Question about Empire DV-215 Direct Vent Natural Gas Heater
How to replace or fix a gas valve for empire dv215
Cant get pilot lit
  • 252 Answers
SOURCE: pilot won't stay lit
Your unit has a "vent safety limit switch" which is a high temperature limit. It gets hot enough to trip over time because you do not have proper venting. It is a safety switch and SHOULD NOT be disabled - instead find and fix the venting problem(chimney bad?)!
Posted on Mar 27, 2009
  • 3280 Answers
SOURCE: 18000btu ventless empire heater lights and burns
Hi clean out tiles with air line clean pilot / if still goes out check thermocouple
Posted on Feb 12, 2010
  • 28 Answers
SOURCE: my empire heater wont turn off and just keeps
Sounds like the thermostat for the blower motor (not the gas thermostat) has shorted. Remove front cover on stove. Follow the wires from the blower motor back to the blower thermostat. Replace with new one. Blower model # DRB-1.
Posted on Dec 04, 2010
  • 120 Answers
SOURCE: PILOT FOR EMPIRE WALL HEATER WONT STAY LIT. I HAVE
are you sure the problem is with the thermocouple? is the pilot sharp and blue? it is unconnon for the magnet in a gas valve to go bad but it does happen. place the thermocouple in the valve and with it in front of you heat it with a match or lighter for 30 sec. now try and light the pilot quickly. if it lights the the problem would be the pilot, if not then the valve. is this a milivolt system or hydrolic t stat.
Posted on Jan 29, 2011
  • 4736 Answers
SOURCE: need a gas valve for
Being an ECS dealer, I'm not aware of a recall. The following link will give you a list of master parts dealers that you should use, if your heater is no longer under warranty. Select the one closest to where you live. http://www.empirecomfort.com/EMPIRECOMFORT/pdf2010/forms/Master-Parts-Distributors.pdf
If your heater is still under warranty and you still have your Proof of Purchase. Order the part through your local Empire Dealer.
Hope this helps you get the gas control valve you need.
Posted on Apr 15, 2011
Can't light pilot due to breeze coming out of unplugged gas wall heater
It sounds like you have a direct vent heater so you have to take off a pilot access cover to light the pilot. So what happens is the draft coming out of the cover is blowing out the match before you get it in the hole. The trick is to get the match or lighter in the hole quickly as possible so the pressure inside the heater will equalize and the match will stay lit. Then you should be able to lite it. Get it inside the hole fast and it will work. Don't forget to put the cover back over the pilot access or the draft may cause the pilot to go back out.
Feb 10, 2018 | Empire Heating & Cooling
Empire wall furnace pushing down the pilot button trying to light the pilot found too much gas flowing
Is the button on the gas valve or a red button in the line to the pilot assembly? If its in the line, there is a regulator upstream of the button. If the gas is coming from the gas valve, there is a small screw covered hole in line with the pilot line in the gas valve. If neither of these apply, you may need to replace the orifice in the pilot assembly. Let me know how it goes.
Nov 19, 2013 | Empire Comfort Systems Direct-Vent Wall...
I have a Empire DV210 wall mount vented furnace. The pilot light is very hard to start and has a very small flame not touching the thermopile. The flame is blue but very small. I can not get the primary...
The pilot ofifice probably has a bit of dirt in it...to get it out you will need to take the pilot apart and clean it out...this can be fairly difficult on those heaters and getting it back together can be a pain...pay attention as you take it apart...blow our the tip with canned air like you would use to clean your keyboard...
Then reassemble...
Sometimes the "hood" or the cover over the flame will bend up over time and you will also have to bend it down a bit to get the pilot flame onto the thermocouple...make sure the thermocouple is also pushed all the way up in the holder...
heatman101
Mar 18, 2011 | Empire DV-215 Direct Vent Natural Gas...
Pilot won't light.
If you try but the pilot won't stay lit, you probably have a bad thermocouple. It is a small probe located in the pilot that has either two wires wrapped in a metal jacket going to the gas valve or one copper tube also going to the gas valve. To get to it, you will have to open up the burner chamber and drop it out. Take the thermocouple to a good hardware store or fireplace shop for a new one.
Mar 13, 2011 | Empire DV-215 Direct Vent Natural Gas...
PILOT FOR EMPIRE WALL HEATER WONT STAY LIT. I HAVE ALREADY REPLACED THE THERMOCOUPLE
Jan 29, 2011 | Empire DVC-35 Wall Mounted Panel Heater
Empire DV-210: Pilot light will light and stays lit, but when I
The thermocoupler is no good. It's that bulb sitting in the pilot flame. when it goes out it shuts everything doen in the main valve. It has to be kept hot by the pilot, that's how it know whether or not it is safe to open the main .
Oct 07, 2009 | Reddy Heater-10-12-15,000 Btu L.P.
Pilot won't stay lit
Mar 27, 2009 | Empire GWT-50 Wall Mounted Panel Heater
PILOT LIGHTING BUT CANNOT TURN ON WITOUT IT GOING OUT
change the gas valve, if the thermocoupling works and the piliot stays lit then it has to be the gas valve check to make sure the screen is clear also,, you said it's propane, check to make sure it is all the way turned on, and has the right pressure it might have a bad regulator on it, but will let other things in the house run good luck
Feb 25, 2009 | Bosch 1600H-LP Liquid Propane AquaStar...
Pilot light wont stay lit
You need to replace the pilot safety switch which is usually a Thermocouple. It is connected by a thin tube from the gas valve to a bulb near the pilot burner. It should be available at Home Depot or online.
Ray
Dec 17, 2008 | Empire ECS HB06M HearthRite Heater
Pilot on burners won't light
Pilot won't light - natural gas or propane. check for a spider web in the burner tube. check no dust in burner tube. check surface igniter is lit. if pilot lights check flame detector - may be a millivolt generator - it is a small capillary with a copper tip in flame path. no fire will keep the pilot valve closed. replace the generator.
Jan 29, 2008 | Heating & Cooling
Empire DV-215 Direct Vent Natural Gas Heater Logo
155 people viewed this question
Top Empire Heating & Cooling Experts
Paul Carew
vance jones
Dan Webster
Dan Webster
Are you an Empire Heating and Cooling Expert? Answer questions, earn points and help others
