SOURCE: replacing only the microwave in Jenn-aire oven combo unit
i dont think so i would check around
SOURCE: Replaced element, oven is still not heating
You may still have a bad Electronic Range Control (ERC). This is your timer that you mentioned. The oven is controlled by the ERC. There is a separate circuit for the BROIL and BAKE functions. Does the BROIL element still work? Or, are both elements not working? You may want to double check all your connections from the element to the control board as well. Sometimes the wire lugs can oxidize and not make good contact. Check the ERC to see if there any obvious signs of failure. Burned components are common. These boards are considered "non-serviceable" and usually requires replacing. You can attempt component-level troubleshooting if you are savvy with electronics. There's usually a basic block diagram that comes with your appliance mounted somewhere inside the operator console or on the back panel of the range.
The ERC for your range would cost in the neighborhood of about $100 - $140 to replace. Prices will vary between model versions and will also depend on where you get it. It is a very simple repair job if you wish to pursue this yourself. I can give you step-by-step instructions if you need further assistance. I hope this helps you.
PS The reason all your surface elements still work is because they are controlled by infinite switches behind the control knobs. There is a separate switch for EACH burner.
SOURCE: Replacing heating element in oven-connecting wires fell back in
hey sorry about that,as a repair man i hold on to those babies like crazy.almost all ovens i worked on [its many]the rear wall dose not come apart.if yours dose great go that way.but other wise yes you have to go thru the back.i would try fishing abit more before i pulled it out if was me.God bless,tom
SOURCE: My Jenn air SVD48600P heating element dose not heat
Hi. I believe this info. may assist you in getting your bake and broil up and running:
When your heating element burns out, you have to replace it because they are not repairable. If, when the heating element burns out, the infinite switch that controls it also fails, you have to replace it too.
