Question about Baby Gear
My sound on my walker saorview 32 inch tv keeps goin of every 5 mins or so after i turn it on wat could that be ..
My sound on my walker 32 saorview inch tv keeps goin of every 5 mins or so after i turn it on wat could that be
SOURCE: Panasonic 32 inch TV has horizontal lines across screen
REPLACE VERICAL OUTPUT IC ' LA7838
Posted on Feb 05, 2009
bernardlunda
  • 318 Answers
SOURCE: tv keep going on standby when you turn it on
tv goes into standby all the time if a power supply is not fine, what happens is that a power supply produces two voltages, one small one powers a standby components and bigger voltage powers a line transformer which later produces more small voltages,
then later cancels the first small voltage.
chec your power supply semi conductors like, transistors, diodes and small value resistors, on your power supply. some power supply uses a IC to oscillate a ht. so check a supply at a w/shop.
Posted on Apr 29, 2009
NJ Logan
  • 31 Answers
SOURCE: 32 inch wide screen black line s 32 pw 6006/25 it
flyback transformer is bad
Posted on Aug 27, 2009
dave1645
  • 834 Answers
SOURCE: my 32 inch westinghouse lcd tv's screen turned pink when on
your T-con board is failing you need a tech to replace it about a 150 dollar job
Posted on Nov 18, 2009
alpug
  • 1961 Answers
SOURCE: Sanyo TV LCD 32 inch about 3 years old. No
the power supply of your tv is bad try to check the fuses if fuse are open try to replace them with the same value..try to power it on but if the fuse blows again replace the power supply board...
good luck plse rate my help.
Posted on Jun 04, 2010
How do I fix a 32 inch 32lg70 smart tv that has sound but a white screen
unplug for 5 min at least the hold the power button on the tv not the the remote then plug back in and turn on
May 31, 2016 | Televison & Video
Technika 32" led 32-2481. Keeps loosing the saorview tuning. Have to auto scan every time move from hdmi back to saorview. What's the problem.
Main system control memory IC is faulty. Replace it. Contact any service technician.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 31, 2014 | Televison & Video
I have an alba 32inch tv and the sound keeps turning off we have to then switch tell off for a minute to get sound back but the sound is gone again in 5 min only 2 years old
sound like there is a over heat / or failure of some circuits
32 inch are quite cheap now, so it maybe something you should re-place,
or flog to a 2nd hand shop if it last long enough to sell during test
Jun 25, 2014 | Alba Televison & Video
My Hisense 32" inch tv has started making a popping sound and is static and it turns off then turns on and load then "pop" it off and it does it again then turns on stays on for about 10 mins with no sound...
Sounds like you have a bad power supply board. Either replace the TV or get it fixed (probably not worth spending too much on considering how cheap new 32" TVs are now).
Nov 29, 2013 | Televison & Video
My sony trinitron 32 inch widescreen only gives slight flash when you turn it on but sound is working. no picture just sound. picture worked once since this started happening and then went off again. Any...
there might be a problem with the connection of the screen to the motherboard or the wire that connects it might be the fault. but there could be a burnt fuse or components.I would suggest letting a tv tech have a look good day sr
Nov 23, 2010 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Jun 04, 2010 | Sanyo DP32746 32 in. LCD Television
Lg 32 inch lcd on light flashing white but fast
Sounds like it started "Protection Mode" because of a failed electronic part inside the TV. When this happens, the TV will keep turning itself OFF or will not turn ON at all. This keeps the other part inside from being damaged. Most likely the TV has a power supply related problem. It's possible that it maybe a badcapacitor or transformer on the power supply board. The common part to go bad for flat panel screens circuit board that powers the screen. Most manufactures call it a Backlight Inverter Board.
But, I can't say what is 100% the problem because I can't actually look at the tv over the internet. I can only make guesses with the symptom.
You have a few choices:
1. You can again try leaving the TV unplugged for 30 - 45 minutes so the TV can discharge and reset itself.
2. If by chance the TV is still under warranty, go that route.
3. If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, schematics, test points, and part# lists.Usually, cost under $20. And most cases the new part cost less than $15 by searching on the internet with the part number.
4. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
I hope I shed some light on the subject for you.
Jul 20, 2009 | LG 32LC7DC 32 in. LCD HDTV
Turn off /turn on
I have an 32 inch Akai TV/DVD Combo; the TV turns off by itself about every 20-30 min, and when I put in DVD to play, the TV cuts off.
Jan 30, 2008 | Akai LCT3215/26 32 in. LCD Television
Baby Gear Logo
104 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Are you a Baby Gear Expert? Answer questions, earn points and help others
