Question about Sport & Outdoor - Others
How to close/unlock a browning model 055 knife
How do you loosen the blade on a gerber remix tactical knife?
Try a few drops of a light machine oil, and then work the mechanism for ten minutes: open, unlock, close, open unlock close, again and again. Tomorrow: do it again. The next day? You get it, just go easy on the lube, and after a week you will have a much easier, smoother opening/closing action.
Unlike most modern folding knives, the Remix does not have a user accessible pivot screw (which solves this problem on many knife models). The central ring pivot has three tiny Torx fasteners, but they are T4 or even smaller (!), so I can't disassemble mine (had the same problem). You might try posting to a more appropriate group, since it isn't even the same Gerber company that makes the toilets as makes the knives. But try it, somebody, it will solve your issue fast.
Jun 20, 2013 | Home
Can't close stanley fatmax
It only goes in one way, try to loosen the screw a little
Jul 30, 2012 | Stanley Fatmax Xtreme Retractable Utility...
Unlock code for daewoo car music player AKF-4306SW
4316
2152
4513
4362
1156
2145
3451
6361
5624
5241
3346
1165
3241
4524
5436
try them all
Jan 06, 2012 | Cars & Trucks
Hi it is a Nokia 2730c V 09.41 RM-578 CODE - 0590816 IMEI 353788040647870 Made in China Locked to Vodafone Australia and it is prepaid if you can please send me the unlocking code thank you
Model: Nokia (Gener)IMEI: 353788040647870Network: 50503000
#pw+317 916 044 511 212+1##pw+437 567 566 567 166+2##pw+808 171 630 623 175+3##pw+278 315 402 665 217+4##pw+235 315 362 315 111+5##pw+385 816 717 320 315+6##pw+024 933 055 261 432+7#
Oct 07, 2011 | Nokia 2730 Cell Phone
I need unlock code for nokia 6600 IMEI: 355381005224790 in egypt, network vodafone. many thanks.
Unfortunately there vodafone is not supported yet. But have a try with the following codes anyway:
NOTE: You only have five tries in which to enter the codes. After that, only a cable solution will help you! So do NOT exceed in one go.
#pw+944 022 771 202 227+1#
#pw+076 203 605 404 005+2#
#pw+402 417 533 016 413+3#
#pw+336 226 464 434 225+4#
#pw+346 846 074 470 545+5#
#pw+283 045 117 142 545+6#
#pw+944 472 577 206 277+7#
#pw+128 474 055 616 075+1#
#pw+275 055 705 352 257+2#
#pw+882 101 313 023 005+3#
#pw+329 366 551 775 464+4#
#pw+978 312 100 665 415+5#
#pw+016 003 047 422 003+6#
#pw+218 925 044 661 724+7#
To get 'p' or 'w' or '+' press the '*' key several times.
Hope this helps.
May 06, 2011 | Nokia 6600
Just purchased a Stanley FatMax 10-778 retractable knife. Cannot figure out how to load the blade for use.
1. Make sure the side lock is unlocked.
2. Push the thumb tab all the way to the front of the blade handle.
3. Insert the blade in the opening, you may notice two notches on the top side of the blade.
4. Press the small blade release button as you slide the blade into the knife. You may have to jiggle up and down to get the two notches on the blade fully into the handle.
If properly inserted, the exposed area of the blade should look very close to an equilateral triangle.
make sure both notches of the blade are inside the handle. They notch into the thumb lever.
good luck
Mar 20, 2010 | Stanley Fatmax Xtreme Retractable Utility...
I have a delta ,model 33-055 needs oil maintenance
Go here for a selection of manuals and diagrams:
http://www.dewaltservicenet.com/Products/DocumentView.aspx?productid=43476&typeId=10320&documentId=40207
Unfortunately the manual is not available but anything identified as a bearing or a bushing in the parts diagrams could probably use a drop or two of machine oil (3-in-1). Unless the loud noise is a screech oiling may not reduce it.
Jul 09, 2009 | Saws
Maytag washer
the front panel is removed on this model for acess, pop the top up and back by using a putty knife or a thin ***** driver. theres (2) clips that will release the top a few inches in from each sid( push w/ tool and the will pop. tip lid back and there should be 2 screws to release hte front panle for better look. if your seeing brown oily splatters around inside oc cabinet that would be a transmission problem(10 year+ old machine not worth repair).never stated what problem with machine is though
Mar 11, 2008 | Washing Machines
Sport & Outdoor - Others Logo
41 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
