Question about Sony KP-53V80 53" Rear Projection Television
Intermittent sound on Sony KP-53V80 TV
Sound is fine for awhile and then goes off and back on at random
ladywinn
  • 5138 Answers
SOURCE: sony tv model #kp-53v80
you have most likely a shorted hori out out NTE2324 and look around hori there is a 1200pf 2k volt cap that goes bad.I have fixed alot of sonys with this problem.
Posted on Feb 01, 2008
  • 916 Answers
SOURCE: Sony KP-53V80 is not turning on.
4 LED flashes indicated a faulty IC board
Posted on Jan 18, 2009
rockitman187
  • 2559 Answers
SOURCE: I have a Sony Projection
No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted.
Check IC1509, Q1505
Please rate this solution
  • 184 Answers
SOURCE: Sony KP-53HS10 rear proj TV - picture goes on & off
If the adjustment of the screen settings does not fix your problem, its likely that one or more of the CRTs (picture tubes) is defective.
And, the CRTs for these sets are hard to find and expensive.
michtech
Posted on Feb 13, 2009
  • 3 Answers
SOURCE: sony kp-61hs10 tv, has sound but picture goes black after 3 min.
I just had the same problem. If your lucky it might be a free 5 minute fix. The five light flashes mean impropper current. I took the front grill off, then behind that is another black cover, I took that off and noticed the circuit boards COVERED in dust. I then took an air can duster and blew off all the dust... works like new. No more flashes and in an out picture. The collection of dust was interfereing with the electrical current.
Ben
Posted on Jun 22, 2009
My 12 year old Sony KP-53V80 TV suddenly turned off and will not show a picture just a small rainbow at the top of the screen, then a whistling sound, crack and turns back off. can you help?
sounds like the inverter went bad...There's a high voltage device in there that runs the whole "picture" thing. There are capacitors involved with it that have probably failed leading to this mess.. That would be what that "crack" is...If you try to turn it back on does it just "click " and then stay off?
Jun 09, 2012 | Sony KP-53V80 53" Rear Projection...
Lines across screen & no sound
KP 53v80 is way too old to be fixing---recycle it as most landfills will not take that as it has toxic Glycol inside of it.
Apr 29, 2012 | Sony KP-53V80 53" Rear Projection...
Sony model KP-53V80 wont show picture or sound
YOU LOST VERTICAL DEFLECTION THIS WILL REQUIRE PARTS REPLACEMENT
Dec 25, 2009 | Sony KP-53V80 53" Rear Projection...
No sound with with sat but have sound with dvd
First unplug the DVD and plug the satellite in the place where the dvd was. if you get sound the problem is with that particular TV input or the wiring if you get no sound the problem is with satellite. Check the sub volume for the Satellite or call satellite provider for assistance
Sep 30, 2009 | Sony KP-53V80 53" Rear Projection...
I have a Sony Projection TV KP-53v80. I tried to turn it on today bu there is no picture no sound. The Timer/Standby indicator flashes 4 times. What does this mean?
Check IC1509, Q1505
Jan 18, 2009 | Sony KP-53V80 53" Rear Projection...
Sony kp-53v80
Check the 470UF Tank capacitor in the Switching Power Supply.Sometimes when heated,it gives trouble.
Apr 01, 2008 | Sony KP-53V80 53" Rear Projection...
Sony KP-53V80 53 in. Rear...
It's not a digital hi-def tv, so you either need a cable/sat box..or a converter once hi-def goes in and analog stops.
Mar 31, 2008 | Sony KP-53V80 53" Rear Projection...
Sony tv model #kp-53v80
Jan 28, 2008 | Sony KP-53V80 53" Rear Projection...
Sony KP-53V80 53" Rear Projection Television Logo
16 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
