Question about Matrix Star SP200 Receipt Printer
Star sp200 dip switches - Matrix Star SP200 Receipt Printer
Can I get the user manual ?.
Hello there
If you go to this webpage:
http://www.i-pos.nl/download/star/user%20manual%20SP200.pdf
you will download a pdf format manual for the SP200, which can be saved to your computer for future reference.
Mar 06, 2015 | Impact Star Sp200 Dot Matrix Pos Receipt...
Can I use a serial adapter to use the parrall sp200-24 printer
no, but if it helps you can get usb to serial or usb to parallel
May 12, 2012 | Star Manufacturing Star SP200 Series...
My star sp200 will not print when asked. The "online" light is not lit up (I'm not sure if it was on before the problem) When I unplug the printer port cord, the online light comes on and the feed button...
1. check the usb or parallel cord to the PC to see if it is connected proper ly
2. clear all print document on the pc
3. If the "online" light will not come on this may mean that the cord is not completely in the connection socket.
4. check Dip switch for parallel cable ( should be 3 ON, 4 ON, 5 ON) this is for USA settings
5. check paper roll ( if at the end of roll it will shut down if proper paper load is loaded.
6. When temperature at the print head is high printer will go "offline"
7. check the alignment of the ribbon also
Mar 18, 2010 | Matrix Star SP200 Receipt Printer
Trying to use star sp200 with quickbooks pos and keep getting spread out printing
Sounds like the "template" is set for "letter size" paper rather than "receipt" paper.
Go to "Workstation" Preferences, and then "Printing". Verify the template selection.
Jan 07, 2010 | Matrix Star SP200 Receipt Printer
Looking for windows xp driver for star sp200 printer please send me a link to driver download at ryoungland@aol.com
This printer is only support to windows 98 and windows 2000. here is the link where you can get the driver for your printer. hopefully it will work.
http://www.barcodesinc.com/star/sp200-series-drivers.htm
Aug 28, 2009 | Star Manufacturing Star SP200 Series...
Opening drawer through star sp200
code for star printer sp200 open drawer code ( tested and works ) 27,7,11,55,7
Oct 08, 2008 | Matrix Star SP200 Receipt Printer
No power for the star sp200
It actually has two in the bottom of the case.
Aug 18, 2008 | Impact Star SP200 Matrix Printer
Star SP200 printing issues?
The print head has gone out on your printer. The printhead will have to be replaced
Jul 25, 2008 | Star Micronics SP 2000 Matrix Printer
Matrix Star SP200 Receipt Printer Logo
26 people viewed this question
Top Matrix Office Equipment & Supplies Experts
Dimitar Todorov
ray gallant
Tom Chichester
Are you a Matrix Office Equipment and Supply Expert? Answer questions, earn points and help others
