Question about Vehicle Parts & Accessories
Rack and pinion - Vehicle Parts & Accessories
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 34 Answers
Yea- they all leak and are almost all noisy
Posted on Feb 17, 2014
Rack and pinion removal
remove the left and right tie rod ends from the from the pivot arms , remove power steering oil lines, remove steering wheel shaft to rack pinion clamp, with wheels in straight ahead position remove rack hold down fittings, slide pinion off steering shaft and remove rack.
Jul 10, 2015 | 2002 Buick Rendezvous
Rack & pinion steering replacement
DISCONNECT TIE RODS ENDS FROM WHEEL HUB, DISCONNECT POWER STEERING HOSE FROM RACK AND PINION, DISCONNECT RACK AND PINION FRON LOWER ENGINE COMPARTMENT
Feb 19, 2014 | 2003 Chevrolet TrailBlazer
How can transmmision fluid leak from rack and pinion
No, no, it just can't. Only power steering fluid goes in and out of the rack and pinion. Transmission fluid travels through the cooler lines (a supply and return line) to the radiator or a separate cooler in front of the radiator. Check again. Is it transmission fluid or power steering fluid? Transmission fluid may be leaking onto the rack and pinion.
Mar 15, 2013 | 2006 Nissan Altima 2.5
How to remove rack and pinion from 99 chrysler lhs
There are few help links showing exact accurate procedure to replace Rack and Pinion. Click the link below and follow the procedure:-----
Pinion Seal Replace on Dodge Dakota? http://howtobyme.blogspot.in/2012/04/pinion-seal-replace-on-dodge-dakota.html
How to Replace a Rear Pinion Seal.
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-rear-pinion-seal.html
How to replace Power steering rack and pinion gear on Chevy Silverado 2500 HD? http://technoanswers.blogspot.in/2012/02/how-to-replace-power-steering-rack-and.html
How to replace Power Rack and Pinion Steering Gear on Acura Car Models? http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-power-rack-and-pinion.html
How to replace power rack and pinion steering gear on Toyota cruiser? http://repairhelpcenter.blogspot.in/2012/02/how-to-replace-power-rack-and-pinion.html
Front Drive Pinion Seal Removal on Ford Explorer? http://repairhelpcenter.blogspot.in/2012/03/front-drive-pinion-seal-removal-on-ford.html
How to Replace Driveshaft, Pinion Flange & Seal?
http://repairhelpcenter.blogspot.in/2012/03/how-to-replace-driveshaft-pinion-flange.html
How to Replace Power Rack & Pinion Steering Gear On 2007 Ford Taurus? http://repairhelpcenter.blogspot.in/2012/03/how-to-replace-power-rack-pinion.html
How to Remove Power Rack & Pinion Steering Gear on Ford Windstar? http://repairhelpcenter.blogspot.in/2012/03/how-to-remove-power-rack-pinion.html
Power Rack & Pinion Steering Gear replacing details for Buick Park Avenue and Pontiac Bonneville
http://repairhelpcenter.blogspot.in/2012/03/power-rack-pinion-steering-gear.html
How to Replace Power Rack & Pinion Steering Gear on Mercedes Benz Truck? http://howtobyme.blogspot.in/2012/03/how-to-replace-power-rack-pinion.html
How to replace Power Rack & Pinion Steering Gear on Toyota 4Runner? http://howtobyme.blogspot.in/2012/03/how-to-replace-power-rack-pinion_27.html
Power Rack & Pinion Steering Gear Replacing on Toyota Land Cruiser & Sequoia? http://schematicsdiagram.blogspot.in/2012/03/power-rack-pinion-steering-gear.html
Power Rack & Pinion Steering Gear Removal on Toyota RAV4? http://repairhelpcenter.blogspot.in/2012/03/power-rack-pinion-steering-gear-removal.html
How to Replace Power Rack & Pinion Steering Gear on Toyota Sienna? http://technoanswers.blogspot.in/2012/03/how-to-replace-power-rack-pinion.html
These details will help.
Thanks.
Nov 23, 2012 | Cars & Trucks
99 Olds alero will only turn to the right. On quick inspection found that the rack and pinion moves with turning the wheels. Is it supposed to?
The whole rack & pinion does NOT move! Only the rod out of either end of it. If the main body, where the hoses connect, is moving the mounting bolts are missing, or broken.
Normally any vehicle with rack & pinion steering, that will not turn left equals a bad rack & pinion.
The "wont turn left" is the classic industry wide indicator that the rack & pinion is worn out.
Aug 21, 2011 | 1999 Oldsmobile Alero
A little play in rack and pinion
IF RACK GOES OUT YOU HAVE EXCESSIVE PLAY IN THE STEERING DUE TO WORN RACK..OR POOR RETURN OF STEERING WHEEL TO THE CENTER.BEFORE BUYING A NEW RACK PINION.CHECK RACK MOUNTING BOLTS FOR LOOSENESS.CHECK RACK PINION MOUNTING GROMMET.ALSO CHECK FOR LOOSE WORN TIE ROD ENDS.IF WORN THEY WILL CAUSE PLAY IN STEERING WHEEL.
Jun 19, 2010 | 2000 Chevrolet Blazer
Changing rack and pinion. how do it out of there?
You have to drop the rear subframe down to remove the rack and pinion
Apr 18, 2010 | 1999 Ford Taurus
95 Olds Achieva steering just ceased up tonight with no warning. Could it be that it is low in fluid?
If it is hard to turn it could be the fluid is low. If you can't turn the steering wheel go underneath the lower rack and pinion right were the steering shaft bolts to the rack and pinion there should be a round silver cap looks like a plug if that cap is missing the pinion bearings are broken and the rack and pinion are locked up replace your rack and pinion
Jun 18, 2009 | Jaguar S-Type Cars & Trucks
Rack and pinion or steering kit
your vehicle has a transverse mounted engine and most newer vehicls have rack and pinion steering versus a shaft going to a gear box with a drag link and sway bar type steering system. most full size suvs have the gear box set up. some suvs like dodge durango have both a gear box and a rack and pinion. your vehicle has only the rack and pinion
Apr 19, 2009 | 1997 Chrysler Concorde
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
