Question about GE Cameras
Write protect when i try to take a picture write proc tect comes up and won't let me take a picture
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • GE Master
  • 102,366 Answers
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Posted on Sep 07, 2014
What's your problem?While trying to take a picture it keeps coming up with write projects and won't allow me to take the picture
I assume it's actually saying "write protect" and not "write project".
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Oct 18, 2012 | GE X5 Digital Camera
It keeps popping up write protection on and won't let me take pictures
Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Apr 09, 2012 | GE T123 Digital Camera
Tried to download pictures and get message of bad connection
mi pc no detecta la camara que puedo aser para q la de tecte
Dec 18, 2009 | Vivitar ViviCam 55 Digital Camera
The ring of lights on the console are all red and it wont turn on to green
try cooling the unit with a fan and seeing what happens, the thermal overload circuits are protecting the internals from failing due to solder melting or overloaded proc.
Dec 14, 2009 | Microsoft Xbox 360 Console
Vcr keeps saying safe
Try this: (actually found in user manual...)
Pro-Tect Plus™ (Child Lock) Feature
This feature is useful to tamper proof your timer recordings from unwanted changes
and/or protect the VCR from mis-operation by other users in the household.
To Lock the VCR
Press and hold POWER or VCR on the remote for
approximately six seconds to turn on the Pro-Tect Plusª
feature.
SAFE appears in the VCR front panel to let you know the
feature is activated.
To Unlock the VCR
Press and hold VCR button on the remote for approximately
six seconds to unlock the VCR.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up) If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
May 27, 2009 | RCA VR355 VHS VCR
SAFE
Pro-Tect Plus™ Locking Feature
To disable VCR usage or to protect set timer recordings, the unit can be locked so that the
buttons on the VCR or remote control don’t work.
• To Lock: Press and hold either the remote control’s ON•OFF or VCR button until SAFE
appears in the display to indicate Pro-Tect Plus is active. SAFE also appears if the VCR is
turned on while the feature is activated.
To Unlock: Press and hold either the remote control’s ON•OFF or VCR button until SAFE
disappears from the front panel display. Unlocking is the only way to use the VCR.
May 10, 2008 | Televison & Video
Mother board
Oh thats easy.!. Well here we go: First you need a screwdriver, and a calm hand and patience; then we can start...
  1. Power off your computer
  2. Disconnect all cabling at the back of the computer. Maybe you want to note which cable goes where so that later it is easier for you to put back the cables.
  3. Open your computer case (the one that is opposite of the motherboard.
  4. Now you can either use a "digital camera" ro assist you; so you make pictures of the board configurations, or you can make drawings to guide you (You probably want to put a new motheroard into the PC so you also want to know where the cables will go right ???
  5. Disconnect your cables from your motherboard that come from your power supply. Also disconnect the wires going to your drives ( CD-ROM, DVD) that come from the Power supply.
  6. Now disconnect your Data cables ( IDE or SATA cables) that run from your CD-ROM / DVD and hard drives. Just remember their configeration.
  7. Now, disconnect the other cables, mainly audio, cpu fan cable, chassis fan cable and audio drive through cables and any other cables attached to your MB.
  8. Next up we have the removal of devices that are direclty attached to your MB. Remove the RAM (Do not touch the RAM on the chips, rather hold it at the sides), remove all add in PCI cards like network card,graphics card etc and put them in seperate anti-static containers
  9. Now its time to get the proc: Remove the heatsink+fan by unscrewing it from the MB; there must be four screws around the MB. If you have removed the Heatsinkwithfan, you will see the proc. There must be either a little switch, a screw or lever to "release the proc" from its "socket" otherwise you will damage your proc and or your motherboard. If you have released the lever, you can remove the proc. lay it somewhere, so that its pins or chips lie down.
  10. Check if there are addional devices that need to be removed.
  11. Next, unscrew the MB from the casing, There should be about 6-12 screws on the MB.
  12. All done: All you need to do now is remove the motherboard slowly from its rest, take it out and put it somewhere safe
  13. All done
Next up would be: How do I install a motherboard.
Kind Regards,
Dominik
Apr 15, 2008 | Computers & Internet
Emachines 2682
check all the pins for the power supply to the motherboard.
actually all connections to the motherboard should be checked. use the manual to make sure all the connections are correct.
Apr 08, 2008 | E-Machines T2682 (000002965) PC Desktop
Can't receive pictures
Hi ya sounds like the problem is with the setting on your phone also sending pictures from different makes of phone sometimes dont work as their picture might be a different format to your phone.
If the problem is your setting then you can ring your service provider tell them that you need the settings for mms they will send you a text message that will updat your phone.
Also depending on what network you are on if you go onto your service providers web site some networks give you the option of sending your phone the setting this way but i know the tect message works because i use it myself when i change networks.
Let me know how you get on ok
Nov 27, 2007 | Motorola Mobility W375 Cellular Phone
Cameras Logo
29 people viewed this question
Top GE Cameras Experts
Steven Wander
Steven Wander
jjanesic
jjanesic
Level 1 Expert
Are you a GE Camera Expert? Answer questions, earn points and help others
