Question about Empire DV-215 Direct Vent Natural Gas Heater
How to fix gas valve for empire dv-215 heater
Pilot wont light after replacing thermo couple
5 Suggested Answers
Therinnaiguy
  • 1420 Answers
SOURCE: Empire DV-215 Low Flame Issue
Either a restriction in the gas train, low gas pressure or a bad gas valve. Check the pressure on the gas line when on pilot and again when the burners are running. Depending upon what type of gas it runs on, you should have at least 4" W.C. if Natural Gas and 10" W.C. if Propane. If gas pressures test good and all valves are open, you are looking at replacing the gas valve.
Posted on Dec 10, 2007
  • 69 Answers
SOURCE: wall heater burners wont ignite
you may have a bad gas valve
Posted on Dec 19, 2008
  • 3250 Answers
SOURCE: re: solution to pilot being blown out at lighting. check pressure at gas valve. Main gas valve on supply side replaced. Do you mean the gas valve inside the heater itself?
Have cleaned the pilot it could be too small to light the burner also clean the main burner .
Posted on Mar 03, 2012
herryjohn183
  • 7 Answers
SOURCE: How do I get the manifold pipe loose from the gas
solution
Amana Furnace Toronto
Posted on Oct 29, 2013
Testimonial: "never got the solution just a blank page"
Replaced thermocouple pilot stays on but burner wont light
Make sure the gas valve dial is turn to the "on" position. Otherwise, I would need more info to answer this question fully.
Nov 17, 2015 | Empire Comfort Systems DV-215-SG...
My pilot light will not stay on. when you go to turn the knob to keep it on it just goes out.
My recommendation is that you will have to measure the millivolts created by the flame on the thermocouple, under most circumstance the pilot will not stay on if it doesn't stay greater than about 20mv if it does reach or exceed 20mv then the gas valve that recieves the mv has an internal componant that is out and should be replaced (never repair the gas valve). Hope that helps!
Nov 19, 2011 | Empire DV-215 Direct Vent Natural Gas...
Pilot won't light.
If you try but the pilot won't stay lit, you probably have a bad thermocouple. It is a small probe located in the pilot that has either two wires wrapped in a metal jacket going to the gas valve or one copper tube also going to the gas valve. To get to it, you will have to open up the burner chamber and drop it out. Take the thermocouple to a good hardware store or fireplace shop for a new one.
Mar 13, 2011 | Empire DV-215 Direct Vent Natural Gas...
Piolite light keeps going out after unit turns on and reaches temperature set on thermostat.
Check gas pressures standing and working make sure pilot burns correctly and thermocouple is in good order
Dec 13, 2010 | Empire DV-215 Direct Vent Natural Gas...
The heater piolet light goes out when you move to use the heater
There is a thermo coupler that shuts the gass off if it is ba. It is locacted just in front of the pilot flame It has to sense the pilot to let the gss through. It is an easy fix and inexpensive.
Nov 12, 2009 | Empire DV-215 Direct Vent Natural Gas...
Pilot will not lite
is the spark right on the pilot , is the spark strong can you see it jumping across tp the pilot try cleaning spark electrode , there could be air in the gas line
Jan 11, 2009 | Empire DV-215 Direct Vent Natural Gas...
Pilot will light, burner will not light.
check all limit switches to see if they can be reset if so reset it ,if problem reoccurs wich limit is going out ? make sure all wires are connected well to your gas valve , use a low voltage tester to make sure your firing circuit is operating properly , if you have a thermocouple it may not have enough juice left to open your gas valve
Nov 02, 2008 | Empire DV-215 Direct Vent Natural Gas...
Dec 08, 2007 | Empire DV-215 Direct Vent Natural Gas...
Empire DV-215 Direct Vent Natural Gas Heater Logo
97 people viewed this question
Top Empire Heating & Cooling Experts
Paul Carew
vance jones
Dan Webster
Dan Webster
Are you an Empire Heating and Cooling Expert? Answer questions, earn points and help others
