Question about Christie CP2220 OEM Projector Lamp
Chirstie CP2220 The lamp start only manually
The lamp never start Automatic when Doremi send the message to start, we have to start the lamp manually and then everything is OK. Please Advice, Thanks Claudio
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 729 Answers
Any questions, feel free to contact me
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
have a nice day!
Jerry,Lampdeng Limited
skype:lampdeng
Posted on Mar 21, 2014
  • Lampdeng.com
    Lampdeng.com Mar 21, 2014
    sorry,I was make a mistake:my skype is not lampdeng. my skype is : lampdeng@hotmail.com
My reverse lights and my brake lights will not work with the anti theft light on in the dash
These lights are all computer controlled ! Several modules involved DIM - dash integrated module , RIM - rear integrated module .They share information on serial data communication network . Class 2 an or GMLAN !
The rear fuse block supplies battery positive voltage through the REVERSE LAMP fuse to the coil and switch terminals of the reverse lamp relay. The DIM sends a power mode message to the RIM indicating that the ignition is in the ON position. When the driver of an automatic transmission equipped vehicle places the gear selector in the REVERSE position, the powertrain control module (PCM) sends a class 2 message to the RIM. The message indicates that the gear selector lever is in the REVERSE position. When the driver places a manual transmission equipped vehicle in reverse the reverse gear position switch mounted on the transmission closes. This provides a ground for the reverse gear position switch signal line, informing the RIM that the transmission is in reverse. For both automatic and manual transmission vehicles the RIM then grounds the control circuit of the reverse lamp relay . This energizes the reverse lamp relay, closing the switch side contacts and providing battery positive voltage to the backup lamp bulbs. The backup lamps are permanently grounded at G402. With both power and ground the backup lamp bulbs illuminate. Once the driver moves the shift lever out of the reverse position a message is send either by class 2 by the PCM or the reverse gear position switch opens causing the RIM to remove the ground from the reverse lamp relay control circuit. This opens the contacts in the relay turning OFF the backup lamps.
This is something best left to the dealer or a ASE certified repair shop . Need a factory or professional grade scan tool to diagnose an repair this . http://www.public.asu.edu/~pheanis/documents/VBI_CAN.pdf
Feb 20, 2016 | 2006 Cadillac CTS 3.6
Why don't lights work?
Both the headlight switch and the BCM provide a ground, or control circuit, to the headlight relay coil circuit for manual or automatic headlamp operation. When you place the headlamp switch in the OFF position, and the ambient light sensor indicates low light conditions, the BCM energizes the headlamp relay for low beam operation. You may switch the headlights to high beam by pulling the dimmer switch handle toward you until the dimmer switch is activated. When the dimmer switch is placed in the HIGH position, the indicator lamp input to the BCM is pulled low. The BCM then sends a class 2 message to the instrument cluster in order to illuminate the high beam indicator lamp.
Low and High Beams Headlamps Inoperative ?
Replace the headlamp switch. Refer to Headlamp Switch Replacement .
Did you check the headlamp relay ? Location ,left instrument panel
Did
Nov 11, 2015 | 2001 Chevrolet Monte Carlo
On my 1999 jeep wrangler [2.4L- 5spd] a circle w/a key in it appears on the upper left of the dash & it will start/run for a few seconds then shut down
i would think that it is an immobilizer symbol letting you know of a problem with the key in use
talk with a service dealer or have the fault codes read to see if there is an immobilizer fault
Nov 08, 2015 | 1999 Jeep Wrangler
My multimedia message sending fails and message displays check settings.
Probably you are yet to configure your MMS settings. You can do that through your GSM service provider (automatic/manually).
Best regards
Jun 11, 2011 | Cell Phones
I have a sony kds60a3000 projectin tv. when i turn the tv on there is a message that says "your projection lamp is nearing the end of it's life." Should I order a new one now? how long do you think it...
You should order a new one and wait for the other one to **** out first. The automatic message is to make Sony more money.
Shop around on the web for the lamp.
Some places are 2-3X more than others
Oct 04, 2010 | Sony LAMP BLOCK XL2100U Projector Lamp
How do i change outgoing answer phone message
Solution for Fax1360, if this does not work please let me know as this process should be the same.
Recording an outgoing message (OGM) on an external TAD 7
Timing is important in recording this message. The message sets up the ways to handle both manual and automatic fax reception.
a Record 5 seconds of silence at the beginning of your message. (This allows your machine time to listen for the fax CNG tones of automatic transmissions before they stop.)
b Limit your speaking to 20 seconds.
c End your 20-second message by giving your Fax Receive Code for people sending manual faxes. For example: 'After the beep, leave a message or send a fax by pressing *5 1 and Start.'
Recommendation: recommend beginning your OGM with an initial 5-second silence because the machine cannot hear fax tones over a resonant or loud voice. You may try omitting this pause, but if your machine has trouble receiving, then you must rerecord the OGM to include it.
Christy
Sep 26, 2010 | Brother Inkjet Fax Machine Fax1460 Plain...
Mitsubishi HC900 Projector shuts down after 5 minutes.
You have 1 of 2 possible problems.
(1) You need a new lamp.
(2) You have an overheating problem.
Just a quick couple of notes about your projector. It is a DLP projector (not LCD) and as such the machine as no air filters to clean. It does have air intake and air exhaust grilles, but no air filters to clean. This next part comes directly from the owner' manual for your projector:
When the lamp operation time exceeds 2000 hours*1 *2, the projector automatically shuts off and can’t be used until the lamp is replaced and the lamp operation time is reset.
Your machine is designed to give visual warning messages at 1500 hours used, and 1900 hours used. Did you see any visual warning about lamp life over the past few months?
If you were experiencing an overheating problem, a "TEMPERATURE!!" message would flash up on the screen just before the unit shuts down. If there is no warning, you don't have a heat problem.
If you have a replacement lamp available, install it and reset the lmap hours according to your user manual. If you don't have the manual, google it on the web (it available).
Apr 01, 2009 | Mitsubishi HC900 Multimedia Projector
We have used 1999 Jeep GCL. Key will not turn, nor can be removed. Purchased a used steering column @ salvage yard. Vehicle is at a repair shop. He replaced the steering column, started car, it runs for a...
you know the fuel pressure regulator could cause your vehicle to shut off after a few sec but then you should be able to start it a few secs later then it will do the same thing..computers can be reset unless they are burnt out..
Dec 04, 2008 | 1999 Jeep Cherokee
Automatic power shut off
Hold right left and power all at the same time and it will reset...
Jul 23, 2008 | Mitsubishi XL1XU Multimedia Projector
Christie CP2220 OEM Projector Lamp Logo
95 people viewed this question
Top Christie Office Equipment & Supplies Experts
jasbo
jasbo
Lawrence Oravetz
Are you a Christie Office Equipment and Supply Expert? Answer questions, earn points and help others
