Question about Coffee Makers & Espresso Machines
Krups xp52 espresso machine. machine making loud thumping noise.
Krups xp52 espresso machine. After being at the 12 oclock position (on) and the light stops flasging. I then turn to the picture of a cup, the machine starts making a loud thumping noise intermittently and the espresso dribbles out extremely slow and seems to thick?
Noggin
  • 944 Answers
SOURCE: Krups Nespresso FNA2 coffe/cappucino machine
First thing to try is a descale. Run the machine normally using it (as if making a cup of both types) a couple of times with a 50/50 mix of white vinegar and water. Leave the machine off but uncleaned overnight. run a couple of cycles with just water, and if there is still a slight vinegar taste then run a cycle with a teaspoon of baking soda in water, then flush with just water again. If this doesn't solve the problem, try again with 75% vinegar. If still not working, there is either a control board problem (may be solveable), or the valve/solenoid that stops/allows the water is sticking, almost certainly solveable by taking that apart and cleaning/lubricating. Definitely solveable by replacement. Let me know what you get after a descale if no luck. Hope this helps :)
Posted on Aug 20, 2007
  • 2039 Answers
SOURCE: DeLonghi automatic espresso machine
do you use the machine often oil in coffee create residue and can accumulate on the grinder and the residue is so thick that it does not let coffee trus remove the coffee bean and were the beans go u should see the grinder teet use a little tootbrush or anything that might fit in there remove the residue and try it it should be good thanks for using fixya pierre
Posted on Feb 08, 2008
  • 3 Answers
SOURCE: instructions for Krups Gusto espresso maker
I found the manual on an Amazon.com site for the Krups Gusto espresso maker (January 2009)
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000052280.pdf
Posted on Jan 18, 2009
  • 54 Answers
SOURCE: Espresso maker doesn't work properly
It is clear that there is a problem with water supply. Check if pump works, if it does, there is blockage in water supply to pump. Check and clean.
Posted on Jul 11, 2009
SOURCE: water leaking in espresso machine
I have a Krups 2010 and it leaked from day one I used it for about a month before I decided to fix it myself instead of paying for shipping it to them. After opening the back (yes the warranty is broken) I took some photos and here is what I found. Poor quality control there are two screws holding a hose interface to the reservoir and they are not tight or became loose since they are metal screws going into plastic that get hot and vibrates.
The fix is to tighten the screws just slightly so that you do not crack the plastic then dab them with nail polish so that they do not move. (see second photo). This machine still makes one of the best espressos I have tasted and now it is one of the easiest to clean.
Posted on Jan 07, 2010
Tub makes loud thumping noise when spinning
Good morning! It's common to hear a loud thumping noise during spinning because the load (clothes) are not properly place in the tub. Please try to put the load in order & compress it down. best regards.
May 02, 2009 | Washing Machines
Water leaking in espresso machine
Mar 10, 2009 | Krups XP2010 Espresso Machine & Coffee...
Krups XP4000 Pump Espresso Machine. It comes on and gets incredibly hot but no water ever comes through. It shakes a lot, makes a really loud noise when turned on. The tank is full and pushed in as far as...
If it is brand new you should not be expected to figure it out, take it back to the shop. Any messing about with a brand new appliance can only harm your guarantee, let them figure it out. It sounds like the pump valves are dry or stuck.
Feb 28, 2017 | Krups XP4030 Espresso Machine
Steamer
Take off the edge on the steam pipe, clean it and mount it again.
/Mirran
Aug 31, 2008 | Breville ESP8XL Espresso Machine
My Krups iron only heats up slightly. HOw do I repair?
Your question is listed under espresso machines. Are you talking about a Krups Espresso Machine? Please clareify. Does it make Coffee and Steam?
Aug 02, 2008 | Krups Orchestro Dialog FNF2 Espresso...
Instruction Manual
Espresso Makers Recall 2/16/2006 12:49:35 PM Krups recalls about 2,100 Orchestro Espresso Makers. The electrical connectors in the espresso machine can erode, posing a fire hazard. The recalled espresso makers are black and silver and make two cups of espresso at once. The word "KRUPS" is printed on the front. The model number and factory mark are stamped on a silver sticker on the bottom of the machine. The following are the recalled models: model number 889-45 and factory mark F8894556; and model number 890-41 and factory mark F8904156. Sold at department stores and independent specialty stores nationwide from January 1999 through November 2005 for about $850. Call Krups at 1-866-832-7690 or visit www.krupsrecall.com for assistance. Source: Consumer Product Safety Commission -- Marla Marino , Tampa Tribune
Jul 06, 2007 | Krups Orchestro 890-41 Coffee Maker,...
Coffee Makers & Espresso Machines Logo
35 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
