Question about Simon & Schuster Ski-Doo: X-Team Racing for Windows
Good compression and spark but not firing
As i said have good compression on both replaced both pistons and rings have lots of spark but clutch side cylinder not firing and plus new carbs aswell and set to specs what else good be
What is the proper gap for the spark plug?
The gap is usually around .025.
But first to see the spark plug is firing by removing, grounding to the cylinder where you can the gap then pull the starter cord.
If there is spark jumping the gap then your more likely to have a compression problem. These engines needs at 100 psi to fire; otherwise, fuel is just drawn in but is never ignited by the plug.
In this case you would remove the muffler and check the cylinder, piston and ring condition . A bad scored cylinder or piston will cause lack of compression. A struck ring will also cause lack of compression. A struck ring can check for by using a small screwdriver gently probing the ring to see it moves freely. If the ring is struck then the cylinder will need to removed so ring and piston can cleaned. Note: these are easily broken so don't use to much force when trying to free them.
Nov 05, 2014 | Bolens 31cc 2-Cycle Gas Cultivator BL410
Tip
Cars not starting
A lot of times i see in here "my car won't start" or "I put new plugs in it and it still won't start". If it is petrol engine you need fuel (gas at the right mixture with air) in the right amount, a spark at the right time compression in other words the when the piston comes up to the firing time the valves are closed and there is no air escaping past the piston rings or blown head gasket ( low compression). If one of these things isn't happening it won't start.
It is a process of elimination, Check for spark then gas then timing, you may have a spark but at the wrong time and last of all compression test, most engines won't start under 60 lb psi.
on Apr 21, 2010 | Chevrolet Chevy Cars & Trucks
Why wont 1 spark plug fire
ok did you check to see if the spark plug wire is good and if it is good take out the spark plug and put it on the spark plug wire that its not firing on if it fire at the spark plug then you should do a compression test if the compression is bad you may have a burn valve or something and that would be what causing the misfire
Jul 17, 2014 | 1998 Dodge Neon
Stihl TS400 stone cutter not working (no compression) so replaced piston rings, new gasket kit and clean for carb new spark plug (good spark when engin turned over) cleaned all air filters, replaced all...
You did not indicate whether or not you have compression now that you have changed out the gaskets and piston rings. If not, it seems to me that the problem could be a) cracked head or block, b) bad valve(s) or even c) a warped head.
Sorry for the bad news (if I am right).
Apr 23, 2014 | Stihl Ts400 Cut Off Saw Carb Carburetor...
I have lot's of spark on my 83 rm 125. I fired it up after sitting for a long time and it kicked right over. I let it run for a few minutes and then shut it off. now it won't fire up again.! Lot's of spark...
Could be low compression (poor piston rings) or plugged air filter.
If it looks like oil on the plug, not fuel, you could have a crank seal issue, as the right side one will **** in transmission oil if it leaks.
Mar 25, 2011 | 2003 Suzuki RM 125
2000 NEON NOT FIRING ON THE #1 CILENDER
#1 cylinder not firing, check spark plug, spark plug wire, remove spark plug and use a compression tester, and check the compression of that cylinder. should have at least 65 pounds of compression per cylinder. If the compression is low, you may try shooting a little oil in to that cylinder, replace spark plug, and try running motor again. if the compression is low on said cylinder, could be due to bad piston rings. requiring a motor rebuild.
Nov 08, 2010 | 2000 Dodge Neon
I have a 1991 Hyundai excel and one of the pistons doesn't fire
Have you measured the compression? Very low compression can be the reason. And the reason for low compression can vary - broken compression ring, worn valve/valve seat... You are sure you are getting a spark, just before the spark plug, right? Have you checked the timing of ignition?
Nov 10, 2009 | 1991 Hyundai Excel 4 Door
46 cc Sears/Poulan chainsaw will not start
Four things I can think of:
1) There is a short in your spark plug wire. When you bend it to connect the plug in the machine it allows the exposed cable to contact the engine block. Examine the wire all the way to the coil.
2) Flywheel key is sheared ( you obviously know how to take off the flywheel since you checked the seals).
3) Flywheel air gap is not set correctly. Loosen the coil. Put the cover of a notebook or the cardboard piece of a cigarette pack between the magnetic portion of the flywheel and the coil. Tighten the coil down. This will get you the proper gap.
4) Your cylinder/piston or rings are scrubbed out. Even though it passed a compression test, on rare occasions it will loose compression only when it fires. So do the following:
Remove your exhaust manifold. Look into the cylinder with a flash light. You are looking for scratches. Anything larger then a light fingernail is definite proof you need a new cylinder/piston assy.
If it passes that test do the following:
Pour mixed fuel straight into your cylinder until 1/4 full. Slowly pull your saw over while looking into the cylinder. If you see bubbles after the ring/rings go by then you need a new cylinder/piston assy. On rare occasions if no scratches are present on the cylinder wall or piston, you may be able to change just the rings.
First if you can get a inline spark tester so you can see if your getting spark with the plug installed.
Mar 24, 2009 | Poulan Pro Chain Saw 46cc 20"
My Poulan saw will not fire
Hi
Check if the gas tank cap vent is plugged.Check if the flyweel key is sheared(ignition timing point).Check the fuel filter and air filter.
Hope this helps.
best regards savumihai71
Dec 15, 2008 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Simon & Schuster Ski-Doo: X-Team Racing for Windows Logo
20 people viewed this question
Top Simon & Schuster Video Game Consoles & Games Experts
James Wishart
Are you a Simon & Schuster Video Game Console and Game Expert? Answer questions, earn points and help others
