Question about Keurig B60 Coffee Maker
Keurig Leaks Water Before Brewing
When my Keurig pulls water from the reservoir to be heated before brewing, all the water it tries pumping is leaked onto the counter from under the machine. When I opened the bottom to see if I could find a loose hose, all I could find was a plastic fastener that came loose from somewhere. Help?
  • 1,511 Answers
If it is in warranty, this unit needs factory services. Unfortunately the cheap labor and rapid production rates are more important to the company than Quality.
Posted on Feb 20, 2014
SOURCE: keurig maker dispenses too little water when brewing
I found this solution on another post. Unfold a small metal paper clip and insert through the lower piercing needle of the cup holder to **** out any debris in the needle.Even a small piece of coffee or debris can slow the water flow through the cup.
Posted on May 01, 2009
mcdevito75
  • 1970 Answers
SOURCE: my keurig machine is brewing only a little water
mcdevito75 here, You may need to clean the machine. water used to make coffee leaves deposits in the brewing holes and has to be cleaned out. Refer to the owners manual on cleaning.
Posted on Jun 20, 2010
SOURCE: The machine leaks water all over the counter when starting brew
My keurig did the same thing, the rubber grommet around the part that punctures the cup gets grounds on it and prevents a complete seal. Pop of the grommet and clean it and it will be good as new.
Posted on Dec 27, 2010
heatman101
  • 43501 Answers
SOURCE: Our platinum keurig has stopped
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
Posted on Mar 01, 2011
heatman101
  • 43501 Answers
SOURCE: my keurig will not brew.
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Posted on Mar 21, 2011
My Keurig will only drip water when brewing. I've descaled, changed the filter, machine is only year and a half old.
#1. Use the paper clip trick on both top and bottom punchers. The holes are in the side of the punchers. (lots of video in youtube) #2. Descale it again with vinegar and leave it for 15-24 hrs before brew rinsing, (instead of 4 hours as mentioned on the manual) #3 some said, turning it upside down and giving it a shake, #4. visibly check the screen on the the water reservoir tank entrance clean if there's any visible clog. #5 Still having a problem, then, for the last resort, before deciding on replacing the diaphragm pump, open the bottom metal part (5 screws), inspect for any visible drip of water (accumulation of white hard water stains, or discoloration on the metal) visualize where it's coming from. Mine is on 2 areas--from the diaphragm pump (where there's 3 black screws) and where the connection of the main pump to the reservoir. This is good news, it means nothing wrong with the pumps. it's just been leaking a little bit of water on the connection (must be air tight, any leak will decrease the pressure). The common sense FIX: depress the metal clamp and pull the plastic tube out, clean the inside and the connection and re-attach it back making sure the little leak will stop. same with the other one then, then replace the other smaller tube with a new tie wrap and make sure it's air tight. Basically you just check all the hose connections make sure it's air tight..
Jun 14, 2015 | Keurig B70 Coffee Maker
My keurig vue unit will no brew a full cup. bubbles come up in reservior when brewing stops
You did the correct procedure. You may have a line leak. If bubbles occur, air is getting into the line somehow. It could be the connection point or a small hole in the plastic line from the water reservoir to the heating reserve.
Jan 07, 2015 | Keurig Vue V700 Brewing System - 110774
Keurig b40 pump out of sync
PLugged exit port tube. Manual Page 18
Jun 24, 2012 | Keurig Elite B40 Coffee Maker
My keurig is leaking from bottom
My Keurig B60 had the same issue. The water reservoir has a valve in a nipple on the bottom that slides into a clear plastic fitting within the base of the unit. Water from the reservoir is supposed to pass through the fitting and into the pump, which is also in the base. Over time, hard water deposits can build up on the nipple or the mating fitting (or both) such that a good seal is not made when the reservoir is in place and water slowly leaks out the bottom. To fix this, I removed the five screws on the bottom of the Keurig and then removed the two screws which hold the fitting in place. I gently cleaned both the clear plastic fitting and the nipple in the bottom of the reservoir with white vinegar. After rinsing both with clean water and drying both, I applied a small amount of silicon faucet grease (available at any hardware store) to both parts. I haven't had any more leaks since, although I assume I will have to repeat this operation periodically.
Oct 02, 2011 | Keurig B60 Coffee Maker
Leaking of water from below reservoir when brewing, especially when pump is on.
Here is a tip that I wrote about Keurigcoffee brewers and the Keurigleaking problems
Keurig OneCup Coffee Brewer leaking
heatman101
Jul 31, 2011 | Keurig B60 Coffee Maker
After placing bottled water in the container, the unit sounds like it is pumping but no water.
If your brewer is not brewing the full amount selected, it may be caused by the following:
The exit needle is clogged by coffee grounds or cocoa mix. Please refer to the K-Cup Holder cleaning instructions.
The brewer may need to be de-scaled. Please refer to the de-scaling instructions.
The removable water reservoir was removed during brewing. Place the water reservoir back onto the brewer and perform a cleansing brew without a K-Cup.
First try to make a descale maybe repeat it the next day.
http://www.keurig.com/customer-service/brewer-registration-and-support/~/media/FD69E91A51CA41BEBF4CCAA138325BBF.ashx
Then try also this useful tip
http://www.youtube.com/watch?v=DqRs4Ott21s
Jul 03, 2011 | Keurig Platinum B70 Coffee Maker
Keurig B60 coffeemaker stopped pumping water because I didn't notice there was almost no water left in the chamber and started it--I added water right away but it won't pump any more water out of the...
This morning my Keurig sounds like it begins to pull water then stops. I tried to cut it off then back on. Still didn't work.Removed water from reservoir and K-cup and added pure vinegar. Ran machine several times without filter or Kcup by pressing cup selector several times. You must open K-cup holder and close each time. I had to do this about a dozen times before the water began to draw again. Flushed system by filling water reservoir with fresh water, and brewed just plain water until vinegar was gone.Works like brand new.
Nov 11, 2008 | Keurig B60 Coffee Maker
Keurig B60 Coffee Maker Logo
560 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
