Question about Radio Communications
How do i make my audiovox walkie talkie stop making a beep noise
How do make my audiovox walkie talkie stop making a beep noise
    Master:
  • 623 Answers
In the "settings" there should be an option to turn off "beeps" or "tones" or "notifications", something to that effect.
Posted on May 04, 2014
Neto
  • 123 Answers
SOURCE: Motorola Talkabout T5100
I think you have to remove the courtesy beep option from radio, this is also call Roger beep.
Posted on Dec 12, 2006
eradiostore
  • 1654 Answers
SOURCE: Motorola FV200 Walkie-Talkie
Scanning Channels
Use scanning to monitor channels for transmissions or to find someone
in your group who has accidentally changed channels.
1. Short press
MENU until the "Z" appears. The current setting
On/Off will flash.
2. Press either
+ or to turn On or Off.
3. Press the PTT to confirm or
MENU to continue set up.
Here is a link to the manual http://www.motorola.com/mdirect/manuals/FV200_userguide.pdf
Posted on Oct 23, 2008
eradiostore
  • 1654 Answers
SOURCE: motorola walkie talkie t4508
http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T4500_User_Manual_E.pdf
This one should be a very close match. The T4508 is a foreign version of the T4500.
Posted on Jan 07, 2009
eradiostore
  • 1654 Answers
SOURCE: walkie talkie symbol stuck on cannot remove it
The symbol you are describing indicates you have the radio on HI power. It will not go away unless you reprogram the radio to LOW power, or change to a low power channel. Here is a link to the user guide: http://www.motorola.com/staticfiles/Business/Products/Two-Way%20Radios%20-%20Unlicensed/_Documents/XTNiD/Static%20Files/XTNiD%20Manual%20EN.pdf?localeId=252
Best regards.
Posted on Feb 06, 2010
  • 4 Answers
SOURCE: BellSouth 1010 walkie talkie receives constant static
you have opened up the squelch - refer to the manual to close and return radio to normal operation
Posted on Apr 30, 2010
Manual for model Qmr61582ch audiovox walkie talkie
Google (audiovox)(Qmr61582ch)(manual) without parens.
May 31, 2018 | Audiovox Radio Communications
Syncernise audiovox walkie talkies
I assume you mean Synchronise audiovox. By that, I assume you have two of more radios that don't talk to each other. If you can provide a model number, I can guide you to a manual website.
Jul 22, 2016 | Audiovox Radio Communications
Audiovox GPRS 2way radio manual?
You can download it from here: http://www.manualslib.com/manual/12720/Audiovox-Gmrs602pk.html
Feb 17, 2015 | Audiovox GMRS-602PK 2-Way Radio Walkie...
Use a audiovox walkie talkie
What is your question about using the walkie talkie? These are standard FRS low power walkie talkies. You need to set both to the same channel. Turn both on. Push the transmit button and speak into the microphone which is on the face of the radio. You should hear the voice in the other walkie talkie.
Note; all of these FRS talkies have substantially less range than advertised. They should provide reliable service within about 1/4 mile line of sight, no more. In an urban environment with lots of buildings you will get less.
Oct 14, 2014 | Radio Communications
Audiovox GMRS1072CH MANUAL
You can download the manual from here: http://www.manualslib.com/manual/355091/Audiovox-Gmrs1072ch.html
Jul 10, 2014 | Audiovox 2-Way 14 channel FRS Family Radio...
I get white noise on my walkie talkie...only when I use the walkie talkie does it stop...what do I need to do to stop this and have it function properly
Sounds like the 'squelch' is not high enough. Check the manual how to raise the squelch level. Then the receiver will be silenced until you receive a strong enough signal.
Jun 23, 2014 | Uniden GMR3040-2CKHS 30-MILE R
Where can I get the belt clips that go on the back of my Audiovox FR-1438 Walkie Talkies ??
I'm not familiar with that make of radio, but try taking the unit to your local Radioshack or similar store, and I'm sure they will come up with a solution.
I hope this answer helps you find the part.
Cheers,
Peter
Feb 04, 2013 | Audiovox Fr-1438 Two Way Walkie Talkies...
Nextel i850 can't receive calls
  • may be the walkie talkie can recieve signals only to an certain distance,so it may be due to the signal problem........
  • if the reciever is beyond the permitted distance it loose its frequency...........
  • or else the person who is calling walkie talkie might not hav signal in that area.....
  • and if the walkie talkie does not recieve any signal then the receiver component present inside the walkie talkie might be damaged.........
  • and if it does not reply to an signal transmitter might be damaged..........
  • i hope my answer would be sufficient for u.....thank u......
Sep 10, 2008 | Motorola Mobility i850 Cellular Phone
Radio Communications Logo
127 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
