Question about Microwave Ovens
Microwave won't heat. Says enter code - Microwave Ovens
Microwave won't heat food
9 out of 10 times if all else is working then it is the magnatron rod that does the heating chances are it will be more expensive than to purchase a new microwave.
Feb 14, 2013 | Microwave Ovens
This is very likely a faulty Magnetron especially as there is not heat. To repair this would mean replacing the Magnetron which is a fairly standard repair for a Microwave oven
Nov 26, 2012 | Microwave Ovens
The problem is in the magnetron or the inverter board if 7 years old or less.
May 25, 2012 | Cuisinart CWM-100 Microwave Oven
Sounds like the magnetron has failed. :(
May 18, 2012 | GE Microwave Ovens
Panasonic Inverter microwave with code H97, won't heat
The problem is in the magnetron, or the the inverter board.
Apr 15, 2012 | Panasonic Microwave Ovens
Whirlpool microwave hood combination won't heat
There are three common issues, the magnetron "heats food" a cracked high voltage diode, a shorted high voltage capacitor.
Mar 10, 2012 | Whirlpool Microwave Ovens
I have a GE Profile Spacemaker 2.0, MOD Number: JVM2070SK02 Last week the thing stopped heating anything. Sounds fine, but won't heat. Any tips?
okay thats sounds like you have to take your microwave to a repair man.the HV capacitor can be open or the magnetron is bad these 2 components i mention are responsible for the heating of your microwave if they go bad..then your microwave wont heat.good luck.
Sep 23, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
AMANA MICROWAVE RFS-12SW2 from subway. I have 3 broken microwaves. and repair guys won't change parts to fix. so i am willing to change it myself. one of them has no heat. two of them doesn't...
AMANA MICROWAVE RFS-12SW2 from subway. I have broken microwave. and repair guys won't change parts to fix. so i am willing to change it myself. one of them has no heat.. any help and manuals? thank you
Jul 24, 2011 | Microwave Ovens
Won't turn on after disconnecting the power code from the wall socket,
Press stop / cancel
Then press Clock
Enter time
Press clock.
It should now be working normally. If not respond here again and I will help you.
Thanks for choosing FixYa,
Kelly
May 12, 2011 | Whirlpool MH6150XM Microwave Oven
Microwave display flashing & beeping.
You have a failed membrane keypad.
On this model, GE doesn't make any parts available except the tray and the roller.
If it's in warranty, they will exchange or repair it.
It it's out of warranty, you're out of luck.
I'd advise you to contact GE Customer Service in case they may be able to help you.
Jul 25, 2010 | GE JES1036PWF 1100 Watts Microwave Oven
Microwave Ovens Logo
20 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
