Question about Embark Queen Pillow Top Double High Air Mattress
Need a replacement valve cap for an Embark Queen air mattress
Where can I get a new one mattress has been used once and the cap is misplaced. Would like to find one ASAP !!
  • Barbara Frazier Mar 04, 2016
    Why is my air mattress started to inflate on both sides
I went to dirt cheap yesterday and purchased a Embark Air Mattress and once I got it home I discovered that the mattress didn't have a valve cap. I want to know if you could replace the cap without any cost? If you would like to send me one here is my address P.O. Box 282 Blue Mountain Miss 38610 Thanks for your help
Posted on Jun 16, 2015
Why do I need a mattress protector?
If you want to keep your mattress clean for a long time and want it to prevent from damage, you should use a mattress protector or you can say mattress toppers.
These toppers would help you to protect your mattress dirt free and keep it away from damage caused by wear and tear.
If you want to have a best high-quality mattress topper to make your bed more attractive, you can prefer Top Rated Mattresses.
They would provide you an amazing collection of mattress toppers made up of high quality materials at best offers.
Feb 08, 2016 | Furniture
Tip
Buying a new mattress can be a long and exhausting process.  Do not let it...
Buying a new mattress can be a long and exhausting process. Do not let it overwhelm you. I am here to provide you with some great tips that will help you find the best mattress for you. Before heading out to the shop ask yourself a few questions. How long do you want the mattress to last? What is your budget? What type of support do you need? Once you have a basic idea of what you need out of a mattress, you are ready to head out to the stores. Here are a few tips that I truly believe are worth following:
Talk to your doctor - although not a sleep expert, your doctor may be able to guide you towards a certain style/firmness of mattress that will best suit your body
Check the warranty
Test drive your mattress - when you go mattress shopping make sure to wear comfortable clothes (similar to pajamas) and spend 10-15 minutes lying on each mattress you sample the same way you would sleep at home (if you sleep on your stomach, then lye on your stomach in the store). Do not let the salesperson rush you; finding the right mattress will take time.
Shop at mattress stores - try to limit your search to mattress specific stores as opposed to department stores/online (DO NOT BUY A MATTRESS ONLINE)
A mattress is a purchase that should not be taken lightly. Although they can be quite expensive, whatever you do, DO NOT risk comfort for a cheaper mattress.
on Aug 28, 2012 | Furniture
Northwest queen air mattress
You can always make a plug. Get a piece of clear vinyl tubing about 1 inch long. The inner diameter of the tube should be the same size or just a bit wider then the width of the mattress plug your missing. Get a small tube of clear silicone rubber (make sure its pure silicone rubber) and completely fill the vinyl tube. Let it sit for 4 or 5 days to completely dry. Cut off the vinyl and your new plug emerges! Use your scissors to cut the tip at an angle so its easier to get it into the mattress tube.
Mar 24, 2015 | Vacuums
How do I deflate my air mattress?
Some pumps come with a deflate setting so make sure to check that first. If not, you need to unscrew the cap off the valve and listen to hear that air is escaping. Then remove your shoes and walk up and down the surface of the mattress. Once you have done this a few times, you will be able to roll up the mattress from the end opposite the valve.
Jul 31, 2012 | Camping, Backpacking & Hiking
What is the best way to shop for a new mattress?
Before you even leave your house, I suggest you understand your needs first. Think about your body and how you sleep. Once you are ready to start testing out mattresses, make sure you go to the store in comfortable clothing. If pajamas were socially acceptable that would be the best! Take your time and lie down on each mattress comparing the feel. Evaluate the level of comfort and support of each mattress you try. Don't be embarrassed to spend several minutes lying on the mattress in the position you usually sleep in. If you pay close attention, you will notice slight differences and start weeding out mattress that you find less comfortable.
Jul 25, 2012 | Furniture
How to prolong the life of my mattress?
In order to prolong the life of your mattress you should try and keep the following.
1) Using a mattress pad or a protective cover will help you avoid stains.
2) Use a good and quality bed frame
3) Try to avoid jumping or standing on the edge of your mattress in order to eliminate bends
Jul 18, 2012 | Furniture
How do you deflate the northwest territory queen size air bed
I was confused by this too. Here's the trick:
When you inflate the mattress, you unscrew the square-shaped plastic cap, like this:
But this is *not* the cap you unscrew to deflate it!
To deflate it, you have to unscrew the plastic at the *round* part that's beneath the square cape -- i.e. the part of the plastic that's affixed directly to the mattress. When you unscrew the round part, the entire plastic apparatus detaches from the mattress, leaving a big open round hole where the air rushes out.
It looks like this:
Jan 06, 2012 | Baby Gear
I cannot find a manual for a blue magic super pump
See the instructions near the bottom of this web page: (picture at the top of pasted instuctions on th link)
http://www.abcwaterbed.com/pump2.htm
  1. IMPORTANT! - Unplug waterbed heater for safety
  2. Remove cap and seal and put aside in safe place.
  3. Remove any excess air from mattress - slide forearm or broom handle from the head of the bed toward the fill hole to move air pocket
  4. Attach the heavy duty hose to the hose valve coupling, connect to the waterbed mattress and other end to the pump intake side. Be sure to include O-rings. Gently push the coupling deep into the mattress.
  5. Attach garden hose to the discharge side of the pump, this hose goes to a tub, or a deep sink.
  6. Plug in the pump. When it starts it should have a low whirring sound, not a high whiny one. If water is not pumping immediately unplug the motor and check hose connections for tightness, verify there is no air in the mattress.
  7. As the pump removes the water, be sure the hose valve coupling at the mattress is pushed down in the mattress to maintain suction. Heavy phone books or other like items will help maintain proper position deep in the mattress.
  8. Keep pumping the water out and continuing to maintain the hose valve coupling position low in the mattress so it can keep pumping.
  9. Do not leave the pump or the area until finished. A dry pump can burn up.
  10. When the mattress is part way empty, you can place pillows under it at the head to help the water run downhill towards the hose valve coupling.
  11. Continue pumping until water flow stops or pump changes sound. The more water you get out, the easier your mattress will be to handle.
  12. If you are satisfied you have got as much water out as you can, remove the hose valve coupling and quickly replace the mattress seal and screw the cap on.
  13. If the mattress is to be stored for a period of time, pour in a large bottle of waterbed conditioner into the mattress before you cap and seal the mattress.
  14. We recommend rolling up the mattress from the head to the foot and carefully sliding one end into a wardrobe box. Another wardrobe box can be worked over the top of the mattress. Work one box into the other and seal both ends and tape the boxes together in the middle. You can now safely move the mattress.
  15. If you don't get enough water out, the fiber layers can easily slide out of position during moving and you may not be able to get them back into position when you fill the bed.
Nov 18, 2010 | Magic Pool & Spa
I need to clean my Mattress
You just use the small handle (in your attachment caddy) with the upright machine. No other attachments or hose is necessary.
Sep 01, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Embark Queen Pillow Top Double High Air Mattress Logo
3,428 people viewed this question
Top Embark Camping, Backpacking & Hiking Experts
ray gallant
Bill Boyd
james laughton
james laughton
Are you an Embark Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
