Question about Fisher and Paykel 23 in. DD-603 Built-in Dishwasher
Dishdrawer f2 error - Fisher and Paykel 23 in. DD-603 Built-in Dishwasher
  • Fisher and P... Master
  • 3,247 Answers
This is linked to a rotor problem. Check this video and clean the cavity. If no difference then need to replace the rotor.
http://www.appliancerepairlesson.com/2011/02/25/fisher-and-paykel-dishwasher-dish-drawer-repair/
Posted on Apr 03, 2014
F1 Error code
F1 is flood error. basically water has arrived at the bottom board. you can unplug the dishdrawer, remove the bottom drawer and dry the board at the bottom, maybe with a hair dryer carefully. this will reset the fault, but this is a fault that may appear again. replace the actuators that close the lid of the drawer that is leaking (look for signs of water running our of one of the drawers).
Jul 13, 2014 | Fisher and Paykel DishDrawer DS605FDSM...
F2 error code drawer
In order to find the availability of spare parts for your model of dishwasher it would be helpful if you can provide the Product Code from the label on the front of the main unit.
May 23, 2013 | Fisher Paykel Fisher & Paykel DishDrawer...
Errors and restarts
will need a description of the problem. Some of the common fault codes are F1, F2 and F3.
All these fault codes stop the dishwasher and will not go away until the cause is removed. Please indicate the problem you are experiencing.
Jan 02, 2013 | Fisher Paykel Fisher & Paykel DishDrawer...
Fisher paykel dishdrawer keeps beeping with f1 error
http://www.scribd.com/doc/6462163/DD601V2-Manual#fullscreen
Nov 17, 2011 | Fisher and Paykel DishDrawer DS605FDSM...
Fisher & Paykel Dishdrawer: DD603: Have had motor & rotor assembly replaced - now F-2 code here is goes again. Determined to have husband fix it!! I hope. Company says it is an issue with the...
Hi - F2 error code indicates a failure of the rotor/motor or the sensors, the following notes should give you guys something to check and see which of these has failed..
Error Code - F2
Which LED - Delicate LED
Reasons - The motor has not been sensed rotating
Likely Causes
_ Foreign object has jammed the rotor
_ The rotor has failed
_ The hall sensor has failed
_ The electronic controller has failed
Aug 19, 2011 | Fisher and Paykel 24 in. DD603H W Built-in...
Hey got a set of dishdraws and when ever we turn on it starts beeping and flashing F1
F1 Error is the Flood Switch. This Usualy mens there is a leak that has Triped the flote switch.
There are many things that could be leaking to cause this.
You should have a pro look at this machine.
Aug 11, 2010 | Fisher and Paykel DishDrawer DS605FDSM...
Our F & P dishdrawer keeps coming up with f1 and a picture of a spanner have tried turning the machine of at the switch for 24hr but is still doing it
Water has collected at the base of the dishwasher under the drawer.
This triggers a flood switch and causes the F1 error.
Turn the mains power off and extend the drawer out as much as possible. Take towels to dry the base from inside. Also use hair dryer ot dry out the flood switch mounted at the base.
Turn the power on and see if there is any difference. The cause of water collection could be many. Foam in detergent or kink in drain hose or drawer door gasket leaking etc.
May 11, 2010 | Fisher and Paykel DishDrawer DS605FDSM...
Looking for list of fault codes for dish drawer
I hope this is what you are after
F1 Flood switch has been
activated.
Turn the water and power supply to the
DishDrawer® off and call your Authorized
Service Center.
F2 Motor problem. Call your Authorized Service Center.
F3 Temperature sensor failed. Ensure water coming in through the inlet
hose is not hotter than 65oC. You may
need to install a tempering valve on your
water supply.
F4 Faulty temperature sensor
or element
F9 Electronics malfunction. Call your Authorized Service Center.
U1 Fill Fault 1 Turn the DishDrawer® water supply on.
2 Ensure the spray arm can rotate about
the center, and if the DishDrawer® is
full of water, it will need to be emptied
manually.
3 Call your Authorized Service Center.
May 05, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dual dishdraw bottom Ok, top one wont start cycle,F2 comes up
Try swapping the motor rotors between the two drawers and see if the fault changes drawers, also check for anything stuck under the motors or and damage to the plastic of them. cheers
Apr 12, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel 23 in. DD-603 Built-in Dishwasher Logo
106 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Owen Barnes
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
