Question about Sony KP-53HS10 TV
KP61HS10 and 1080i distortion
When it goes into 1080i the picture is stretched vertically and the 16:9 aspect disappears or doesn't engage
4 Suggested Answers
Slinteriors
  • 8617 Answers
SOURCE: 1080i picture is vertically stretched
You can get the service manual emailed to you instantly if purchased from the following site and they offer free support to help you diagnose and repair your set.
http://servicemanuals.vstore.ca/
Posted on Feb 14, 2008
  • 11967 Answers
SOURCE: how do i resize picture to square aspect ratio
Well, you can't. The best you can do in a photo-editing program such as Photoshop Elements, is to crop the picture to square dimensions.
Posted on Oct 28, 2009
  • 21 Answers
SOURCE: I have sony Sony Bravia
check is source is 4:3. set tv widemode to full.
Posted on Oct 18, 2010
The text along the sides of the tv screen are not completely in view
you need to change the 'zoom' on the tv by the remote.
Normal mode frames the 4:3 video to the 16:9 picture area by displaying it in its original aspect ratio, with vertical gray or black bars on both sides of the screen. The disadvantage of this method is the fact that the image is small by virtue of not using the entire width of the screen. This is also known as the 4:3 mode.
Full mode Full mode horizontally stretches the 4:3 video evenly across the entire width of the screen. This is the proper mode to display anamorphic video. If used for standard aspect ratio video, everything on the screen will appear wider than normal. Contrast this with anamorphic video displayed without processing on a 4:3 display, in which people on the screen will appear taller than normal. This is also known as the 16:9 mode.
Zoom mode Zoom mode evenly stretches the picture both horizontally and vertically, until the picture fills the entire width of the screen. This crops out the top and bottom of the picture. This mode is used for letterboxed and open matte video.
14:9 mode Main article: 14:9
In 14:9 mode, the picture is magnified more than in Normal mode, but less than in Zoom mode, while retaining the original aspect ratio.
Wide Zoom mode Wide Zoom mode, also called Just mode, Horizon, or Smart Stretch, progressively stretches the picture horizontally, less in the middle and more on the edges. This allows normal aspect ratio video to be displayed across the entire width of the screen, with minimal cropping, and with much less of the unpleasing visual stretching effect of Full mode.
Dec 08, 2013 | Emerson LC320EM9 32 in. LCD HDTV
I purchased a Grundig GUD1500XI2 Digital Freeview Box for my old small TV. Unfortunately it insists on filling the TV screen on 4.3 ratio by cutting off the sides of the picture. If 16.9 is selected it...
Please remember all modern Digital Set Top boxes are designed with HD LCD/Plasma TV's in mind. Their default aspect ratio is 16 : 9. The reverse was possible- LCD/Plasma allow you to change their viewing aspect ratio from 16 : 9 to 4:3 ( some models also allow 14:9 ).
You will have to return the box if it makes it intolerable for you to watch geometric distortions !!
Mar 08, 2011 | Televison & Video
Picture is stretched on wide screen a circle looks egg shape
Hello
This is an issue because most television programming is produced in a 4:3 aspect ratio. The minority of programming is high definition, which is produced in a 16:9 aspect ratio. Because televisions are made in either a standard (4:3) or widescreen (16:9) format, there is always a conflict with an image being stretched vertically or horizontally. In the case of widescreen televisions, the stretching is horizontal.
Picture Modes
Luckily, most if not all widescreen televisions have a picture mode that allows the user to toggle between a wide (16:9) and standard (4:3) mode. This means that a person can watch non-HD programming in the 4:3 picture mode, and then go to widescreen when watching HD programming. Some TVs have a picture mode that will automatically adjust to the correct aspect ratio. Other people will watch all programming in the wide picture mode, and learn to adjust to watching a stretched picture.
A stretched picture is when a 4:3 image is pulled on the sides to fill the entire screen. People and images end up looking fatter/wider and shorter.
So, what's the big deal?
Some people don't like a 4:3 picture stretched or distorted because it does reduce the overall visual and picture quality. Some people don't like the bars on the side of the screen when a widescreen is in a standard (4:3) picture mode because it looks different.
Solution
There is no fix-all solution for this issue, unless you own a TV that will automatically adjust to the intended aspect ratio. The stretching of the picture is a side-effect, the price we are paying for the better resolution that is digital and high definition. This is definitely something to consider when buying a television, but keep in mind that there is no right or wrong within this issue. It is just the way it is, and there is no way around it unless you buy a 4:3 aspect ratio television.
Hope these lines will clear the issue, if so do rate the solution
Jan 04, 2011 | Televison & Video
How can I get full screen image without distortion on tv viewing? I only get 4:3, zoom, full and justified. Full looks stretched horizontally with tv, looks ok with dvd.
Hello
Most of the telivision transmissions are comes at an aspect ratio of 4:3. Wide aspect ratio is 16:9. If you try to see a picture with aspect ratio 4:3 to wide 16:9, it will look like stretched. it is not the fault of the tv. Most DVD recording have the aspect ratio of 16:9 [Wide]. This aspect ratio will be displayed correctly when your tv is also set to wide mode. If you select normal mode at this condition, the picture will be displayed elongated. Ok Your Tv has no probelm.
Oct 19, 2010 | Panasonic Televison & Video
I'm using this as an additional monitor for a HP 10" netbook and the picture is stretched & distorted & doesn't fill screen. The vertical adjustment just moves the whole thing up and remains...
Solution goes this way, to maintain the aspect ratio of the monitor, take note of this. Your HP 10inch notebook have different resolution compare to your additional monitor, But I'm sure you selected the dual view mode or the duplicate mode that is why you have distorted display on your additional monitor, to let the additional monitor decide and maximize its resolution, try using the extended view option, you can change the resolution of your additional monitor without affecting the resolution of your 10 inch laptop.
Oct 21, 2009 | Acer X183HB Monitor
I can't get the picture to fully fill the screen on my 46'' TV. Model code ln46a750r1fxza. Used the ''tools'' button on the remote and tried adjusting the picture size, but it did not correct the problem....
First set your tv to 16:9 aspect ratio. Then go to the source ie: Cable Box or Sat Box. Then go into the User Menu and find the Set Up or HD settings or picture settings. You need to set the Box to the "Stretch" setting. Right now your source box is set ot 4:3 aspect ratio.. If you have difficulty in changing the aspect ratio on the source box, call the Cable or Sat co. They can help you.
Jul 09, 2009 | Samsung Televison & Video
Aspect ratio problems on Samsung LN-S2651D Flat Panel TV
The aspect ratio (zoom) button on the cable remote had been changed. On Brighthouse the # button toggles through the zoom settings. It's not a tv issue, it's a cable fix.
May 29, 2008 | Televison & Video
HDTV
It is obvous that the aspect ratio that you are watching the program in is the native mode if you see the proportions correctly. If the native mode was in 16:9, it would not stretch when you change to this mode.
The broadcaster may be down converting all their video to 4:3 because the majority of sets in his area are still on the old aspect ratio.
Jerry G.
Dec 28, 2007 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Connecting dvi cable straight to acer monitor
The cable box is probably outputting a resolution the monitor is not compatible with. Computer monitor and television resolutions are usually different, and not cross compatible in some cases.
For example, wide screen monitors are usually 16:10 aspect ratio, while TV is usually 16:9 aspect.
The AL2216wbd is a 1680x1050 display, while HD TV is either 720p (1280x720) or 1080i (1920x1080).
If your cable box is set to 1080i that would be too high for the monitor. You will need to set it to output at 720p, and even then you will probably get a vertically stretched picture since the monitor has a taller aspect.
Nov 15, 2007 | Acer AL2017 20" LCD Monitor
Sony KP-53HS10 TV Logo
22 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
