Question about SaniServ 707 Frozen Drink Slush Margarita Machine 1 Head
Saniserv 707 The last time I had the machine in operation, I filled the reservoir to capacity (usually only add 1-2 gallons). During operation (and it did freeze), there was excessive vibration and grinding noise. Additionally, the machine became very warm to the touch. Was wondering if this were a bearing issue that I could "easily" (and without breaking the bank) resolve.
I HAVE A TOGGLE SWITCH ON THE BOTTOM OF MY MACHINE. WHATS IT FOR???
I have been unable to locate the toggle switch in a SaniServ Operational Manual located HERE , I suggest you call and ask Saniserv what this toggle switch is for 800-733-8073
Thumbs up if this helped!!!
Jun 21, 2011 | SaniServ 401 20 Quart Ice Cream Maker
I have a saniserv 707a and the product won't freeze. The refrig line is freezing right after compressor switch.
my saniserve ice cream machine will not get freeze hard or freeze when u press the button on for the compressor to kick , it will not kick in.
May 12, 2010 | SaniServ 401 20 Quart Ice Cream Maker
Looking for a manual for my Saniserv 407. Any info would be VERY appreciated!
I was able to get you a phone number where you can inquire about the manual you need 1-866-892-6344 and a website that sells this product.
http://www.instawares.com/saniserv-soft-serve-ice.ssm-407.0.7.htm
it appears to be distributed by a third party called instawares. good luck
Dec 29, 2009 | SaniServ 401 20 Quart Ice Cream Maker
Same Machine
In the 1990s SaniServ manufactured soft serve ice cream makers for slush puppy Corporation and call it freeze bee model A 501 which is the same machine as SaniServ model 501...........
if you go to www.saniserv.com or call their phone number at 317-831-7030 and give them your serial number they will give you all the information you need, when inquiring ask for technical help.
I have one and I really like it, does a great job, you need to fine the saniserv dealer closest to you for parts and supplys, they have everything you need.
Bob aviator state of Maine
Aug 31, 2009 | SaniServ 501 Twist 22 Quart Ice Cream...
Press the switches and nothing turns
Contact the manufacturer.
This sounds like something that you may have to get repaired (or, if not, the manufacturer usually knows all the little tips and tricks to get it working! :)).
Their contact number should be either stamped somewhere on the machine or in the product manual (usually near the back of the book). If you still can't find it, you can usually just do a quick internet search (just typing in the manufacturer name--in this case, "SaniServ"--and then "support" into Google usually helps).
Good luck! :)
Aug 22, 2009 | SaniServ 407 10 Quart Ice Cream Maker
Saniserve 707a margarita machine
The best thing to do would be to recover the 404a into a clean recovery jug,weighing how much you take out. Check the nameplate on back it will tell total ref charge. in either oz or lbs. then weigh the charge back into the unit. this is the best wayto verify if you have a proper charge.If the unit is low on charge then you will want to find and repair the leak as soon as possible.
Jul 13, 2008 | SaniServ 401 20 Quart Ice Cream Maker
I need a manual
Couldn't find a manual for you.
But i found a link to SaniServ to contact them for techincal support:
http://www.saniserv.com/contact.jsp?p_=&go=no&form=4
Hopefully they can tell you how to fix your machine.
Good Luck
Apr 16, 2008 | SaniServ 501 Twist 22 Quart Ice Cream...
What brand compressor do saniserv use
Depends on the unit, goto to www.saniserve.com ,they can tell you the exact compressor by the model and serial numbers.
Feb 26, 2008 | SaniServ 401 20 Quart Ice Cream Maker
Opertational Manual for SaniServ 401 1A (20 Quart)
I called:
A Service Provider
(305) 279-9544 Office
but don't tell sani-serv. They are anti-DIY and will politely try not to help you.
Oct 13, 2007 | SaniServ 401 20 Quart Ice Cream Maker
SaniServ 707 Frozen Drink Slush Margarita Machine 1 Head Logo
41 people viewed this question
Top SaniServ Ice Cream Makers Experts
Dennis Boxerman
Andrew Taylor
Andrew Taylor
Are you a SaniServ Ice Cream Maker Expert? Answer questions, earn points and help others
