printer to be turned off and then back on. Now the 3 lights blink-the power light, the auto answer light & the wi-fi light. So I am back to square one and cannot make the lights stop blinking. Any help would be greatly appreciated!
    Problem Solver:
  • 6 Answers
As far as the wifi is concerned, try getting it connected to your home network. Once it gets connected, go into your network settings and try to get the IP address. If you can obtain that, you should be able to add a network printer using TCP/IP port. Also, see if you can factory reset the printer, and start the setup all over.
Posted on Feb 17, 2014
  • Faye Mast
    Faye Mast Feb 17, 2014
    Thanks. One time I was able to reset to factory settings but now all lights blink and will not allow acess to any settings nor can the software see the printer.
I recently moved my epson WF2630 to home from work but it just wont print and keeps saying error evcen though the printer has accepted the home network connection. Any ideas
You did not mention drivers for your computer to talk with the Epson printer. http://www.driversepson.com/epson-workforce-wf-2630-driver/
also check pg 38 on user manual on https://files.support.epson.com/docid/cpd4/cpd40876.pdf
changing wi fi router
what frequency is the wi fi on the printer 5 ghz or dual 5 ghz and 2.4 ghz . to consider !
Jan 25, 2017 | Epson Office Equipment & Supplies
I am trying to scan to my computer from my new Printer EE-2550 Epson printer on Wi Fi and I can not get it going.
Try using your ethernet cable. If it works like that then the problem lies with your wi fi connectivity to computer.
Nov 24, 2016 | Epson Office Equipment & Supplies
Can I use ethernet and wifi together?
No, you can use both type of connection without problem. Ethernet is a direct wired and generally faster connection. Wi-Fi is a via air form of transmission and is highly dependent on how many cellphones and computers are connected at any one time. In airports where I work, this is a big problem. My airport lounge has its own Wi-Fi provided by DataValet for this reason.
When you connect via Ethernet the connection will be used automatically. when you wish to use Wi-Fi, you will choose that in settings. You should only use one, although it isn't going to hurt if your try connecting via both. My guess, is that it will take the best signal.
Nov 11, 2015 | Apple iMac Computers & Internet
Wi Fi printing and Epson Connect print not working
Does the printer print other documents such as a word doc, letter or photo from your desktop? If it still does, then it's the attachment that is the culprit. Check to see if the attachment is an Adobe doc. If it is, you may have to initiate a print command usually found at the bottom of the window (mac) or within the doc itself (pc). It's a guessing game answer since I would need a bit more information from you, but see if this helps.
May 05, 2015 | Epson WorkForce WF-7620 Wireless Color...
Is it possible to connect a standard DSL modem - without Wi-Fi (with 1 Ethernet port) and a DSL modem - Wi-Fi (with 4 Ethernet port) to broadcast Wi-Fi singles
Does the non wifi modem give out DHCP addresses?
Can the wifi modem be set up to receive it's IP address from DHCP?
If the answer to both these questions is Yes then that's what to do as a first step. Make sure the wifi modem DHCP service is disabled as it must NOT give out DHCP addresses.
Connect the ethernet port of the non wifi modem to one of the LAN ports of the wifi modem and NOT the DSL/WAN port. The wifi modem is not participating in any DSL connectivity at all so it's DSL light will remain off. The non wifi modem is doing the DSL duty so it's DSL light should be correctly illuminated.
May 01, 2015 | Computers & Internet
My M800 won't cannot detect any wifi or network and i can't get online
try to connect via lan cable.if u get online then look for wifi switch !
Apr 09, 2015 | Computers & Internet
How to receive fax
Driver (v1.63) 15-Jul-2014 18.36 MBs
  • Version: 1.63
  • Release Date: 15-Jul-2014
  • File Format: EXE
  • File Size: 18.36 MBs
Epson WorkForce WF 3010DW
download and install
Aug 06, 2014 | Epson WorkForce WF-3010DW Inkjet Printer -...
Have a linksys router and adapter not sure how to install, my daughter wants to use her laptop but cant get the internet
Connect your router to computer with ethernet cable.
Then access it with following link.
http://192.168.1.1 or
http://1921.168.0.1
type user name as "admin" and password as "admin" or blank or "password"
Then configure your router as WEP.
Then go to wireless and check that wi fi is enabled.
Then go to wi fi security and add WEP key it is your password to connect your wi fi.
Also enable dhcp if you want get ip auto to computers.
configure your wan settings as your internet service provider like dns ip addrses.
Then save settings and restart the router.
Now go on your laptop first turn the wi fi switch on your laptop .
Then check that your wi fi network adapter driver is proeprly installed.Also check in my network places that your wi fi is enabled.
Then double click on wi fi icon and click on "View wi fi networks."
then connect then enter password which you set in router wep key.
Let me know if you need more assistanse.
Thanks.
Aug 29, 2009 | Linksys Wireless-G WRT54GS Router...
Epson WorkForce WF-7520 Wide Format All-in-One Printer Logo
458 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
