Question about ViewSonic PJD5133
Cleaning problem My viewsonic PJD5133 projector turns on for 5 minutes before the color starts to go out. I checked the bulb and it works fine. I assume I need to clean the air filters. How do I do this?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 729 Answers
1,the color starts to go out, it become the white and black ,
2,then,the projector running off after only a few minutes,
it is a general issue:the inductor need to be cleaned
Use a cotton swab moistened with alcohol to clean the inductor.
the inductor (Sensing element),is near to the Color Wheel.
the industor : is a black little element,as little as a sesame seed
any questions, feel free to ask me
have a nice day!
Jerry Lampdeng Limited
Posted on Mar 04, 2014
SOURCE: my viewsonic pj400 projector switches itself off
hello
i have the same problem, a clear image, the the projector shuts down, turn the fan on, and "lamp" blinks.
i returned my projector to viewsonic service center, they told me to change the lamp.
the problem is that a lamp is very expensive!
HudgeFR
Posted on Aug 05, 2009
  • 6 Answers
SOURCE: Viewsonic Projector PJ506D not working
proable solution the cooling fan is giving problems. the whistling sound most likely is fan rubbing on a wire??? The unit gets over heated and turns off for protection. Good luck
Posted on Aug 19, 2009
  • 22 Answers
SOURCE: My projector (viewsonic pj452) started flickering.
The power supply needs to provide a constant current flow
to the lamp. Any small change or in the current will be seen as flicker
in the lamp and projected onto the screen.
Problem could be with low voltage power supply, the ballast or the
lamp it self is beginning to wear out.
Posted on Jul 21, 2010
robertsager
  • 24 Answers
SOURCE: "clean and reset filter" alert is displayed even
You can reset the "Filter Time" on your projector and it will clear this error out of the system.
1) Clean Filter
2) Turn the power on
3) Hit the Menu button
4) Once the menu appears choose "Options"
5) Choose "Filter Time"
7) While the time is displayed hold the "Reset" button on the remote for 3 seconds
8) The "Reset" menu will pop-up and choose reset.
That should take care of it.
Posted on Mar 15, 2011
heathgr
  • 442 Answers
SOURCE: Our ViewSonic projector was turned on to warm it
have you cleaned out the air filter. Try running in full fan speed operation.
is the unit well ventilated, or in an enclosed space.
Posted on Mar 26, 2011
How do I open up?
NOPE U NEED TO REPLACE COLOR WHEEL
Oct 07, 2015 | ViewSonic PJD5134 DLP Projector
Viewsonic Pjd6531w bulb not turning on and projector requires unplugging to turn off
Have a good day! any question ,contact me,Please
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Mobile: 0086-13178867858
Wechat ID: 008613178867858
Whatapp ID: 008613178867858
Skype: lampdeng@hotmail.com
http://www.lampdeng.com
Feb 23, 2014 | ViewSonic PJD6531W Projector
Green and yellow color with viewsonic pj551 projector
the LCD panels are failing
the price is USD100
any questions, feel free to contact me
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
have a nice day!
Jerry,Lampdeng Limited
Feb 11, 2014 | ViewSonic PJ-551 Home Theater Projector:...
I'm using an acer aspire laptop and a viewsonic projector. projector colors and disply works fine with an xbox bt when i se my laptop, the projector screen goes red. is it the settings on the comp
Make sure you have all drivers and software necessary for the projector installed on your laptop. You can find them on viewsonic's website. Also go to Control Panel>Display>Connect to a Projector and insure all settings are correct. Let me know if you run into problems.
Jun 13, 2012 | Acer Aspire 5100 (5100-5674) PC Notebook
My viewsonic pj400 projector switches itself off
hello
HudgeFR
Jul 13, 2009 | ViewSonic PJ400 LCD Projector
Blue spots & haze
two problems .out of that any one will solve the problem. the bulb or the colour wheel any out of that has to be checked and replaced.
how to replace the colour wheel with diagram and procedure
http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/
how to replace the lamp in 5 minutes with diagram and procedure
http://www.jangro.com/a/2006/08/03/how-to-change-your-samsung-dlp-lamp-in-5-minutes
Mar 03, 2009 | ViewSonic PJ501 Multimedia Projector
Viewsonic PJ556d shuts down after 30-60 seconds
My solution sounds dumb, I had the same issue. Took the lamp cover off the bottom. The screws were loose holding in the lamp. Maybe they heat and expand and eventually work their way out and the lamp doesn't make good contact. Just tightened mine up, the unit would power off after 45 minutes prior. Been on now for 5 hours, no trouble.
Sep 15, 2008 | ViewSonic PJ556D DLP Projector
Optoma MovieTime DV10
I have the same issue, I have figured out its a fan issue, my fan must have went out. After about ten minutes the bulb will get too hot and the picture will start to turn a way off tint color. I put a fan on my projector and after about 40 min. the picture returned to the appropriate color. I am still investigation on how to get and replace the fan.
Sep 02, 2008 | Optoma MovieTime DV10 Multimedia Projector
Optoma H30 Projector: color banding
Most DLP projectors have a colour wheel. It's usually hard to get at, and you may have to actually remove everything including the optical block from the projector to access it. This wheel turns on a motor just like a fan, and if it gets dirty it can act up just like a fan.
They are expensive to replace, so you might want to try taking it apart and cleaning it out. Add a small amount of 3 in 1 oil to the motor if you can.
Aug 22, 2008 | Optoma H30 Multimedia Projector
ViewSonic PJD5133 Logo
110 people viewed this question
Top ViewSonic Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a ViewSonic Office Equipment and Supply Expert? Answer questions, earn points and help others
