Walker saorview 32 inch tv
My sound on my walker 32 inch tv keeps goin of every 5 mins or so after i turn it on wat could that be ..
  • 155 Answers
SOURCE: Vizio 42", have picture for about 5 mins then screen goes black.
also check the power cord wire coming from the back of the tv is loose from the tv side or perfect.
Posted on Oct 26, 2008
  • 668 Answers
SOURCE: Toshiba LCD TV AV500E Turns off then on every 5 minutes
It sounds to me that the Main board is causing the problem. But I would get in touch with Toshiba for a warranty repair. It has a one year parts and labor warranty. It makes it a lot cheaper for the pocket.
Good Luck,
Skyassoc
Posted on Jun 20, 2009
dsacco86
  • 1077 Answers
SOURCE: lg 32 inch lcd on light flashing white but fast
Sounds like it started "Protection Mode" because of a failed electronic part inside the TV. When this happens, the TV will keep turning itself OFF or will not turn ON at all. This keeps the other part inside from being damaged. Most likely the TV has a power supply related problem. It's possible that it maybe a badcapacitor or transformer on the power supply board. The common part to go bad for flat panel screens circuit board that powers the screen. Most manufactures call it a Backlight Inverter Board.
But, I can't say what is 100% the problem because I can't actually look at the tv over the internet. I can only make guesses with the symptom.
You have a few choices:
1. You can again try leaving the TV unplugged for 30 - 45 minutes so the TV can discharge and reset itself.
2. If by chance the TV is still under warranty, go that route.
3. If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, schematics, test points, and part# lists.Usually, cost under $20. And most cases the new part cost less than $15 by searching on the internet with the part number.
4. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
I hope I shed some light on the subject for you.
Posted on Jul 21, 2009
  • 4 Answers
SOURCE: my samsung 40" lcd power problem
I had the same problem with my Samsung LN26A450 LCD TV. I found the following YouTube video http://www.youtube.com/watch?v=Mm51C_RDIZE titled "Samsung TV Repair - Part 1 of 2) (also watch Part 2 of 2) which shows how to easily fix the problem. The problem is bad capacitors on the power supply board. My TV had seven (7) bad capacitors - all 7 had dark stains on the ends from leaking electrolytic fluid and one (10V 2200MFD) was blown with bulging ends. I ordered 7 new high-temp (105 degrees C) aluminum radial capacitors from DigiKey.com matching the Temperature, Capacitances and Voltage Ratings for each damaged capacitor that I removed. I followed the instructions in the video except I used desoldering braid ($3.99 at RadioShack) to remove the solder attaching the bad capacitor leads to the power supply board. Once you wick up the old solder from all sides of each lead wire using the desoldering braid, the bad capacitors are easily removed. Total cost of repair including soldering equipment was less than $50. Thanks to “The Professor” for posting the video and saving me $400.
Posted on Oct 30, 2009
dave1645
  • 834 Answers
SOURCE: my 32 inch westinghouse lcd tv's screen turned pink when on
your T-con board is failing you need a tech to replace it about a 150 dollar job
Posted on Nov 18, 2009
How do I fix a 32 inch 32lg70 smart tv that has sound but a white screen
unplug for 5 min at least the hold the power button on the tv not the the remote then plug back in and turn on
May 31, 2016 | Televison & Video
Technika 32" led 32-2481. Keeps loosing the saorview tuning. Have to auto scan every time move from hdmi back to saorview. What's the problem.
Main system control memory IC is faulty. Replace it. Contact any service technician.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 31, 2014 | Televison & Video
I have an alba 32inch tv and the sound keeps turning off we have to then switch tell off for a minute to get sound back but the sound is gone again in 5 min only 2 years old
sound like there is a over heat / or failure of some circuits
32 inch are quite cheap now, so it maybe something you should re-place,
or flog to a 2nd hand shop if it last long enough to sell during test
Jun 25, 2014 | Alba Televison & Video
My Hisense 32" inch tv has started making a popping sound and is static and it turns off then turns on and load then "pop" it off and it does it again then turns on stays on for about 10 mins with no sound...
Sounds like you have a bad power supply board. Either replace the TV or get it fixed (probably not worth spending too much on considering how cheap new 32" TVs are now).
Nov 29, 2013 | Televison & Video
My sony trinitron 32 inch widescreen only gives slight flash when you turn it on but sound is working. no picture just sound. picture worked once since this started happening and then went off again. Any...
there might be a problem with the connection of the screen to the motherboard or the wire that connects it might be the fault. but there could be a burnt fuse or components.I would suggest letting a tv tech have a look good day sr
Nov 23, 2010 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sanyo TV LCD 32 inch about 3 years old. No
the power supply of your tv is bad try to check the fuses if fuse are open try to replace them with the same value..try to power it on but if the fuse blows again replace the power supply board...
good luck plse rate my help.
Jun 04, 2010 | Sanyo DP32746 32 in. LCD Television
Lg 32 inch lcd on light flashing white but fast
Jul 20, 2009 | LG 32LC7DC 32 in. LCD HDTV
Turn off /turn on
I have an 32 inch Akai TV/DVD Combo; the TV turns off by itself about every 20-30 min, and when I put in DVD to play, the TV cuts off.
Jan 30, 2008 | Akai LCT3215/26 32 in. LCD Television
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
