Keyboard on laptop types wrong charcters or no characters when keys are hit?
listeur
  • 88 Answers
SOURCE: Keyboard typing wrong characters
turn off the keylock on boot- this is an option in the bios. also you might be able to use the fn key and turn it off manually
Posted on Nov 24, 2007
  • 136 Answers
SOURCE: emachine laptop Fn key locked
I think the only solution is to phisically remove the key from the keyboard - VERY gently, in order not to break or send flying the pieces to which the key is attached. The little rubber button underneath might be squished below those pieces.
Posted on Oct 27, 2008
  • 135 Answers
SOURCE: Laptop keyboard prints wrong characters
Go to Control panel.
Select Regional and Language Options
In the Regional options tab, select your country and language settings
Click on apply and ok.
You MAY have to reboot for the changes to take effect.
Thanks for using FixYa and please rate this reply if it has helped.
thank you.
Posted on Feb 26, 2009
A+Support
  • 45 Answers
SOURCE: keys on keyboard typing wrong characters
Instructions for Windows Vista
  1. Click Start and then Control Panel
  2. In Control Panel, if you are in Classic View, click on Control Panel Home (top left corner)
  3. Open Clock, Language, and Region
  4. Click on Regional and Language Options.
  5. Click the Keyboards and Languages tab and then click Change keyboards.
  6. Under Installed services, click Add.
  7. In the Add Input Language dialog box, select the keyboard layout you would like to add from the list available and click OK.
  8. The keyboard layout you added will be included in the list. To set the new layout as your default, select it from the list. Click OK to save your changes
  9. You can switch between different input languages (= keyboard languages) by clicking on the Language Bar button or by pressing the Alt + Shift keys
Instructions for Windows XP
  2. In Control Panel, if you are in Category View, click on Switch to Classic View (top left corner)
  3. Open Regional and Language Options.
  4. Click on the Languages tab.
  5. Under Text services and input languages, click on the Details button.
  7. In the Add Input Language dialog box, choose the input language and keyboard layout or Input Method Editor (IME) you want to add.
  8. Click OK twice. You should now see a language indicator in the System Tray (located at bottom right hand corner of the desktop by default). You can switch between different input languages (= keyboard languages) by pressing the Alt + Shift keys
Posted on Apr 11, 2009
  • 96 Answers
SOURCE: Some of my keyboard keys on my new vaio are
hit the num lock key :-) look on the j k and l keys and i bet they also have a 1 2 and 3 on them.same with uiop 456*
Posted on Nov 04, 2009
Testimonial: "Thanks, that was exactly it. I've never had a laptop where the numberlock key did that before. Good to know!"
When you are typing it will type the symbols instead of the letters, you have to keep hitting the function button for the letters to work, sometimes it will work hitting it one time other times you have to...
Hi
Try system restore. Go to START>ACCESSORIES>SYSTEM TOOLS>SYSTEM RESTORE>CHOOSE PREVIOUS RESTORE DATES. Use other restore dates if needed.
Or try this
If your laptop keyboard types wrong characters, it is rather a software issue than an hardware one. This can happen if you accidentally press certain keys on your keyboard, which enable a certain kind of function.
Try the following steps in case your laptop keyboard displays wrong characters:
1.Go to the control panel option
Click ? 'Regional and Language Services' ? 'Languages' ? 'Details' ? 'Key Settings'
2.Select the option 'Switch Between Input Languages' and click on 'Change Key Sequence'
3.Ensure that all the check boxes are unchecked in this window and do the same for 'Switch to...(Keyboard Type)'
4.Click ?
'Ok' ? 'Ok' ? 'Apply' ? 'Ok'.
This should solve your problem
Jun 24, 2011 | Acer Aspire One AOD150-1920 Netbook
My toshiba laptop is typing wrong characters but my wireless tevion keyboard is o k. Is there a solution to this ?
Sounds like the laptop keyboard went bad and thats why its typing wrong characters. Best way to verify this is to use a USB keyboard on the laptop, if the USB keyboard is typing the correct keys then you know the laptop keyboard is bad. If the USB keyboard is typing the wrong keys as well then you know its a setting in windows that is causing the keys to type wrong characters.
Apr 28, 2010 | Toshiba Satellite P105-S9312 Notebook
Keyboard types wrong character
The problem is with your keyboard not with its s/w. if u have installed vista and still the problem remains then it is problem of keyboard. pls rush to nearest service center. don't do much experiment
Jun 15, 2009 | Medion MD-40954 Notebook
When i type characters are missing erratically
Sir try to unplug and plug in the keyboard.
Next try it in safe mode try using MS word,excel,powerpoint and notepad to make sure it is not a software problem.
If ever it is still there try to run the diagnostic for it and choose the diags for keyboard.
^_^
If ever it will not work maybe that needs to be replace already.
and btw try first a different keyboard to see if its not the keyboard problem
May 25, 2009 | Gateway MT3705 Notebook
Screen only displaying keys that are on blue on keyboard
sir if u wants to type the special characters then press the shift key before pressing that button.
Apr 23, 2009 | Dell 0Y3740 Keyboard
The keyboard characters does not correspond to what appears on sc
Does it type " by any chance when you press the @ key? if so this is usually because keyboard input is set to the wrong language in the regional & language settings are wrong in the control panel. try pressing the left alt key & shift at same time first this is a quick key to change between input languages.
Feb 27, 2009 | Dell Inspiron 500m Notebook
Improper charcters
You didn't say what kind of typewriter it is or if it only happens on the symbol keys.
Jul 21, 2008 | Lexmark Wheelwriter 35 Series II...
Nov 22, 2007 | IBM ThinkPad R50e Notebook
Computers & Internet Logo
David Payne
David Payne
