Question about Wolfgang Puck Bistro 1700 Deep Fryer
Display reads error and wont heat - Wolfgang Puck Bistro 1700 Deep Fryer
Oven light on display says door and now wont heat
The oven will not turn on the heat because it thinks the door is still open. It thinks the door is open because it has a sensor that gets pressed by the door when it closes (look around edges of oven that get covered when door closes) this sensor is wet, dirty or broken so when you close the door the sensor still says its open. Did you clean around the door with a wet cleaning fluid?
Dec 20, 2013 | Whirlpool GBS307PRS Stainless Steel...
I have a Whirlpool gew9868kl3 dryer. The dryer only clicks when you try to start it. I did the diagnostic check on it and I do not come up with any errors. I did however find two things during the check...
one of 3 things can be wrong 1) make sure on an electrically heated element dryer that you have 240 volts,because if not either the timer or motor wont turn and it will not heat without 240 volts,2) if you can hold the start switch in the start position and you can hear the motor running then its a broken belt and there is a switch on the idler pulley tensioner bracket to stop the motor so if the drum wont turn the unit also wont heat to protect against overheating clothes starting a fire. 3) if no sound then either the motor switch is bad or there is a wire off the motor start switch which is very common due to vibration
Apr 12, 2011 | Whirlpool GEW9868K Electric Dryer
Wat is an LSU error on a phaser 3200 MFP
Change the toner cartridge , i have many units phaser3200 and this is one of the problem , but only if the toner cartridge is very old and many time refilled , if not , change the Laser unit .
  1. Remove a misfed document if the copier displays a message reading "Document Jam." Lift up the document feeder cover and turn the roller to remove an Exit Misfed document. Lower the document feeder back into place and feed the document through again. If the document is jammed on the Input side, open the cover and gently pull the misfed document to the right and out of the feeder.
  2. Pull out the paper tray and lift the tray to release it from the copier if the copier displays a message reading "Paper Jam O." Remove the jammed document, and open and close the side panel of the copier to clear the error message.
  3. Unplug the power cord and plug it back in again if the copier displays a message reading "Fuser Error, Open Heat Error, Heating Error and Overheat." If the problem persists, call for a service.
  4. Remove the toner cartridge and shake it from side to side if the copier displays a message reading "No Developer Cartridge." If this does not do the trick, you may need to replace the cartridge. Pull the release latch to open the side cover, and open the front cover. Twist the cartridge locking-lever upwards and remove the toner cartridge. Insert the new cartridge and lock the lever into place. Shut the front cover and the side cover.
  5. Power off the unit and power it on again if the copier displays a message reading "LSU Error." A problem has occurred with the Laser Scanning Unit. If the problem persists, call for a service.
Jan 04, 2011 | Xerox Phaser 3200MFP/N Laser Printer
Our whirlpool dishwasher ADP 7408 is displaying a F3 fault and wont work. What is the problem?
F3 error fault code
The heating cycle is not working. The error is indicated after several electronic checks are done over a 25 minute period. Therefore if the heater heats too slowly or the heater is open circuit or indeed the electronic control PCB is defective, each of these will indicate F3. The twist is, if the NTC is fluctuating in its reading it also can indicate F3 and not F1.
Nov 14, 2010 | Whirlpool 33 in. ADP6830 Free-Standing...
F-05 flashing on the display screen
Hi There
I have this for to read and hope this helps out. Let me know how this works out.
F/05 Water Temperature Sensor Error
If during the water heating step in wash cycle, the water temperature sensor (NTC) value is out of range, or the heating element circuit has failed, the "F/05" error code will be displayed.
  • Check the Water Temperature Sensor, Heating Element and Element Relay
  • Check connections to the Sensor, Heating Element and Relay
Thank you for writing to fix ya.
Best Regards Richard
Dec 28, 2009 | Washing Machines
Error code 126
This is a bad thermister or heat sensor. It mounts in your water manifold and if it goes bad no error will show. The bad sensor is telling the heater that the water is to hot and it wont let the heater fire. This is a farley inexpensive part and easy to change out. With a new one it should read the proper temp and call for heat then fire the heater. Good luck.
Jun 17, 2009 | Sta Rite Sr400na Max E Therm Pool & Spa...
Help with correcting fault code f-5
F-05 error means:-- Water Temperature Sensor Error
TO RESOLVE THE PROBLEM:--
Check the Water Temperature Sensor, Heating Element and Element Relay globul1a.gif Check connections to the Sensor, Heating Element and Relay
May 07, 2009 | Washing Machines
Wont read disc-error message HO7
check out this link I think this information will help you. http://www.ledcar.com/pdvdh07/
Sep 17, 2006 | Panasonic DVD-CV47 Multi-disc DVD Player
Kitchen Appliances - Others Logo
24 people viewed this question
Top Wolfgang Puck Kitchen Appliances - Others Experts
Steve
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Wolfgang Puck Kitchen Appliances - Other Expert? Answer questions, earn points and help others
